cleaning trans
/ cleaning trans #1
mayer2323
Member
Just got my tractor out of gear it was stuck . He told me I should drain the trans and fill with gas lit sit 15 min. then drain and pressure wash and refill. Is there a better method or product to use I am kind of leary of the gas thinking it might be bad for the seals. Its a ford 841
/ cleaning trans #2
You haven't given enough details to give a good comment. I have had tractors with water in the trans/hydraulic. I prefer to drain and fill with clean fluid , repeat, until no signs of water.
/ cleaning trans #3
Filling with GAS? I hope you mean diesel or kerosene, not gas. Shudder.
/ cleaning trans
no he said gas it got stuck in grear He had to remove the cover and pry the bars unti it poped out .Its a mech, trans 1958 ford 841. I think kero is the way to go
/ cleaning trans #5
I need to be clear here. I know nothing about your particular tractor. Gas, however, I've had direct, scary experience with when I was young and foolish. No lasting damage, fortunately, but I have a healthy respect for gas.
I would never use it for such a purpose, just too dangerous.
/ cleaning trans #6
I would not use gas and I sure in the heck wouldn't pressure wash it unless you plan on completely disassembling it to get the water out. A little more info on what you are working on would help.
/ cleaning trans
On this tractor there is a cover plate that holds the the gear shift an starter button you remove that and it exposes the trans. It has a drain plug on the bottom to change fluid with cover removed you can see all the gears and rods want to clean it out.
/ cleaning trans #8
I'd flush with diesel.. but not gas.. but more importantly.. i'd find out why you were able to get it stuck into 2 gears.
usually means shifter nub is worn.. or shifter pattern.. or detents. etc.
post back.
soundguy
/ cleaning trans #9
assuming its a gear trans,never heard of using gas to flush trans,but thats probably not what he's saying,probably wants to soak it to clean Gunk off/out.
How about desil fuel,that might do it and would be less dangourous? wouldn't stick a pressure washer hose in it.
Maybe,fill it up with desil and let it set over night,drain.fill with cheap oil[probably ain't such a thing but],run for an hour or so,drain,and than fill with proper fluid[whatever that might be],
Don't think desil will hurt any seals,but not sure about that 100 percent,
/ cleaning trans #10
841 has a plain jane 4 spd gear tranny.
I wouldn't 'overfill' with diesel and let set.. it's input shaft seal will likely leak anyway.
just dump in some kero or diesel, agitate.. drain. and refill... if it was a lil wet.. add transtune seafoam and that should grab most of it onthe next change.
the wet oil ain't the biggest problem here.. the being stuck in 2 gears is!
soundguy
/ cleaning trans
Just bought some seafoam . going to try that. Should I leave it in all summer then change out in the fall. Just put in new hyd oil before it got stuck.
/ cleaning trans #12
seafoam can be added and left in.. it will grab water in soloution and hold it till draining.
soundguy
Unused 2026 CID SNLB84-S 84in. Snow/Ice Skid Steer Bucket Attachment (A66734)
Unused 2026 CID...
2026 SG45 Hydraulic Stump Grinder Skid Steer Attachment (A66734)
2026 SG45...
2009 POLAR TANK . (A67714)
2009 POLAR TANK ...
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A66736)
2016 Chevrolet...
2014 FREIGHTLINER CASCADIA (A67714)
2014 FREIGHTLINER...
