If you could what would you change
   / If you could what would you change #21
built in seat warmer,
built in ports for a 30-50 btu heater for fast install/removal regardless of having a cab or not.
definately a toolbox built in some where hidden like rear fender but easy to get to.
a cell phone/pager slot with cigarette plug for charging. (my bx is near floor- great place to break the cord! bad place!)
rops that fit standard garage doors or at least the option to change to a lower top half!
   / If you could what would you change #22
Not much of any tractor I can't fill real easy with this.
I would like to see the fuel tank moved to behind the seat. It is a pain holding the 5 gal. container and trying not to slop fuel all over the hood. It is even worse when the loader is on. My old Case I.H. had the tank behind the seat and the fueling went much better.
   / If you could what would you change #23
I would like a cup holder that does not cause my beer to go flat. I would be nice if it kept it cold as well! :D
   / If you could what would you change #24
Agree with that one...Don't know who designed that holder, but a can just rattles around and spashes all over the place. Not deep enough either.
   / If you could what would you change #25
On the BX 24, mre clearance with the rear tires and the MMM so I could run chains. Sometimes 4x4 and diff. lock is just not enough!
   / If you could what would you change #26
improvements.. lots of the above. Though some I've got already I noticed, guess they are makeing changes.
Oil pressure lights - hydro and regular.
I have parking brake lights. A buzzer would be good... I'm getting better.
Toolboxes that you could fit things in. More places to put all sorts of stuff.
M59 - vent the exhaust up. Not like the FOPS is foldable...
   / If you could what would you change #27
L2550, L3450 - A seat suspension linkage that is designed correctly such that the linkage pins pivot within the link bearings as opposed to pivoting in the sheet metal frame.
ALL tractors - a brake lock that locks both pedals.
larry
   / If you could what would you change #28
1. Skid plate or better protection for the hydro fan.
2. Better more visible tach with separate hour meter.
   / If you could what would you change #29
L2800HST,swril seat about 12 degrees...like some models NH offers.
   / If you could what would you change #30
A bit off topic, but I set a small rubber mat on the hood and then set my 5 gallong can on that. I remove the cap on the can and on the hood, and then I use one of those three dollar siphon pumps (the one with clear tubing and a colored hand pump on top) to siphon the fuel from the can to the tank. Works awesome, no mess, no funnels, and no twisting trying to pour.
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
1985 Suzuki Shaft230 Quad Runner (A59814)
1985 Suzuki...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
