Gravely 2 Wheel Tractor for PT 422 Owner
   / Gravely 2 Wheel Tractor for PT 422 Owner #11
I had never seen a rotary plow for a walk behind. That must be like a pig rooting around in the dirt. Wow!
All the best,
Peter
   / Gravely 2 Wheel Tractor for PT 422 Owner #12
I had the rotary plow. It is a real beast to handle when tilling undisturbed soil! Once the soil is initially plowed subsequent use is much easier.
The plow throws dirt and rocks and is, in my opinion, inherently dangerous--as are some of the other Gravely inplements.
Is it too dangerous? Don't want my daughter's husband or me hurt.
   / Gravely 2 Wheel Tractor for PT 422 Owner #14
I don't really know how to answer your question. All I can say is that at this point of my life I wouldn't chose to use one.
Anybody else have comments on safety. This is the most negative thing so far. I had not really thought that there was anymore danger than a regular mower. Bob999, can you elaborate on what's so dangerous.
   / Gravely 2 Wheel Tractor for PT 422 Owner #16
I'll give my perspective. I currently own 4 two wheel gravelys and have grown up around and with them since I was 6, so about 49 years of exposure. My family has used them in our nursery both on site and in commercial landscaping use.
Most of the tractors and implements I have were built before the current safety rules for shielding and motor cutout when the operator is not in the "drivers seat". So you can get into trouble if your not safety conscious. I don't crawl under my CUT tiller to pull out vines when its operating either.
Gravelys have a lot of power and since your discussing the rotary plow, getting a root or vine caught in the blades or hitting a rock can cause some hurt. IF the safety clutch is set up too tight. With the older attachments, each attachment has it's own clutch and I find that the operator needs to set this up for his own conditions. Under the situation described, the tractor will pivot around its tires causing the handles to hit your hips or where your going to generate offspring. Any two wheeled tractor is going to transmit sideway force from an implement hit to the operator. Using the snowplow or one of the many mowers will do the same.
The rotary mower also can do a good job of throwing objects far and wide unless it has a chain guard on the front, or the ill conceived one piece deck that is closed off in the front. My Woods M5 CUT deck also throws out objects far and wide on the side where it is missing it's chain guard about the same distance.
To me the Gravely and the PT series are completely different animals. For the same tasks, the Gravely allows you to get into places that you can't with the PT. In our operation, the PT is useless as the larger work is covered by my Ford 1710, while the Gravelys cover the HD work that homeowner equipment just can't deal with effectively.
Bottom line I don't think the gravely is any more dangerous then one of my chainsaws or chipper. But to me safety is in how you handle tools and know their potentials.
Edit - forgot to add. Plus you can throw your driveway snow onto the PITA neighbors.
JFS, thanks for the input. This is very helpful.
   / Gravely 2 Wheel Tractor for PT 422 Owner #18
My comment was directed to the rotary plow. On hard ground the machine will bounce and twist and could be ripped from the operators hands. The unit I had, manufactured in the mid 80s, had no dead man switch. Additionally the plow will throw rocks. There is a small shield but it doesn't prevent all rock throwing. I generally agree with the comments posted by the JFS2295. However, I believe that even a safety conscious user can get into trouble.
   / Gravely 2 Wheel Tractor for PT 422 Owner #19
Now he has a house and almost an acre. He wants to have a garden.
If gardening is what he wants to do, I would invest in a good rear tine tiller with counter rotating tines, a couple of good garden hoes with different blades, a 5 gallon bucket, a sturdy metal cup, a hand trowel and a book by Mel Bartholomew titled Square Foot Gardening. ;)
Welcome To My Garden! | Square Foot Gardening
2005 CHANDLER 500 BBL FRAC TANK (A58216)
2005 CHANDLER 500...
CAT930K (A58216)
CAT930K (A58216)
(2) ROW AULTIVATOR (A58375)
(2) ROW AULTIVATOR...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
UNUSED FUTURE GR87-87" HYD GRADER BLADE (A58376)
UNUSED FUTURE...
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A56858)
2022 Chevrolet...
