self contained, passive top link
/ self contained, passive top link #1
ford860
I'm fabricating a rear end loader for a 40 HP tractor. I want to be able to lift and dump the bucket using a self-contained hydraulic top link that I have (dual action; 2" bore; 15" stroke; 21" retracted length). The top link will hold the bucket position when the valve is closed and used to dump the bucket when opened. Resetting the bucket and top-link will be done by lowering the bucket and rolling the tractor forward. The valve will then be closed to hold the bucket position. An example of what I have in mind can be seen about 2/3 of the way through this video:
http://www.jiffyhitchsystems.com/jh_bb.wmv
Essentially, the hydraulic cylinder will function passively (not with active hydraulics) and the pressure, even with the loaded bucket will not be that high as the tractor lift arms will more directly bear the weight. Nonetheless, the cylinder, hoses, valve, etc. will be rated for 2500 psi.
I already have the cylinder (described above), but would appreciate recommendations on the best way to fabricate the other components. I was thinking the the following beginning with the rod end port -> hose -> 2 way ball valve -> hose -> reservoir, with a second hose linking the reservoir to the 2nd port? A pressure relief valve could be in-line between the hose and the 2 way ball valve if needed; but when not in use I'd leave the valve open.
Any thoughts, recommendations, concerns, etc. would be appreciated. If a reservoir is needed, suggestions about what I might use would be most helpful - it won't need to be large.
/ self contained, passive top link #2
Pretty interesting. I think you need a reservoir and a 3-way valve that connects or isolates all three connections. I can't seem to find such a valve online. A T-ported ball valve connects but doesn't seem to isolate. Alternatively 2 normal valves operated in unison with the first one connecting the 2 ends of the cylinder and the second one leadiing from a tee on the base end to the reservoir.
If you connect the cylinder ends and just valve the reservoir it should hold in compression with pressure proportional to the rod area but will cavitate at a tensile load of about 15psi x rod area.
Hope that makes sense.
B
/ self contained, passive top link #3
If you don't need the full range of the cylinder, then just plumbing the ends together and placing a valve inline will work. If you fill the cylinder when it is extended fully, you will not be able to retract the cylinder completely because the retract side has less volume.
While this will work with a cylinder, I'm curious why you don't just build a toplink with a trip function that lets it extend/dump? If you don't need to lock the toplink in various positions or have a controlled extension speed, I think a tripping toplink would work. Of course, cylinders are pretty cheap and you might be able to use a cylinder with less hassle than designing and building a trip mechanism.
Thanks Jinman,
That's the kind of information I'm looking for. To optimize the range, should I fill the rod side of the cylinder when it's fully retracted?
The reason why I'd like to fabricate it this way is to have some control of the speed of the dump, especially if I want to spread the contents of the bucket - not to mention that I already have a cylinder with a 15 in stroke.
/ self contained, passive top link #5
Have you tried that? I don't see how it would behave well. If you fill it solid fully retracted and then seal the system with the valve open, you will have to pull hard enough to form a void to extend it to connect the top link. Where the void forms is indeterminate but some oil must flow into the base end. When the valve is shut and outside force is released any void in the base end will tend to collapse, causing some retraction. The remaining void space in the rod end will allow slop in tension when force is applied.
Again hope that makes sense. If you've done it and I'm full of it let me know.
/ self contained, passive top link #6
The Jiffyhitch systems is similar in concept to the DeltaHook products.
Both products are interesting.
/ self contained, passive top link #7
Brad, I think you may be missing that the retract and extend sides will have a hose connected so the fluid can freely flow between them. By adding a valve in the line, Ford860 can control the point where the cylinder locks.
Ford860, I would not just fill the retract side because you would then have extra air in the system. You must fill the extend side and try to ensure there is nothing but fluid in the lines through the valve. Any air will cause the cylinder to be "spongy." More air will make it worse. I doubt you will see that much loss in retraction by filling the extend side and lines; maybe an inch, but no more.
/ self contained, passive top link #8
I understand that the 2 ends are connected but the total contained working volume of the system will change by the volume of the rod as it enters and leaves the cylinder. Fully extended the working volume equals (cyl area x stroke). Fully retracted the working volume equals ((cyl area x stroke) - (rod area x stroke))
(I say "working volume" to neglect the volume of plumbing and clearances.)
Brad's point makes sense. As the rod moves in an out of the cylinder the total volume within the system may change; moreover, temperature changes will cause expansion and contraction of the two fluids (air & oil) in the cylinder. This is why I asked if it is necessary to have a reservoir; if so, any design suggestions?
/ self contained, passive top link #10
Maybe you could use an old fire extinguisher as an accumulator. Put a schrader fitting in the top so you can preload it with low pressure air (10 psi maybe?). This is the same principle as a house water tank (except they have a bladder). Have a flex hose from the rod end of the cylinder, through your valve to the extinguisher reservoir; vent the other end of the cylinder.
With the air charge the cylinder could have enough force to return the bucket to the upright position by itself.
