Look what I found on my Porch when I got home today!
   / Look what I found on my Porch when I got home today! #11
I will have to charge the battery and fill the rear tires and add a rear weight box and boxblade.:) Since I haven't received straps yet, I'm not sure how it'll attach to the front.:D
Use duct tape!:D
The universal engineering tool!:D
   / Look what I found on my Porch when I got home today! #12
first I've heard of the ratchet rake...went to the official site and I like what I see and bookmarked it.
I do a lot of back bladeing swale holes with the FEL so it looks like it might prove useful. In the mean time I'll see how you guys like it.
thanks for the heads up and links...yes those are very nice.
   / Look what I found on my Porch when I got home today! #13
I'm thinking one might be handy also. I just seeded an area, maybe around 1 acre, and it would have been handy for getting it preped. You need something to groove the soil for the seed, and it looks about perfect. Let me know how it works.
When I drove up my drive and saw this sitting on my porch I :Ded. Since tomorrow is my birthday I'm going to call it my birthday present to me! Heavier steel than I had visualized. Believe it will do heavy work. Now waiting on straps to install it on tractor. Just ordered it Sunday and today is Wed. Will send photos of straps when they arrive.
Straps arrived today. Here's pictures as promised.
   / Look what I found on my Porch when I got home today! #16
Are you sure the light metal bucket can handle that?;):)
   / Look what I found on my Porch when I got home today! #18
That is really impressive! Did you check the shipping weight on the label?
Installed and used it for a few minutes this evening. I just dragged/picked it up and set one end on bucket and then other end. Lifted end off while I installed strap clip then did same on other end. Very easy to install by myself. 5 minutes and that was mostly tightening the straps with ratchet handle. If the brackets were an inch farther from the edge I wouldn't have had to lift it off while I clipped straps but it was no big deal. I'm even more impressed with it after using it. I worked a small space that I was limited in by trees and grasses but it's left to where a hand rake will have it ready in 5 minutes to plant. Also raked down gravel in front of my tractor bldg and satisfied with results. I really like it. I can see the edges of the Ratchet Rake from my seat so helps alot being visible. Easiest implement to install that I have.
2004 TAKEUCHI TB175 EXCAVATOR (A51242)
2004 TAKEUCHI...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
Mayrath 10 x 32 Auger (A50514)
Mayrath 10 x 32...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
2015 ISUZU NPR 16FT BOX TRUCK (A51219)
2015 ISUZU NPR...
