Bobcat CT 440 & Chippers
/ Bobcat CT 440 & Chippers #1
SteamDriver08
Spanaway, WA
Bobcat CT440
Wow what a great new toy! My wife and I pulled home our brand new 440 last night behind our archaic 85 F250. The tractor looked like it could smash the truck, we actually ended up being 2 Ft to long for the trailer. The dealer had only provided us with the base tractor specs/ dimensions. So when the actual unit showed up with the 9TL FEL on front it was way to long. We drove home with the loader in the air sticking out over the front of the trailer and swinging over the bed of the truck!
Anyway I logged on here today because my plan was to run this tractor with the Bearcat 8" PTO chipper. I did not even know about the operator presence function until I picked it up. Of course it meets our needs in every other way (after hours of research)- so we didn't want to cancel and go find another tractor. Our family runs 120 acres mostly covered in trees. The PTO chipper along with the snow plow and box scraper will be putting the most hrs on this new ride. I do not want to cut the wires and void the warranty. Does anyone out there know how to keep this tractor running short of leaving a sand bag on the seat for the operator presence switch, when dismounted? I also wanted to run a hydraulic jack hammer off of the rear hydraulics, but cannot do that without figuring out how to bypass the operator presence switch. -Hydraulicaly powered log splitters (3pt) won't work because of the operator presence switch as well, unless you can talk your wife into sitting on the seat and reading a book while you throw logs into the splitter all afternoon:D.....
I guess I should mention yes we did try and set the parking break, with the loader down flat on the ground, still the thing shut down every time I tried to climb off. Anyone else out there have this problem with their Bobcat tractor? This will be soooo nice graduating from my dads ancient Ford 8N to a much more modern Hydrostatic 4x4, mans toy with stronger, newer attachments.
/ Bobcat CT 440 & Chippers #3
what does the CT 440 run in the great state of washington?
/ Bobcat CT 440 & Chippers #5
Steamdriver 08
I went out and checked a CT225 as it was the only thing i have on the lot right now. I was able to set the Parking brake and engage the PTO and get off of the tractor and everything kept running. If the Brake was unlocked, the machine shut down after about 2 seconds. You should be able to keep the chipper running. I would check with the dealer and have someone come take a look at it. Hope this helped.
/ Bobcat CT 440 & Chippers #7
Does anyone here know the lift capacity of the loader on the ct440? I'm wondering how it compares to a DK40se hst and having a bit of a problem navigating the website..
/ Bobcat CT 440 & Chippers #8
The lift cap on the CT440 is 2600lbs at the bucket pivot with rear ballast
UNUSED CFG INDUSTRIAL QK18R MINI EXCAVATOR (A62130)
UNUSED CFG...
(24) Ratchet Tie Down with Toolbox (A61166)
(24) Ratchet Tie...
UNUSED WOLVERINE SP-15-84W 84" SNOW PUSHER (A62131)
UNUSED WOLVERINE...
2018 Trail King Lowboy (A63118)
2018 Trail King...
2015 Kubota RTVX1100C (A62177)
2015 Kubota...
1999 Chevrolet Step Van Food Truck (A61568)
1999 Chevrolet...