Extinguishers are cheap, lots of volumes available and it can be mounted anywhere. You will need to consider the volume of oil that has to be stored vs the volume of the reservoir. You may not need any (or very small) head pressure; when the cylinder is extended the accumulator pressure will increase...
I would also install a safety valve to prevent the extinguisher from being over pressurized (say if you filled it to the top with oil). There are isolating valves (shuts off flow) or vent valves to do this and it could be installed anywhere on the low pressure side of your valve. Install a pressure gauge so you can monitor it also (extinguishers come with a gauge that may be good enough).
I have a system like this for oil spraying equipment (undercoating cars).
Regards,
Mike
Thanks Mike,
The more I think this over the more I think that it might be wise to consider active hydraulics, though I have far more questions than answers. Before I ask, please forgive my redirecting the conversation; and, if there's already a thread that will address my questions, please let me know.
Is it as simple as purchasing a $60 adapter plate (w/ seals, etc.), put the top plate back on top of the adapter plate and run hoses from the adapter with an inline single spool valve?
Or, do I need sink $600 to $700 into a valve kit?
Or, is there some in-between solution?
Thanks,
/ self contained, passive top link #12
I don't know much about the 860 by my Ford 2000 ('74) had a cover plate under the seat that would have to be changed to add remove hydraulics. I had found an aftermarket kit but I think it was close to $1000 all in. I thought it better to get a tractor with hydraulics available and ended up buying new:D
I will search and see if I can find the kit, good chance it is compatible with yours. Probably lots of others here that know more about your model and whats available.
Used parts are an option but I am guessing that there are not many donors available with the hydraulic accessory.
/ self contained, passive top link #13
I did a google search for "external hydraulics ford 860" and found this:
"You can buy an original fit valve from New Holland and I think TISCO also sells one. You can get a single or a double spool valve. These bolt on the top of the lift cover. Although you could tap into the blockoff plate on the lift cover it is not the best way to go. If not plumbed right you could cause pump damage. Buy a valve made for the tractor. You will be glad you did. "
Cheers,
Mike
Thanks Mike, I appreciate your trouble.
Ford 860
/ self contained, passive top link #15
I would say that you could easily do this by experimentation. When you get your cylinder and a single hose, prefill the cylinder and see what you need. Just push the cylinder all the way in until it goes to hydraulic lock. Then, open one of the fittings on the hose and let the additional fluid drain into a cup. That will tell you exactly the size of reservoir or accumulator you will need. A small bladder reservoir/accumulator without a precharge of air is what you will need. You want it to not take much pressure to fill it or it might restrict the movement of your cylinder. I don't know where such a thing might be available. Probably any tiny reservoir would work if you can orient it where air does not get drawn into the lines going to the cylinder.
/ self contained, passive top link #16
Don't use any air or oxygen in hydraulic system. VERY EXPLOSIVE!! NITROGEN ONLY in ackumulators.
You need an ackumulator as an reservoir. The volume is the volume of the pistonrod plus 10-20% to compensate for natural leaks over time of use. You have to experiment with precharge of N2. You will need some to keep air out of the system.
I assumed this is your setup up of cylinder, extend when empty bucket.
Use either a ballvalve or a 2/2 spool valve with wire control, remote! Valve have to be on the rod side of the ackumulator.
You also might need a relief valve on the rod side if bucket gets heavy loaded, or when bouncing during moving around. That relief have to drain into capped side of cylinder.
/ self contained, passive top link #18
I'd go with the $100 adapter plate for your top cover rather than the $600 spools. I run this on my 861 (and actually have a set of spools on top of it). The adapter plate gives you ports to plumb into the valves of your choice and run the hydraulic top link or anything else you want. You can get the plate from TISCO - I bought mine through ytmag.com.
-John
/ self contained, passive top link #19
Akkamaan,
Thanks for adding the schematic. The way you have it drawn you only get 115PSI resisting compression. I think both ends need to be isolated from the reservoir.
/ self contained, passive top link #20
Akkamaan,
I cant see a reason to isolate capped side of cylinder......load will be hanging on the rod side pressure....The way I assumed the hook up, extract cylinder when dumping, you need rod sid isolated from accumulator/reservoir.
Brad, Please show the math behind the 115psi resisting pressure! My 100psi suggestion can be igorned, I did suggest trail and error to decide pre-charge pressure
The mechanical leverage design will decide what load pressure there will be on the rod side, together with the unknown rod diameter....bigger rod diameter will give higher rod side pressure.
Active hydraulics will require more hook up procedures and additional hydraulics on tractor....$$$
Better go for a NON HYDRAULIC design....just a locking "hook", controlled by a wire to the cab.....simple, inexpensive and reliable.
2019 CHEVROLET SILVERADO 2500HD (A65643)
2019 CHEVROLET...
2025 Deere 320P (A64126)
2025 Deere 320P...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
John Deere 4840 Tractor (A66285)
John Deere 4840...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
