Grand L5740 pushing it's reach ...
/ Grand L5740 pushing it's reach ... #1
DamonH
Rockwall, TX.
2007 L5740
We loaded up the last of our hay to head off to central Texas and I must say I was pleasantly surprised with the "little Kubota". The previous bales had been loaded by the buyers larger JD, but it wasn't available when the semi came back for the last load. I had my doubts we'd be able to get the top row of bales loaded, but the L5740 came through! I definitely wouldn't have tried it without a bale on the back end! :eek: Just thought other's might enjoy the pics.
Getting started:
main.php
R E A C H I N G:
main.php
Working on the last row:
main.php
Heading south:
main.php
/ Grand L5740 pushing it's reach ... #2
You Texans always do it bigger. I haven't seen hay stacked that high since we manually stacked square bales that high!
good to hear the 5740 is up to the task!
/ Grand L5740 pushing it's reach ... #6
OK -
How do you get the bale that you stuck on the backend on the truck?
16 bales on and one on the ground?:)
/ Grand L5740 pushing it's reach ... #7
It's only 2 bales high>.:D
Seriously, or more likely..Not. This is even made easier with stupid annoying smilies, with them you can make anybodys good effort look like they almost didn't do good.
Come on you can do better..........
To the OP> Great job as some on earlier posts have been questiong the capabilities of the bigger Kubotas. My wife and I will wear our Kubota Hats with pride this weekend! Nice tractor and,Thank you very much! Good pictures.
OK -
Driver would only carry 32, and we had 33, so it worked out. We ended up keeping the runt of the bales.
/ Grand L5740 pushing it's reach ... #10
Great pics. Two questions - 1) - what was the approx weight of the bales and (I am assuming about 1500lbs each -32 x 1500 =48000 or 24 tons) and 2) - Did you reach across the trailer for both upper and lower rows, or did you load from both sides?
/ Grand L5740 pushing it's reach ... #11
I say "JOB WELL DONE" I have L5740 and love it. I traded up from a B7800 - no comparison. I use a 55 gallon drum with 800# of concrete in it for a counter weight while I handle haylage as well as dry round bales. I have no problems with this set-up. I have a 20' gooseneck flatbed with a 5' dovetail, and I can haul 14 dry round bales on it by stacking two rolls of 5 on their side with a top roll of 4 centered. I have no problem setting the top ones in place. The L5740 is an awsome tractor for what I need done. The B7800 was a good one also - just not big enough to constantly handle round bales (used a 3-pt spear). As always, when having a load like that high, level ground and slow and steady WITH SEAT BELT ON.
1). I'd guesstimate they were closer to 1100 then 1500.
2). We reached across on the bottom row, then loaded the top from both sides.
That's not a bad idea. Do you have water in your tires? We don't, but plan on filling them soon. We normally throw the disk on with a railroad tie or two to give us extra weight, but we left the hay fork on so we could get the bales closer to the road in a more timely fashion.
/ Grand L5740 pushing it's reach ... #14
I do have my tires filled also, with the bio-ballast - that adds about 475 lbs per tire or about 950 total in both.
/ Grand L5740 pushing it's reach ... #15
By the way, here is my L5740
2021 Kubota RTV1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2010 SmithCo Super Star Bunker Rake (A59228)
2010 SmithCo Super...
30in. Forks and Frame Mini Skid Steer Attachment (A59228)
30in. Forks and...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
