Any pointers on hooking up brake controller?
/ Any pointers on hooking up brake controller? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
Vehicle - E350 7.3L diesel
Trailer in sig
I bought an elCheopo Northern Tools Reliance BC.
Directions say to use #12 wire to hook it up.
Everyplace sells #16 wire - any danger in using #16?
Also - because of my crammed engine compartment I was planning on just running the wire thru the doghouse -does this seem ok?
/ Any pointers on hooking up brake controller? #2
No way would I use #16 wire...Follow the directions...
/ Any pointers on hooking up brake controller? #3
Maybe a patch cord is available for your truck ?, then it would be just a plug in type installation.
What brand controller ? (ah, never mind. I see it know. Sorry.)
/ Any pointers on hooking up brake controller? #5
I use 10 ga. wire on all my controllers (for the main power). I start right at the battery with it, put an inline fuse holder right there, run the 10 ga. to the controller and then on out back to the trailer connector - wire secured all the way. Your van/truck should have the wiring harness where you only have to buy the pigtail to install but if not be sure and use looming and grommets where necessary. The fuse right at the battery will at least protect the complete run if you do get a short.
/ Any pointers on hooking up brake controller? #6
I'm in the process of hooking mine up now. I went to Home Depot and bought outdoor lighting wire at about fifty cents a foot, which is obviously two stranded. It says 'underground' on the wire so I'm sure it should stand up to weather.
/ Any pointers on hooking up brake controller? #7
Use proper sized wire, it carries a lot of current to activate those brakes. Most Fords are pre wired if you have the big 7 pin at the rear of the truck from the factory. If not you will have to do it yourself. Like others mentioned there are kits for doing this.
Chris
Thanks guys
That's what I figured. It just boggles my mind that the stores sell the controllers and right next to them the 16 gauge wire, when all BC's seem to require 12 gauge.
And my van did not have a factory type hookup.
/ Any pointers on hooking up brake controller? #9
Trailer in sig
Pointer? Follow the directions
5 bucks extra for wire vs. burning hulk once worth $40K...Easy decision for me.
As far as parts stores selling the weak wire next to a BC on the shelf...take into consideration the education and maturity level of those that stock dem dare shelves.
Edit: another pointer which was already stated...and I want to emphasize, if it goes through a sheet metal hole or rides up against a sheet metal edge, it needs a grommet. Took me darn near six months, second brake controller, and a complete rewire of my truck to find the slight rub on the brake power wire caused by the wire going outside through the door sill...There was three layers of metal inside only two grommets, only I didnt see the inside layer that rubbed and gapped too big to place a grommet.
/ Any pointers on hooking up brake controller? #10
What year is it? I would be surprised if it did not have the wires pre-run and just needed a pigtail on each end. My parents '99 E-350 (15 passenger van w/7.3L engine) was setup that way from the factory
Aaron Z
/ Any pointers on hooking up brake controller? #11
On my older truck without the factory towing package i used a inline auto reset circuit breaker instead of a normal fuse , just in case ..........
/ Any pointers on hooking up brake controller? #12
Use a circuit breaker on the power lead instead of a fuse. It will still protect you, but you at least have a chance of getting brakes back if it trips.
/ Any pointers on hooking up brake controller? #13
Get the kit. I wired my last truck, an '89 F250. It was not hard, and I had wire, loom, grommets.
My wifes last truck, an '04 Dodge 1500, was not wired. I got the kit for it; it was not real expensive, all the wire was there, zip ties, loom, instructions for that specific truck. Sure, it cost more than just wire, but it sure was simple.
I was at a trailer supply house looking thru thier catalog yesterday. There are a couple of places that make complete wire harnesses for all kinds of vehicles.
/ Any pointers on hooking up brake controller? #14
Aaron Z
I agree.. my 98 dodge ram 1500, 2000 yukon, and 04 ford f250 all were prewired 'plug in' jobs at the dashboard.
soundguy
/ Any pointers on hooking up brake controller? #15
hopkins products the company that sells plugs adaptors and such sell the kits that are brand/model specific search their site you should find the proper pigtail and then splice it to you northern tool controller. by the way which controller did you get they do sell some better ones even though they are cheap?
It's an '88, no one makes a a wiring harness, just before (the morning of) I picked up the trailer/tractor I had a qualified trailer place (about 100 miles away) wire the brakes.
But there is basically no place nearby that anyone could recommend to do a quality job.
/ Any pointers on hooking up brake controller? #17
Still.. no big deal... the controlers have a power wire, ground wire, brake sense wire, and power wire out to traielr.. 3 of those wires are all handles right under the dash.. the last wire can just be routed to the back, any way you want.. then joined in with the plug, turn and stop/ilumination lamps.. plus aux power wire ( fused or breaker protected ).
soundguy
2014 Ford F-150 Ext. Cab Pickup Truck (A66736)
2014 Ford F-150...
2024 BOBCAT TL619 TELESCOPIC FORKLIFT (A65053)
2024 BOBCAT TL619...
2017 Blue Bird 71 PAX School Bus (A66736)
2017 Blue Bird 71...
CAT 330BL Swing Drive (A68134)
CAT 330BL Swing...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2006 SUPERLINE DO20T192ALP T/A 20FT TRAILER (A66091)
2006 SUPERLINE...
