Tires Mixed tires. Turfs and R4's?
   / Mixed tires. Turfs and R4's? #1
Muskrat84
Member
Kansas City, Ks
I need new tires for the front of my B2400 and would like to switch from turf tires to R4's. My rears are still in good shape so I do not want to replace them right now. I did find some 23x8.50x12 R4's, which is the exact same size as my front turfs. Does anyone see a problem with getting the front R4's now and then getting new tires and/or wheels when the rears need to be replaced?
Here is a link to the tires..
23x8.50-12 6ply CARLISLE R4 Loader Lug TRAC CHIEF tire by rustybore
Thanks
   / Mixed tires. Turfs and R4's? #2
This was recently discussed at length, it was just the opposite swap... I think if you keep the rolling circumference the same as what was originally there you will be fine... Make sure there is a R4 for the rear that has the same rolling circumference as the existing rear turf...
It takes a while to wear out turf tires, don't wait too long. KennyV
I cant seem to find the thread you are referring to. Does anyone have a link for me?
Is that just a "you can use the tires as tires" or "you can use R4's on the front and still use 4 wheel drive as long as the R4's are the same size as the turfs"?
   / Mixed tires. Turfs and R4's? #6
You can put the R4's on the front and still use 4WD as long as the tires are close to the same size.
2000 Lull Highlander 1044C-54 Series II 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2000 Lull...
JOHN DEERE LOADER BRACKET (A51243)
JOHN DEERE LOADER...
1275 (A50490)
1275 (A50490)
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
John Deere 1560 No Till Drill (A52349)
John Deere 1560 No...
2018 WOOD MAXX TM 86H WOOD CHIPPER (A51243)
2018 WOOD MAXX TM...
