International Cub Cadet 782 need some deck work
   / International Cub Cadet 782 need some deck work #1
EchoValleyTractors
I just bought a 782 cub from a guy i work with it runs fairly good but it needs some tunning. my biggest problem is the deck he said it has ben worked over once but the main drive pully has came off the deck. i havent had a chance to get a close look at the shaft yet but i would imagine it needs t be replaced along with ever goes with that (bearing, brackets ect.) could someone point me in a direction. Mabey what parts i would need and part numbers.
I dont have any of the paper work. I think i found the part numbers i need in the the pdf you posted thanks. Do you have any recomandations as to where to order them from.
   / International Cub Cadet 782 need some deck work #4
not offhand - mebbe some of the other regular posters here that work with the older IH cubs may have suggestions. OTW, a google search should get you some leads... BTW, dig around in that IHregistry dot com website - you might find an owners manual for that machine... handy to have.
Case 1845C (A47477)
Case 1845C (A47477)
Mini Plate (A53316)
Mini Plate (A53316)
Mini Plate (A53316)
Mini Plate (A53316)
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2002 R/S Body Co Dump Trailer (A47477)
2002 R/S Body Co...
