WHATS BEST
/ WHATS BEST #1
outdooretc
ASV RC 100 OR THE NEW ASV PT100 OR BOBCAT T300 OR T320? HELP ME DECIDE.
/ WHATS BEST #2
That is a pretty broad question. What do you intend to do with the machine, landscape, excavation, operate on grass, woods, asphalt, pallet forks/hardscape, load trucks, need high flow for stump grinder, cold planer, brush cutting, need ground speed, need ground clearance, is width a concern? You'll get plenty of opinions on these two and I'm sure some others, but the best thing would be for you to operate each one of them to see how you like them. By the way....PT100
/ WHATS BEST
ill be clearing brush..
/ WHATS BEST #4
You might want to try out the ASV PT100 Forestry machine. I think it is the only "rubber-tracked" machine built by an OEM made for brushcutting. I understand that the older ASV RC100 had some axle issues at one point. I know a contractor up here in WI that is in his second summer with the ASV that he bought and he hasn't had any problems in just over 900 hours. I think ASV replaced all of the wheels so that they now use metal face seals and I think they beefed up the axles. The machine comes standard with a fully pressurized cab and an automatic reversing fan so that it blows debris out of the cooler. The belly pans are also hingd so that it is easy to clean out the engine compartment. I do know that there is nothing from an OEM on the market that can touch the hydraulic hp that the machine puts out- 40gpm@3,650psi. Like I said yesterday, you should demo all of the machines you decide to consider.
/ WHATS BEST #5
yeah i have two new pts and have had two replace both axles on both machine for a second time in less than 1000 hours on them anyone else experiencing these problems
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
1996 INTERNATIONAL 4800 SPREADER TRUCK (A63291)
1996 INTERNATIONAL...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
Diesel Engine Oil Tank (A61573)
Diesel Engine Oil...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
