John Deere 750 Head Gasket Gone Again
   / John Deere 750 Head Gasket Gone Again #1
woodduck97
OK guys my dads friend has a john deere 750 with the 3 cyl Yanmar diesel with 800 hrs and like 25 years old. About a year in a half ago it puked out collant we tested the radiator for exhaust gases. Came back positive. SO we had pulled the head off and when we had pulled it off the last cylinder closest to the steering wheel was filled with antifreeze. We had started to inspect the head and it had cracks in that cylinder so we had went ahead and bought a new head for it witch was like 700 and some change along with new head gaskets and stuff. The other day he was using his bush hog and it had puked out antifreze agin and then stoped running cause one cylinder has filled with anti freeze. Now could have the head bolts strected due to that they were the old ones or what just trying to get a idea on why it blew the gasket again and maybe the head but not sure till we get the tractor to work on it. Also it happened when he was bush hogging the first time and did the same thing again. Any ideas would be helpful Thanks.
   / John Deere 750 Head Gasket Gone Again #2
Did you check the block deck for flatness and cracks, or corrosion pitting?
As for the head bolts, sure, proper torqueing is required, starting from the
center of the block and moving outward. Some manufacturers call for
re-torquing after the engine has been running for a while, but the reality is
that virtually no new engine undergoes re-torqueing. I assume you did
the initial torqueing correctly....they only take about 65-70 ft-lbs. I never
buy new head bolts myself, though on some modern engines, new bolts
are required because the stretching ruins them for re-use.
Sorry to hear of your troubles.
Yes had went back with the factory head torq. No cracks or corroding on block. Head and black was stright had got a edge from are race engine builder to make sure before we put it back on. Could a cause be that the radiator is not getting good flow due to old age and getting hot and pushs the gasket.
   / John Deere 750 Head Gasket Gone Again #4
You may be onto something. When you are starting to overheat, the
cylinder farthist from the radiator will get hottest and fail first. That
assumes flow is not compromised to one cyl more than another. On my
older Yanmar engines (1996 vintage JD955), I notice the water passages
are not very big, while the newer one (EPA tier 2) has much bigger water
passages. On yours, can you see well enough in the water passages to
verify no serious blockages or rust build-up?
Well we havnt had time to tear into the engine yet but thats the only other thing we can think of. But I do know when we get it off this time we are going to be cleaning passages if needed in the block and checking the radiator and if a lil stoped up its geting a new one.
   / John Deere 750 Head Gasket Gone Again #6
I probably would have changed the head bolts. Cheap insurance. Alot of bolts once torqued wont hold torque again.
Overheating could have caused some issues. Did anybody notice if it was overheating before these problems?
And your sure you checked both the block and the head in several places? Front to back, side to side, and corner to corner for flatness? Some just throw the straight edge down the centerline of the block and call it flat.
   / John Deere 750 Head Gasket Gone Again #7
I know this is an old post but I am having trouble with my jd750 head gasket.
How was this resolved?
   / John Deere 750 Head Gasket Gone Again #8
Unfortunately the OP hasn't been seen here for 14 years or so, so we probably wont know how he got to the root of his issues.
What is happening with yours? Might be worth starting a new post so people can respond directly, and not have your issue get lost down the page.
EDIT: Just found your other thread and Im having a look there now.
   / John Deere 750 Head Gasket Gone Again #9
Any time you remove head bolts put them in the trash
In most cases, you should not reuse head bolts because they are designed to stretch when torqued, meaning once used, they may not provide the proper clamping force if reused and could lead to potential engine issues like head gasket leaks;
willy
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
DEUTZ MARATHON...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
Pickup Truck (A59230)
