HANGOVER MOWER .
/ HANGOVER MOWER . #2
Have you checked out a flymo hovering lawn mower?
/ HANGOVER MOWER . #3
What about suspending one of those self powered ATV mowers from your frontend loader frame. Or better, yet, mount a LandPride FDR2584 from it. Power with hydraulic supply and motor. (I'm workin' on that one for a field mower SomeDay project).
/ HANGOVER MOWER .
I don't think they will mow out over a ditch.
Getting the needed reach is the challenge.
/ HANGOVER MOWER . #6
There are boom type sickles, but, won't work well in wet grass. To cut the wet grass, either the knife/blade must be very sharp or the blade speed must be high. For the wet grass, the best mower is old classical drum mowers which has a speed of about 2000 rpm. See attached small, 4 ft, drum mower. Requires less than 20 hp.
By the way, contrary to the belief, mowing the wet grass is better than let it grow for the health of grass from biological point of view. But, I don't understand much about biology and this claim is not my claim, just a copy & paste of their thoughts of some biology experts.
/ HANGOVER MOWER . #9
Wisconsinsurplus.com currently has the Woods version of that on auction. Right now it's at $905.00
1995 Model - HS105-3
Woods is a dirty word with me. (at least with mowers) I've owned a few of their mowers and had TERRIBLE luck with them. (Gear box failures/paint shedding in sheets/welds breaking/ect) I still own a Woods rear blade, a box blade, and a pulverizer that have served me well.
/ HANGOVER MOWER . #10
Need a mower I can mow out over wet areas with that does not ride on or run on the ground.
Anybody got any ideas,seen any such thing or built something?
How about these boom mowers from Power-Trac.
/ HANGOVER MOWER . #11
Here is another boom type mower, and I believe it is a flail. can use it in all positions.
/ HANGOVER MOWER . #12
Tiger has lots of side mounted flail mowers and boom flail mower mounted off either the side or rear. I believe they have rotary mowers as well. I'm thinking of a 8' rear flail coupled with a 4' side mounted flail for whenever I get my 30 acre chestnut orchard installed in a couple of years.
/ HANGOVER MOWER . #13
Would a three point or FEL mounted boom pole running to the side with an old gas power push mower hung on it work the the area you want to mow?
/ HANGOVER MOWER .
Yeah about or something like I had in mind; but I've never seen anyone on here or any place else build one.
Anybody here built one ?
/ HANGOVER MOWER . #16
One of the guys in Power-Trac built one , I will see if I can find a picture.
/ HANGOVER MOWER . #17
check on youtube there one on a crane mowing a pond and its a zturn
/ HANGOVER MOWER . #18
Here is a lawn mower mounted on a boom pole.
/ HANGOVER MOWER . #19
Now, that's good. This sparks me an idea of adding electric boom mower drived by tractor electricity. Will be much simpler than pto driven mowers which cause the mowers complicated and expensive.
/ HANGOVER MOWER .
Now, that's good.
This gives me the idea to add an electric boom mower drived by tractor electricity.
Will be much simpler than pto driven mowers which makes those mowers complicated and expensive.
I'm thinking of a combo that could be attached to a 3 point or a fel or operated as a pull behind either rite behind the tractor or off set.
