Bolt on Bucket Hook and Receiver mount for JD2520
   / Bolt on Bucket Hook and Receiver mount for JD2520 #1
billmcba
Connecticut
John Deere 2520
Hi All,
Check out my Bucket Hook mount with receiver that I came up with for my 200CX loader on a JD 2520. I'm hoping this makes the simple jobs easy now to pick up / move with the loader...
I have added a 3/16" backer plate inside of the bucket, bolts are 1/2 diameter grade 8.
Bill
   / Bolt on Bucket Hook and Receiver mount for JD2520 #2
And looks like you could just take the whole mess off and put it on a new tractor someday if you needed to? Nice idea.
Hi RCR,
Yes you have to plan for the next one...
This is the first picture that I have posted on TBN... I did not know we had a limit. Can you tell me what file size or picture size is prefered?
By the way I just looked at your pictures and I had the exact same idea for a bucket insert to help clean out a part of my pond... Nice pictures!
Bill
   / Bolt on Bucket Hook and Receiver mount for JD2520 #4
Very nice workmanship.
How thick was your bucket sheet metal? Was it hard to drill in that many holes?
Ivan
   / Bolt on Bucket Hook and Receiver mount for JD2520 #5
Once I welded a hitch receiver on my FEL bucket, I never used the 3 pt. hitch to ever move a trailer. I'm sure you'll find your setup very useful. Great job!
Thanks everyone for your comments.
Drilling the 12 holes was easy as I used the backer plate (which had 1/2" holes in it) to locate the hitch on the top of the bucket loader. Then I clamped the plate to the loader and used a transfer punch to ocate the hole centers on the bucket. I drilled a pilot hole with a sharp drill and left the backer plate on all the way up to the 1/2" holes goling into the bucket to be sure that everything was alined.
That worked well as I could drop a 1/2" bolt into all holes and none were sloppy.
Bill
   / Bolt on Bucket Hook and Receiver mount for JD2520 #7
Hi RCR,
Bill
There is no limit that I'm aware on TBN. However, some folks with slow connections have trouble downloading the bigger pictures. That being said, many times a big picture is the way to go because you can zoom in and see details on a bigger picture. Play around with image resizer as it is easy to use and see what you think..
BTW, the red message is part of my tagline, but I am not a moderator and have no authority on TBN. In other words, you can just tell me to go jump in the lake and make the pictures any how you see fit. :)
   / Bolt on Bucket Hook and Receiver mount for JD2520 #9
Now what you need is one of these. It is not my idea, but I took advantage of it.
Thanks guys, I'm eager to build a pole boom as well. In fact I was just looking at other posts to get some ideas. I think the mount will be a nice addition to the 2520.
Oh, regarding the question about the drilling the bucket material that was easy. I did not measure the material but I would estimate it at 10 guage (around .100) by eye. The key is sharp drill bit.
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
E-Z TRENCH GROUND SAW (A51244)
E-Z TRENCH GROUND...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52128)
2016 Ottawa Yard...
IH 735 5 Bottom Plow (A50515)
IH 735 5 Bottom...
2015 KUBOTA M5660SU 4X4 FARM TRACTOR (A51243)
2015 KUBOTA...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
