Tires TC35 front tires
   / TC35 front tires #1
jjbath
Northwest New Jersey
TC35
Is It ok to replace just the front tires. Or do I need to replace all 4. The back tires are still in pretty good shape.
I know on 4wd cars/trucks it can cause premature wear and/or failure of the differentials.
   / TC35 front tires #2
I don't know about 4wd cars and trucks for sure, but my impression is that they travel at highway speeds on pavement most of the time, whereas tractors spend most of their time being driven on soft soil at speeds below 5 mph. I would change just the front tires without a second thought.
Are your front tires really that bad? Are you sure you aren't suffering from "new-to-you tractor-itis"? We all do it. We get a new tractor and anything not perfect just becomes something we worry about too much. Tractors bring out the OCD (obsessive-compulsive disorder) in all of us.;):D
Post a picture. If you show me yours, I'll show you mine.:eek:
   / TC35 front tires
Thanks jinman. I figured it wouldn't matter.
I think they are pretty bad. I'll post a pic tonight. At first they didn't look too bad but the more I look at them they look pretty bald. I found OEM replacements online for $125 each with free shipping. I will install them myself so it won't bee to bad.
   / TC35 front tires #4
Where online did you find TC35A tires for $125? Mine are badly cracked. They worry me on the hill out back.
Thanks,
Boatyard
   / TC35 front tires #5
...I found OEM replacements online for $125 each with free shipping. I will install them myself so it won't bee to bad.
Your rear tires will cost 3x-4x that much each. Your front tires will wear
out extra fast if you drive on pavement in 4WD, since the speed of the
front wheels is a bit more than the rear. Your rears can last many hundreds
of hours if only driven on dirt.....they will likely wear out by the time the
fronts are replaced once, twice, or even 3 times.
   / TC35 front tires
Thanks,
Boatyard
I don't recall at the moment but I have it book marked at home. I'll try to update it later. I think I also found them pretty cheap on Ebay.
   / TC35 front tires #7
Nebraskatire.com has some pretty good prices on blemished and overstock tires. I ordered replacement front turf tires for $44 each including free shipping.
   / TC35 front tires
Thanks,
Boatyard
I found them on Ebay for $90 each. With shipping for 2 tires its $250. They only have a few left though so they might not last long. There may be others from other sellers.
   / TC35 front tires
I took a real good look at them tonight when I got home. The outer part of the lugs has alot of meat left but the centers only have about 3/8" left on them. These tires have about 1130 hours on them. I use 4wd most of the time as there is lots of mud here now. 2wd is useless with no weight on the rear when using the loader.
All in all I think they have some life left in them but for $125 each it may be worth picking them up now for later.
I didn't get a chance to take a pic as I was running it until dark. I have this picture that I took the day I picked it up.
   / TC35 front tires #10
The first two photos are of my left front tire now. The second two photos are of my right-front tire at delivery in February 2001. I don't see that much difference in my tires or yours. Industrials have a thin cleat in the middle for hard surfaces and a thicker cleat on the sides with a flat rolling surface.
2013 MAXX-D BUMPER PULL TRAILER (A58214)
2013 MAXX-D BUMPER...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
case 370 glass door never installed (A56435)
case 370 glass...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
BIMINI TOP FOR BOAT (A58374)
BIMINI TOP FOR...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
