Revolvers
   / Revolvers #21
Both are excellent guns, and will outlast you.
The Smith tends to have crisper triggers, the Rugers tend to have a longer trigger pull but are built like a tank.
I used to have a 6" 686, swapped it for a 4", I liked the balance better.
And for the doubters, with a good holster, the 686 can easily be carried concealed.
I also think Ruger has improved the factory smoothness of their triggers. I have a current SuperRedhawk and the facotry trigger is smoother than the one I had a dozen years ago.
   / Revolvers #22
I have and love the Red Hawk Double action is the way to go. I only purchased it in 1986 and used it in minor compitition in german shooting houses and with local friends so their is a fair amount of amount expended. NEVER a problem it has also been stored for a couple of years during deployments Never a rust spot or anything. JUST love it.
Ruger HooAh!
   / Revolvers #23
There is a spring kit for Ruger, quite few people swear by - I didn't have a chance to buy them yet.
   / Revolvers #24
A spring kit may change the trigger pull, but better polished surfaces make a smoother trigger. That's the change I've noticed.
However, my observation is just on two guns. I don't know if it is generally representative of something Ruger has done, or just luck of the draw.
   / Revolvers #25
I have a Shoulder rig the wife bought me from cabellas for Me to wear when i,m at the far end of Our property on the tractor for critters ( coyotes ) or the ocasional trespassing target shooter on the surounding Propertys . Allthough its a fairlly heavy gun, its comfortable to wear & I sometimes forget i have it on .
Theres been several times i,ve had bullets zing by or here ricochets by someone that wasn,t aware i was out there when i,m down by the river . So now when i here a shot i,ll just fire one into the ground as a warning that someone is there . I dont care to catch a wild bullet :eek: .
Its Happened far to many times the last few years out here . Most times My shot is the last one I here , meaning to me they knew they weren,t suposed to be there . :D . Bob
   / Revolvers #26
You need to do the polish work with the spring kit to make them truely fantastic.
   / Revolvers #27
On a 10/22, I did that. Target springs... What I wound up with, was a lighter, poor trigger:eek:. Still took it to a gunsmith to have the trigger touched up.
It is the contacting surfaces of the trigger components that need polishing, and sometimes minor shaping/adjusting. That is what will affect how the trigger releases. The springs just affect how much pull is needed, ie 3lbs vs factory 9lbs.
My old Blackhawk, I bought target springs, then had the gunsmith install them, tune the trigger, and check the timing on the cylinder ect. HUGE difference. Once that was done, it was a really nice shooting accurate weapon. My issue, is I expect that out of the box... The trigger and tune should be good, even with the heavy Lawyer trigger pull weights they have now days.
   / Revolvers
Right or wrong, I finally found a revolver that I liked -- I am ashamed to say -- because of the price. $420 for a Ruger LCR .38 Special + P. The 38's are cheaper to shoot and easier to find in the stores than the .357's are. Now if I can hit something with it is another story.
   / Revolvers #29
nothing wrong with that.
good luck with it and I'll look forward to a range report on it
   / Revolvers #30
Ah, the 38's shoot just fine in a .357. You can shoot both, that's why the .357 is an obvious choice.
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2015 FREIGHTLINER...
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
2012 KENWORTH T8 DAY CAB (A54607)
2012 KENWORTH T8...
