BOBCAT 753 WONT BACK UP ON LEFT SIDE
   / BOBCAT 753 WONT BACK UP ON LEFT SIDE #1
HOPPY
MY BOBCAT 753 HAS BEEN MOVING SLOWER LATLEY ON THE L/H DRIVE & NOW IT LOST THE ABILITY TO GO INTO REVERSE ON ONLY THE L/H SIDE. ANY HELP WITH DIAG WOULD BE GREAT. ALSO WOULD ANYONE HAVE A REPAIR MANUAL THAT THAY WOULD LIKE TO SALE?
   / BOBCAT 753 WONT BACK UP ON LEFT SIDE #2
You would probably get more attention if you post in "Construction Equipment" area on this forum.
If I were you I would go to "skidsteerforums.com" and look for member "Tazza" he is really good with the older Bobcats.
Good luck.....
   / BOBCAT 753 WONT BACK UP ON LEFT SIDE #3
The easiest test is to swap the wheel drive motors from side to side. If the prble stays in the same side its in the hydrostatic drive, and if it move across the machine its in the wheel motor.
Alot of nfo is at www.skidsteerforum.com
(note no s at end of word forum as previously posted)
Ken
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2003 Volvo S60 Sedan (A50860)
2003 Volvo S60...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A51039)
Ditch Witch 6510A...
2007 Mack CTP713 Granite T/A Roll Off Truck (A48081)
2007 Mack CTP713...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
