Grease Gun Question:
/ Grease Gun Question: #1
FRIZ
NW Indiana
John Deere 4720 Cab
I am getting ready to order my JD4720. One of the accessories` I wanted to get is a grease gun. But I know nothing about grease guns.
So please educate me:
What is the best quality grease gun which is also easy to use?
Where can I get the grease gun you recommend for the best price?
Thank you for sharing your insights.
Regards,
FRIZ
/ Grease Gun Question: #2
Recently in the Oil, Fuel, and Lubricants section, there was a very good thread about grease gun purchases. Here is a link to the thread if you care to take a look: http://www.tractorbynet.com/forums/oil-fuel-lubricants/145115-grease-gun.html
Here is a copy of the post I made in that thread:
Last year I bought a pistol type grease gun from Advance Auto on wim. It turned out to be a piece of crap because it was always loosing it's prime and I would have to unscrew the grease canister to get it to prime again. Never had this problem with my NAPA lever grease gun. A few weeks ago I bought a Lincoln 1134 off Amazon for $31 w/ free shipping. Took about a week to get here and they still have them for that price if your interested. I could tell right away when I was using the Lincoln that it is a much, much better built gun and so far I have been very pleased with it.
/ Grease Gun Question: #3
If the 4720 is anything like the 4320 I own (and I think it is) there are very few grease fittings on the tractor. Mine is only a little more than a year old but all the grease fittings I've found is on the 3ph. However, you'll need to grease lots of other accessories and equipment -- especially front end loader and backhoe.
I know from experience that Craftsman (Sears) and Lincoln both have very good grease guns. Prices on ebay are usually pretty good.
You might consider a cordless battery operated gun. My youngest gave me one for Christmas last year and I only wish I had it years ago.
/ Grease Gun Question: #4
Your dealer sells some JD branded ones also that are very good IMHO. I have the pistol grip style and love it.
/ Grease Gun Question: #5
Regards,
FRIZ
In my opinion, pistol grip Lincoln 1134. As stated above the link is good information. It helped steer me to the Lincoln.
/ Grease Gun Question: #8
Regards,
FRIZ
If you have or will get a trailer - on which you will use this "Dream" grease gun.
I suggest that you DO NOT get a high pressure one that can put out a lot of volume quickly.
i.e. do not buy on specs, in particular do not select the gun that puts out the most volume at the highest pressure.
It is one of my beliefs that a "regular" el cheapo discount store grease gun cannot put out enough pressure and volume to blow the seals out of trailer wheel bearings.
On the other hand a compressed air powered gun can pump grease into E-Z lube axles faster than it can flow through the bearings and out the front - so it blows out the back seal and "finds" the brakes.
For the various fittings on the loader a swivel grease connector can sometimes be the ONLY way to get at those.
PTO shaft grease fittings are another thing that can be awkward with only a straight on connector.
IMO, YMMV, etc.
/ Grease Gun Question: #10
Regards,
FRIZ
I went with a pistol grip John Deere one and a case of their "general" all around good grease. I would need to go grab a tube to get the type.
D.
/ Grease Gun Question: #11
Except when you add shipping into the total it then now becomes $35. Amazon will give you the gun for $31 w/ free shipping.
thats a good deal right?
/ Grease Gun Question: #12
Check out what your dealer has to offer. You get to put your hands on it and I bet the pricing is very comparable. I like the John Deere pistol grip grease gun. As a matter of fact, I just picked up another one of them.
D.
/ Grease Gun Question: #13
That's a very good deal, and the best deal I've found. For example, Northern Tool sells it for $44.99 + $7.99 for shipping, your looking at over $50 there. I think you'd be pretty hard pressed to fine a grease gun of that high quality for that good of a price anywhere else. I used mine for the first time last Monday to grease all the points on my RFM, as well as the loader, and it never lost it's prime from the last time I used it.
/ Grease Gun Question: #14
Who sells the grease needles? I need one for the front driveshaft on my Dodge truck.
D.
/ Grease Gun Question: #15
D.
Any bearing shop. Just get a good one!!1 the cheap one i bought (at PAuto canadas harbour freight), the needle pulled right out of the place where the grease coupler connects. It could have been bad of it shot off under pressure!
/ Grease Gun Question: #16
I just found one on Amazon - a lincoln $10 shipped.
Thanks,
D.
/ Grease Gun Question: #17
D.
I bought one at Advance Auto. There are two types you can get, one that's thin but still slightly larger than a medical needle, and one that is about the size of a straw w/ a cone tip. With the thin needle you actually insert it into the eyelet on the U-joint, and with the cone it's intended to be pressed up against the eyelet and held there while you pump. After thinking about it, I figured that the thin needle that inserts into the eyelet would be the best option and the least hassle. The only pain is that it is hard as anything to get the needle out of the end of the hose unless you have a loose coupler. Make sure you don't stick yourself with the needle either, that wouldn't be fun.
Lot of 4 10-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
Skid Steer Leveling Plane (A64047)
Skid Steer...
CASE INTERNATIONAL 893 - 6R36" CORN HEAD (A63291)
CASE INTERNATIONAL...
