cub cadet 3186 will not move
   / cub cadet 3186 will not move #1
nolan1
Member
Hi I'm new here. I have a Cub Cadet 3186 garden tractor that all of a sudden will not move, the deck will not lift up or down and the power steering will not operate. The engine starts and runs fine and no noise is made when trying to engage the trans or deck lift. Any help would be appreciated!
   / cub cadet 3186 will not move #2
Start by double checking all your hydraulic levers...one could be stuck.
   / cub cadet 3186 will not move #3
Check to make sure the driveshaft is turning because it sounds like the bolts are sheared.
   / cub cadet 3186 will not move #6
Sounds like the charge pump went out.
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
flatbed trailer 24ft (A56857)
flatbed trailer...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
Utility Cart (A56857)
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A55315)
2023 Kubota L3560...
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
