mini hoe question
  • Thread starter washita
  • Start date
/ mini hoe question #1
W
washita
Guest
diggin a trench for the neighbor with the mini hoe when he asked a interesting question on why the boom stick did not move side to side? my reply was additional hydraulics to run it, his suggestion was a pivot joint that would be self centering by weight of boom stick and bucket but would pivot left or right x amount of degrees when bucket would be higher than the pivot point, now I am wondering if this would be practical or a incident waitin to happen
/ mini hoe question #2
How are you going to control which side it flops to?
How will you keep it from flopping when you don't want it to?
/ mini hoe question
a pivot point similar to a snow plow with a pin to limit degrees of swing, or king pin style as seen on solid front axles (buses-dump trucks) 5 to 10 degree of swing with stops just enough to clear the trench without moving the machine, use a pin to lock boom in straight position if movement not desired, maybe a pivot joint would not handle the stress, probably just wasting my time thinkin- I tend to over analize:eek:
/ mini hoe question #4
I think you would run the risk of racking or twisting your lift arms if you fabricated a pivot bracket for your mini hoe and mounted it to the quick attach adapter plate. There have been times that I have carried an unbalanced load in my loader bucket and it does put stress on one lift arm or the other. I never had any problems finding a spot to dump dirt while using my mini hoe...I just turned the steering wheel to dump and turned back to continue digging.
/ mini hoe question #5
I've tweaked the lift arms on my 425 doing something similar. Piece of a pine tree trunk about 12' long BUT I didn't know one end was still attached to the stump...
/ mini hoe question #6
The mini-hoe is one of my favorite attachments. I think the simplicity of design is its greatest asset. I don't see any advantage in added hydraulics or a swinging set up as you describe. The one gripe I have is the auxiliary handle position, I'm planning to mod that as others have already done-- moving it to the other side. Using the steering to move the boom seems to work great, and it's easy to do quickly, especially with a steering wheel knob.
/ mini hoe question #7
I wonder if it would help to dig a straighter trench? With the swing arm that is.
/ mini hoe question #8
I've used the mini-hoe (PT-425) a LOT and find that it is a little harder to stay straight than with a conventional backhoe w/swing capability.
It's easy, though, to "draw" a line where the trench is supposed to be by backing up with the bucket on the ground with a little downforce to see where you want to dig.
A painted line on the ground gets obliterated pretty quickly when emptying the bucket because you're constantly driving over the line.
It's also pretty hard to dig a good trench on a cross slope as there's no way to level the tractor as with a conventional backhoe.
That said, I've saved a lot of $$$$ by using the PT to dig the trench for our power line, the hole for our septic tank, a few hundred feet of sewer line, and the leach field for the system. Would have been nice to be able to dig just a little deeper, but for our site all the piping received fill over the original trench to get to the desired depth.
/ mini hoe question #9
The Lackender minihoe gives me ~6' of depth. I have dug hundreds of feet of trench, etc. Very useful and saves me a lot of money and i do not have to try and coordinate getting someone here when i need them.
Ken
