Bucket Capacity?
/ Bucket Capacity? #1
Brokermike
Shaftsbury VT
Mahindra 2555, Ford 4610, New Holland T4040
I have a DK 40 Se with the standard 72" bucket and a toothbar. The toothbar lets you really heap the bucket but I was wondering if anyone had a rough idea how much the bucket holds both with and without a toothbar in relation to yards of material (1/4, 1/3, or 1/2, etc). I really have no sense of these things but after having "3 yards" of mulch delivered, either I got shorted or I have way underestimated what a yard actually is.
Thoughts?
/ Bucket Capacity? #2
A standard 8' pickup bed filled level full in right at 3 cu yds just to give you an idea. With a toothbar you can really heap the mulch on. I would say you could probabally get 3/4 of a yard on a 6ft bucket easy enough.
How Many bucket scoops did you get.
/ Bucket Capacity? #3
Something else you could do if you have a 5 gal bucket. Scoop a load of mulch and see how many times you can fill the 5 gal bucket. Their are about 40 buckets to a yard.
/ Bucket Capacity? #4
I got two yards of mulch in my truck (full size 8ft. bed) a month or so ago, and it was pretty full. A third would probably have been spilling over the sides, and a few ft above the bedsides.
/ Bucket Capacity? #5
You probabally got a little more than 2 yards then.
A typical P/U 8 foot bed, 5 1/2 ft width, 21" deep.
= 77 cu ft which is about 2.85 yards. Not quite 3, but close.
When I posted earlier I was using 6ft for the width, but your post prompted me to take a measurement. So I stand slightly corrected, but still very close to 3.
BTW a short bed with 6.5 box 5.5 width and 21" deep will hold 2.3 yards.
/ Bucket Capacity? #6
Gotcha, I guess I got a good deal then. They don't measure very precisely when you get a load of mulch. They just gave me two scoops with a 1 yard bucket on a skid steer.
/ Bucket Capacity? #7
Pretty easy to calculate. Take the dimensions of your bucket in inches. Multiply the 3 dimensions together and then divide by 46656 (cu. inches in a yard). Now image the toothbar just extends the bucket out into a rectangle and repeat the calculation for those dimensions.
/ Bucket Capacity? #8
That is actually easier said than done. There are quite a few more than 3 dimensions to take into acount due to the bucket not being a perfect rectangle. Most buckets have various contour angles or they are rounded. Not to mention the average scoop of mulch is a heaped load.
/ Bucket Capacity? #9
Seems pretty easy to me.... unless you need to know to +/- a few cubic inches. The amount that the bucket is short of a rectangle is pretty much compensated for by heaping.... on average anyway. How accurate does one need to be given that it's going to vary from bucket full to bucket full?
/ Bucket Capacity? #10
How many gallons of water will it hold?.....
larry
/ Bucket Capacity?
Ummmmm............. Rick somebody.... I figured this was an easy question. Such as "Oh they come standard with a 1/2 yd bucket"
Any dealers car to opine?
/ Bucket Capacity? #12
If you really need to be precise. Your bucket can be devided into two volumes: a triangular volume and rectanglar one. The volume of the triangle will be B x H x L/2. The volume of the remaining rectangle will be H x D x L. The add them together.
Post the dimensions of your bucket (with and without the toothbar) and I'll do it for you. I couldn't find them on Kioti's website.
/ Bucket Capacity? #13
I too would like to see some measurements of the bucket and we can figure out ho many cu ft it'll hold.
Just for refrence I looked at my loader book and my 60" bucket capacity is 8.1 cu ft struck and 9.9 cu ft heaped.
So at about 2 cu ft per foot of bucket I'd guess your's at about 12 w/o the tooth bar. With the tooth bar I'd say you can easially scoop 1/2 yd which is 13.5 cu ft.
/ Bucket Capacity? #14
Don't forget that by time you got home your 3 yard load of heaping mulch had probably settled down to 2 yards from the vibration of the truck on the road. Until you shoveled it off the truck and fluffed it back up to 3 yards again. :eek:
Steve
/ Bucket Capacity? #15
I'm actually kind of surprised Kioti doesn't list bucket volumes on their site.
I'm going to guess it holds about 1/2 yard flat loaded, more heaped.
this is based on my 9 Cu Ft "easy dump" (tapered side) 72" bucket and my 14 Cu Ft "straight sided" 72" bucket.
/ Bucket Capacity? #16
For what its worth...I have a six cubit foot capacity wheelbarrow. With only a modicum of spillage, I can empty three wheelbarrow loads of manure into my 72inch Kioti bucket. This is pretty imprecise, but from it I'd say the one-half (plus) yard volume is a fair estimate for a six-footer without a toothbar.
BOB
/ Bucket Capacity? #17
It is listed if you click on the "Brochure" button for most models, but not for the DK40SE.
/ Bucket Capacity? #18
I still think it is a 12 cu ft bucket.
They do list the volume for the 66" bucket on the kl351 @ .31 cu meters, which is about 11 cu ft.
11/5.5= about 2 cu ft per ft of bucket
2 x 6 = 12 cu ft
That is if it is about the same depth as the kl351, which it probabally is, it is just a little wider
/ Bucket Capacity? #19
Since this was driving me nuts and I had nothing better to do...I called a kioti dealer.
He confirmed that the kl351 66" bucket is identical to the kl401 72" bucket it is just 6" wider. So that would make your bucket a 12 cu ft on the money.
/ Bucket Capacity?
Sweet so with a toothbar it safely holds .06yrds more than .44 yards making it 1/2 yard bucket
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
100 Gallon Plastic Tank (A65640)
100 Gallon Plastic...
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
2007 Chevy Suburban (A62679)
2007 Chevy...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
