2520-62D belt came off
   / 2520-62D belt came off #1
47chevy
john deere 2520
I was mowing today and the blades quit. The belt came off :mad:.
When I mow I run the engine at 2000-2100 rpm. Should I set the rpm to the 540 that is indicated on the tach?
Here is a couple of pictures, first is what I was mowing, second and third the deck, is there too much grass on the deck? The lawn was about 6-8" and damp. After I get done mowing I generally use the air compressor to blow all of the grass off. I installed the belt, finished mowing everything was ok.
   / 2520-62D belt came off #2
47chevy - My wife was mowing yesterday and the belt on our 62D ripped right in half and was jambed in the pulleys. The grass she was mowing was about 8" - 12" of grass but she had the deck up as high as it could be and running in low. So I would say, she was cutting about 5-6 inches of grass. We usually run ours at 2400 RPMs. I wonder if cutting too much grass puts a strain on the belt??
   / 2520-62D belt came off #3
Mowing very thick or tall grass can cause the belt to slip, but I don't think it would cause it snap. Sounds like it was just a fluke with the belt coming off. If it keeps happening repeatedly than I would start to wonder.
   / 2520-62D belt came off #4
Yes, you should run at the proper PTO RPM, when the rear is at 540-then the front is at 2100 which is what the deck is designed to run at for proper blade tip speed and a quality cut.
   / 2520-62D belt came off #5
Especially important when mowing in tall, heavy and wet grass conditions. Those are ALL factors that can put a strain on the working components of your deck system.
AKfish
2015 Ford Escape SUV (A55758)
2015 Ford Escape...
KMC 5610 (A53084)
KMC 5610 (A53084)
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2012 John Deere 7230R (A55302)
2012 John Deere...
66'' root grapple (A53421)
66'' root grapple...
