Look what I found on my Porch when I got home today!
   / Look what I found on my Porch when I got home today! #21
I was thinking among other things that would be the perfect tool to dress up and older established gravel driveway. thanks for posting the pics JOHNTHOMAS.
   / Look what I found on my Porch when I got home today! #22
Just got mine yesterday. Installed this morning in less than 5 minutes. Its really wet here so I got limited use. What little I did do I like what I'm seeing. I feel already it was worth the $. Nice dimension to the FEL and goes on an off so fast.
   / Look what I found on my Porch when I got home today! #23
I think I could use one of those, be sure to let us know how it works for you.
   / Look what I found on my Porch when I got home today! #24
Anyone want a deal on a 68" ratchet rake? $300 shipped obo.
j
   / Look what I found on my Porch when I got home today! #25
j
What convinced you not to keep it? Did it not work well? I was thinking about one, but I have welded teeth on my bucket.
   / Look what I found on my Porch when I got home today! #26
It's just not working out as I had planned/hoped. The area I bought it for simply has too many very large rocks. I'm talking 2-4 ft sized rocks. I end up having to remove the rake too often to use the FEL as I need for this area. If the rocks were smaller or fewer it would be ideal.
j
   / Look what I found on my Porch when I got home today! #27
Installed and used it for a few minutes this evening. I just dragged/picked it up and set one end on bucket and then other end. Lifted end off while I installed strap clip then did same on other end. Very easy to install by myself. 5 minutes and that was mostly tightening the straps with ratchet handle. If the brackets were an inch farther from the edge I wouldn't have had to lift it off while I clipped straps but it was no big deal. I'm even more impressed with it after using it. I worked a small space that I was limited in by trees and grasses but it's left to where a hand rake will have it ready in 5 minutes to plant. Also raked down gravel in front of my tractor bldg and satisfied with results. I really like it. I can see the edges of the Ratchet Rake from my seat so helps alot being visible. Easiest implement to install that I have.
No offense but I'm not that impressed with what I see. Maybe I'd have to be there but when I'm done with a box blade it's as smooth as a babies butt. Perhaps in a larger area the ratchet rake would do better.
I have a boxblade and it could not have done most of this job due to closeness of plants/trees. It could have done one straight pass but no better than the ratchet rake. I was pushing dirt and rocks around and then back dragging for smoothness with the ratchet rake. Pictures don't do it justice. Since I own a boxblade I am not putting the boxblade down. They are just different tools for different purposes.
j
Couples of weeks to late. I believe they have a satisfaction guaranteed or your money back.
   / Look what I found on my Porch when I got home today! #30
Yup they do, but I figured I'd try to help save someone on here a few bucks.
j
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
Quick Attach Pallet Forks (A47384)
Quick Attach...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
