Backhoe thumb
/ Backhoe thumb #1
mboulais
Gold Member
USA
2004 Mahindra 4110
I built this as a father's day gift for my father .....
/ Backhoe thumb #2
Sorry if I am raining on your project and my questions may not be accurate just looking at picture and by no means a thumb expert.
But, is it only bolted on? Did you do something to spread out the stress on the top and bottom of the boom where it is bolted on? It looks a little short, have been told you want the thumb to be longer (at least as long) as the bucket teeth when it reaches the thumb. I have used a thumb a good bit with logging debris on 10,000 pound excavator is my total experience and my concerns may not be valid. But...you certainly don't want to damage a boom section as I have known of being done with a bolt on design by someone on ebay and for certain you don't want there to be a failure when any load lifted.
A thumb is very very handle for many lifting jobs.
/ Backhoe thumb
Yes it is bolted on,Through bolted actually. I am not sure what failure you are expecting. The tube backhoe frame is thin, but the load is near the sidewalls of the tube and most of the force will go into those sidewalls. The plates that for the outside members of the backhoe will handle bending stress as easily as if you were pinching a rock between the bucket and arm.
/ Backhoe thumb #6
As I said I am not an expert, hope my concerns prove all false. A lot will depend on load it is subject to of course.
/ Backhoe thumb #7
Looks nice.
Yes, appears a little short, I've got a thumb on my backhoe and I purchased a little small and it is about 4-5 inches short of the bucket teeth. The only difference is you need to get down under logs and the like to pick up. When the thumb meets the bucket teeth you can surgically pick up, without needing to get under. I may ultimately extend mine, but in the mean time it works just fine.
Joel
/ Backhoe thumb
Thanks all.
WOW- JD decals and all?
Yes, JD Decals and all. Those decals cost more than the money. They were on my desk at work and coworkers who know my preference for red tractors spotted them.
Actually it looks like a computer rendering.
It's real, I edited the photo to highlight it and blur the background.
Actually it fits right around the center point. Sorry, no fancy photo manipulation this time.
/ Backhoe thumb
It probably won't get loaded too heavy, It's on a small backhoe behind a JD790. Besides He has an awesome warranty.
/ Backhoe thumb #10
the reason thumbs are usually longer is that when the boom is fully extended the thumb can reach around the object allowing the bucket to swing in without scooping up dirt my guess is that , this set up may pull some divets, and I have to agree about through bolting ,it is a little sketchy a small rock will peel it right off , also it may split right at the teeth nothces , I am not trying to rain on your parade either but I have built quite a few thumbs. just friendly advice,saying it wont be overloaded is well you know..
/ Backhoe thumb #11
I have the divit issue with mine, I'll be extending.
I figure you you end up with a problem with the bolt through you can always weld to the stick.
Your thumb looks very well built and I doubt you'd have any problems with the thumb it self.
Nice work,
Joel
/ Backhoe thumb
What do you consider "small" when talking about rocks? I would worry about the pivot holes egging out before anything else on that fails. The most likely failure would be swinging the boom and striking the thumb against an immovable object. Sideloading will certianly twist that steel. Those notches are insignificant stress risers in a 3" wide piece of flat plate given the availble force of a compact tractor backhoe. The John Deere model 7 backhoe has a bucket roll force of 2400 lbs, but only 200 lbs boom lift capaicty at full extension. I am not concerned about overloading based on the available power in the backhoe. I think it will outlast the ones he priced online at $400+. The day I gave it to him, I offered to make a longer jaw for it if/when he wants one, but he likes it the way it is now.
/ Backhoe thumb #13
sorry you arent understanding the issue of the rocks, it isnt the weight of the rock that will cause failure it is the leverage enhanced crushing power of the bucket curling back against the thumb causing the plate bolted to the boom to shear the bolts off. the object will have to be the exact right size to form the perfect hinge point for the shear to happen so it probably will take a while but I bet dollars to donuts it will. the wieght of the rock is irrelivant . and by the way the job IS nice
/ Backhoe thumb
Thank you for the compliment. I think I understand all the forces involved. The failure you are describing sounds more like a tensile load than a shear load. You would have to be prying on an immovable object. Force applied near the end of the jaw would make the thumb bracket try to pivot away from the backhoe at the jaw end of the mounting bracket. The bolts neast the jaw end of the bracket are under the greatest tensile stress, the bolts furthest from the jaw are under the least tensile stress. The bolts should all be sharing the shear stress equally. Quick math says each of those bolts will safely hold 2,600 lbs of shear load and safe tensile load on each of them is around 4500 lbs. The bucket curl motion is the most powerful motion on the backhoe due to the mechanical advantages provide by the geometry of the cylinder , bucket pivot point, and linkage. The bucket can produce 2400 lbs of force at the tip of the bucket. I am not going to do all the math but with 15 years of mechanical engineering experience in heavy industry, my gut feeling is that it will hold up.
/ Backhoe thumb #15
1 redneck with a torch and welder, has takin 1 mod since i built it and that was to add bracing to the tip of the "teeth". I wish that i would have made a way to fold it up but other than that it has picked up rocks that the bh would only lift 6" off the ground, pulled lots of trees out of the ground and only cost me 30 bucks, and a few hours welding.
/ Backhoe thumb #16
I made an even simpler thumb from scrap iron which folds away easily when not used. I am holding quite a heavy stone with it here. :)
/ Backhoe thumb #17
what a coincidence I have 15 years of fixing stuff designed by "engineers" I say this , through bolting box tube isnt a good idea. it just isnt.take a scribe and mark the boom of your hoe and the thumb plate then pick up a rock and look at the marks do they still line up?
Wolverine Quick Attach Mulcher (A66285)
Wolverine Quick...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
Stout Brush Grapple 66-9 (A66285)
Stout Brush...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
PRIEFERT PORTABLE CATTLE SQUEEZE CHUTE (A64277)
PRIEFERT PORTABLE...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T800...
