Constantly flat front tire.
/ Constantly flat front tire. #41
FWJ...I had used a 6 foot long 2x6 lying on a tire to break a stubborn bead. I drive my PU truck slowly up the plank to pop the bead loose. Pretty redneck...
We use the Bead Cheata to break down tire/rims while they're still mounted on the tractor. Makes for less work.
As far as "redneck" goes, us rednecks git'r'done one way or another, but we git'r'done!
/ Constantly flat front tire. #42
neat looking tool. i also like those tire changer tools that help you get the rubber on the rim.. I see them on sale at the chinese store now and then and keep trying to convince myself i need one.. but then..I only do a tire now and then, and when that comes up I just go get the irons out and then don't think about it for another year..
soundguy
If you want to do your own tire repairs and you simply DETEST beating on a tire to break a stuck bead, get yourself one of these.
5500 Bead-Cheata [Shoup Manufacturing Company]
I bought one a few years back and you couldn't wrestle it away from me for love nor money! Makes a difficult task SO EASY!
/ Constantly flat front tire. #43
Hey.. whatever works... I've used a fel to press down on a tire bead before.. sure beats standing there whacking on the thing with a 10# tire sledge for 10 minutes trying to get a stubborn one to unseat..
soundguy
/ Constantly flat front tire. #44
yep.. with tubes.. not a real problem with the bead.. though if the rims are bent.. the tires may not seat till you drive it.
vegi based soap helps the bead seat during re-assembly.
yep.. with a few tire tools.. the averae person can do their own tires, if they want to..
As for replacements.. i generally let rubber run till it blows off the rim. it's to expensive to change out rubber still holding air.. :) the front fat 10-16 tri ribs onmy NH 7610s look like racing slicks! and have holes inthe casing my thumb could poke thru...I put thick farm patches on the inside and a boot and a new tube and have been runninghtem 2 seasons since those repairs now.. expect to get at leat aother one I hope.. ;).. the fronts on my 5000 aren't that much better. .. no holes.. but decent amount of checking and some trivial cuts in the tread areas..
soundguy
Great tip. Its the kind of thing you smack yourself in the head and wonder why you didn't think of it yourself after flopping around fighting with a tire.
So far, breaking the bead has not been too much of a problem on these fronts. I haven't had a flat on the rears yet. And, like I say, my neighbor down the road has all the bigger tools for working on the rears.
Probably my biggest problem with the fronts was getting the bead to seat back up. Ratchet straps, sometimes 2 at a time, are often necessary. I'm assuming that won't be a problem now that I've got tubes. Anyway, great advice all around guys.
I figured the tire man must have checked the inside of the tires and pulled out any thorns or nails or whatever. Don't know if he patched inside. The first thing I'll do if I start getting popped tubes is add a boot. I think with the right tools I can do all this myself from now on.......well, I was doing it myself before too, now I should be able to do it correctly anyway.:D
I looked at the tires real close today. Even though they've got a good bit of tread left on them, they are really beat up. Lots of slices. Lots of little chunks missing and even some cracking. They've been abused and have always been outdoors and from what I've read, they're considered light duty/ low price. When its time for new fronts I'll probably get something a good bit heavier duty.
/ Constantly flat front tire. #45
George,
Yes, it looks like a bolt head in the valve stem hole. Since this is the first time that I've done this, and my only experience with it, I can't say what it would take to remove the tire and put on a new one. Since my tires are for commercial use and have a ten ply rating, I would have thought that would work. But taking out trees in the woods is just more then they can handle. I never take it out on the pavement, so wear on the tread should be minimal. I don't foresee replacing the tires, but if it happens, I'll foam them again.
As for the ride, all I can say is that I haven't noticed a difference. I keep them at 35psi, so the ride with an empty bucket seems the same. One thing that I haven't done yet, but I'm curious about, is what it will be like with a heavy load in the bucket. At 4,000 pounds of lift on my loader, I can put allot of weight on my front tires. I've seen them flatten out pretty good under a big load, like a stump. I'm hoping that with the foam, it won't affect the shape of the tire.
As for being able to patch a tire with Slime, that may be true, but getting a repair shop to do it for you is another matter. I've been to several shops and have been told the same thing, you can't patch a tire that has had slime in it. The only way to fix a flat after you have put Slime in it is to put a tube into the tire. Of course, when the Tube gets a flat, you can patch the tube if it's repairable. I've been about 50/50 on getting tubes patched. Sometimes I can, other times I have to buy a new tube.
Eddie
I have foam in the front tires of my 870 with loader
The only way to replace a foam filled tire is to use a sawsall to cut it off---then throw it in the trash.
A foam filled tire will not change shape under load.
You will find the tractor ride is "harder"
How do you maintian a foam filled tire at 35PSI that is impossible...
/ Constantly flat front tire. #47
I'm not sure what "bead sealer" is, but I've sucessfully used regular ol silicone caulck on sevearl tires on 4-wheelers and front tractor tires. Just clean everything up good - put a bead down with your caulck gun and re-seat the tire pretty well (temporary HIGH pressure in the tire to get it to squeeze up against the rim good), then let pressure down to 3 to 5psi and let everything dry overnight. Then put the propper amount of air in, and put it back on the tractor.
This method also worked well for me on a whellbarrow tire that kept loosing pressure and collapsing
The silicone is a bit of a pain to get off if you ever change the tire, but it can certainly be done with a few minutes of work.
/ Constantly flat front tire. #48
soundguy
The bead cheata has another use besides breaking down a beaded tire. They're just as usefull when re-mounting the tire. Where you previously described using vice grips to hold the tire inward, the bead cheata does the same task. The biggest advantage is it holds the bead far enough in towards the middle of the rim so as to put the bead directly in the center of the drop center portion of the rim. Then you simply take your tire irons and walk the lubed tire back on the rim.
I've done field repairs with mine where I've broke the bead on a 20.8X38 tire, dismounted the tire, changed tubes, re-mounted the tire and re-inflated in less than 20 minutes, all by my lonesome. Sure beats pounding on one for hours with a tire sledge..........
/ Constantly flat front tire. #49
Foam will pay for it's self if it keeps me from running one extra day per year figure $175 per flat for the rear tire plus 1 day down in getting a tire fixed if it is fixable, $30 in fuel getting it fixed plus paying crew to pick there nose while the tractor is not working.
Plus the saftey margin in that the tire don't ever need aired up.
$1500 for foam per machine seems cheap to me.
/ Constantly flat front tire. #50
sweet... I gotta put one of those on my christmas list.
soundguy
1770 (A58375)
1770 (A58375)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
207272 (A52708)
207272 (A52708)
SET OF HANG ON QUICK ATTACH 48' PALLET FORKS (A59823)
SET OF HANG ON...
2014 Dodge Avenger Sedan (A59231)
2014 Dodge Avenger...
2023 FONTAINE INFINITY FLATBED TRAILER (A59823)
2023 FONTAINE...
