Is this "Open Centre"?
/ Is this "Open Centre"? #1
Chris_in_Oz
South of Perth, Western Australia
Iseki TU155 Landhope
Hi guys,
I bought a pair of spool valves. Can anyone confirm that they are centre-open? The sketch is on a little plate rivetted on each valve.
Cheers!
/ Is this "Open Centre"? #2
Quick test is blow compressed air thru "in" and see if it comes "out."
/ Is this "Open Centre"? #3
Chris:
Those hydraulic symbols aren't the standard ones I am familiar with, but they appear to show an open center valve. As Barry said, if it is open center you can easily blow air through the valve from the IN port to the OUT port. Indeed, you can do it with your breath since the center passage should be wide open with the spool centered. Or you can hold the valve with the IN port up and the OUT port down and pour a little oil into the IN port. If it is open center it will quickly run out of the OUT port.
/ Is this "Open Centre"? #4
Chris
Watch out ther is now maximum pressure valve .
Be shore wen you mound the valve in a hydraulic system that there is a pressure valve between pump and your valve .
gr Eus:confused:
/ Is this "Open Centre"? #5
Here's a diagram for a two-function, open-center, manually operated directional control valve stack...
It doesn't seem your diagram is of a open center spool.
Not meaning to be a grammar ****, but "centre" is a place where a specified activity takes place. Like the "town centre". "Center" is like "in the middle" or "between two objects". I got that lecture from a well educated Canadian lady friend.
/ Is this "Open Centre"? #6
This is from Wikipedia...
Center or centre (from the Greek κέντρον /kentron/) spelt "center" in American English and "centre" in British English, Canadian English, Australian English, New Zealand English and other Commonwealth varieties.
Both spellings are correct, depending on location! :)
/ Is this "Open Centre"? #7
Right! Wiki claimed a picture I took back in 1991 in Iraq was an M-1 tank that was killed by an Iraqi tank in 2005. (someone else took my picture from on-line and posted it as theirs.) I had the negative to prove the post was wrong. They pulled the picture and post with-in minutes. Don't trust wiki! While they are correct most of the time, they are not exactly in the first place when it comes to facts. Wiki depends on people's submissions and corrections.
That Canadian friend of mine taught English in Vancouver, BC. Then again, people are fallible. We're not perfect, so she could be wrong.
/ Is this "Open Centre"? #9
Your valve looks fine to me. From the diagram it has a 3rd port that you may want to plug on both sides if you are using regular double acting cylinders.
I find the description "open center" a bit hard to understand except that I guess they mean that the supply side is "open" or really "bypassed". The benefit of this design is that it draws the least amount of power from the pump when idle and generates the least heat in the hydraulic circut. It also means that the whole system should run quieter when idle. The system pressure is ultimately determined by the actual load applied, up to the limit set by the pressure regulator. Any time the load requires less force than set by the pressure regulator, system pressure will be less than the limit.
(4) Ratchet Straps (A65583)
(4) Ratchet Straps...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
Woods 1050 3-Pt Backhoe (A66285)
Woods 1050 3-Pt...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A65563)
2012 Mitsubishi...
