425 Problem
/ 425 Problem #1
pajoube
Montana (Near Bozeman)
Former Owner PowerTrac 425 (September 2003)
Had a problem with carburetor float sticking so ordered a carb kit and had the local Koehler dealer install the kit.
Went to mow and found I was unable to get full power when under load. All else seems ok but rpm's seem little low. In checking the manual there is no adjustments for this carb. I did adjust the throttle linkage but that did not seem to help.
Did mow today but still not at full rpm's when under load so mower is sluggish and going up incline very slow.
Not sure what to check any more, any suggestions?
PJ
/ 425 Problem #2
Hi Paul. Are there any governor settings that could have gotten put back incorrectly? As I recall, some engines have several places where the governor can attach. Might be worth looking in to.
/ 425 Problem
Only two rods and one spring to detach when taking the cab off and only one hole for each. With my knowledge of engines I elected to have shop install the carb kit so would assume they did so correctly. Putting bak on was easy and assume was correct with so little to attach.
When the float stuck I had fuel in the oil, muffler, and every where else. Checked today to see if I could smell any fuel but did not.
When starting to mow and oil is cool it seems to run better but when it gets hot it starts to get sluggish, that could also be part of the problem. All this started when carb float stuck.
When working 425 without PTO it works very well with power to spare.
PJ
/ 425 Problem #4
I've got the service manual for your engine. In the troubleshooting area for the fuel system and governor it lists condition 3. as "Engine runs lean(indicated by misfiring, loss of speed and power, governor hunting or excessinve throttle opening)." Does that sound correct?
/ 425 Problem #5
Pull the plugs immediately after operating under load and look at their condition. If the engine is running too lean, which it sounds like may be the case, the plug(s) should show it.
If it is too lean, take it back and stand over them while they fix it. Having a death grip on large, hard object while sporting a purple complexion helps immensely. :p
/ 425 Problem #6
PK
Hi Paul, Is your home above 6000 ft? If so, there is a high altitude jet kit available. On the fixed jet carb. Kohler, says the low speed jet is set at the factory, and normally do not need any further adjustment. If you have to install the high altitude jet, and it still does not work correctly, I would go back to the adjustable jet, new float needle and seat. and tune according. If you have the fuel cut off solenoid, be sure it is throughly cleaned. Just a little bit of crud will keep the engine from operating properly.
/ 425 Problem
David,
All sounds correct except for misfiring.
PJ
/ 425 Problem
J.J.
We are at 4700 feet.
I have the fuel cut off solenoid that has never been taken off or opened up.
When mowing yesterday I filled up the tank which lasts for one mowing plus a little extra. I ran out of gas when just finishing. Used more than normal.
PJ
/ 425 Problem
I took out the plugs and cleaned. When finished mowing I looked at them and they seemed to be still in good order.
PJ
/ 425 Problem #10
J.J.
PJ
PJ, If you pull the choke out a little does it make any difference? I have used the 20, 22, 25 HP Kohler's, on my Dixie Choppers, and keeping the fuel solenoid clean, and water in fuel was about my only problem. Recommend you take it out and clean it . Maybe the service guy did it for you .
/ 425 Problem #11
David,
PJ
The solutions for that condition are
A. Low idle fuel mixture is improperlyu adjusted. Adjust low idle fuel needle.
B. Float level is stuck too low. Separate carburetor air horn from carburetor body, adjust float per steps 4 and 5 on page 5.6.
C. Ilde holes plugged; dirt in fuel delivery channels. Remove low idle fuel adjusting needle. Clean main fuel jet and oil passages; blow out with compressed air.
On your carb, there is no adjustment for the main jet. There are two adjustements. 1. the low idle speed adjust and 2. the low idle adjusting needle.
To adjust the carburetor idle speed, with the engine stopped, turn the low idle adjusting needle in (clockwise) until it bottoms lightly. Do not force it in as it is easily damaged. Now turn the adjusting needle out (counterclockwise) 1-1/2 turns.
Start the engine and run at half-throttle for 5-10 minutes to warm up. Check that the throttle and choke plates can fully open.
Place the throttle control into the idle position, turn the low idle speed adjusting screw in or out to obtain a low idle speed of 1200 RPM +-75RPM.
Turn the low idle fuel adjusting needle in slowly until engine speed decrease and then back out approximately 3/4 turn to obtain the best low speed performance.
Recheck the idle speed using a tach.
As for the float, I would check that, too. There is a long procedure for that. I can scan it in and send it to you if you like. :)
/ 425 Problem #12
Possibilities...
Wrong carb kit.
Tech did not install it correctly.
Governor linkage reinstalled wrong or bent.
Air leak between carb and manifold
Air leak between manifold and head.
Blockage in exhaust. (Did he remove the muffler? Your symptoms fit this case rather well.)
BTW, the service manual is on the Kohler web site in PDF format.
/ 425 Problem #13
Possibilities...
Wrong carb kit.
I think he has a CH25. I cannot find the manual on line for that. That's why I bought one from my small engine shop here in town. :confused:
/ 425 Problem
I took the carb off and brought to the service guy. It was only two bolts and three rods to take off (one side only). I also put in a new fuel filter and changed out the oil filter and filter for the hydraulic system.
I will check on the choke tomorrow.
PJ
/ 425 Problem #15
PJ. I was just thinking, were there any options for ordering the carb kit? I know it would be a pain , but if you get the chance check the number on the fixed jet, if the service gave you back the old parts. You might check the number from the old jet also to see if it is the same. Maybe even switch back to the old jet. You are definitely at a higher altitude than I .
/ 425 Problem #16
You bought one? You could have downloaded one for nothing.
:D
Technically, I believe it is a CH-730 variant. The service manual is available here. :)
/ 425 Problem #17
:D
When I received my PT425 back in 2001 the service manual was not available on line. Only an operator's (or owners, I don't have it in front of me) was on line. So I bought three books at the small engine shop.
That link you sent me has some differences to the manual I have. Mine has nothing about fuel injection or emissions compliant motors. It also has better pictures than mine in some locations, like the spring hook up on the governor, for instance. I will download it at home and keep a copy on the PC just for reference. Thanks. :)
/ 425 Problem #19
I tried to open file but unable.
PJ
The first time I tried the link it failed. When I tried it again it connected and the file downloaded successfully.
/ 425 Problem
Went on to the Kohler web site and clicked on problems and got connected to expert who gave this advice.
This is where you have to decide if the problem is in the engine or the transaxle. If the engine rpm stays pretty much constant, then I'd look at the motion belt system first. If the engine bogs down hard, like it's struggling to pull, then I'd look at the braking system first. If the engine loses a few rpm but doesn't seem to be straining, then I'd go to the transaxle. If the engine sounds loose, like it wants to over-rev or blows black smoke then pull the spark plugs and check their condition. If the engine just sounds weak, you may have a fuel delivery problem.
Personally, just from what you have described so far, you may have a transaxle that's not cooling. Check that the fan is in one piece and that the transaxle is clean. That fan is essential for the Hydrostat to work and grass built up on the unit can also allow too much heat to build-up which thins the oil in the transaxle.
Thought I would pass this info along for your input as well.
PJ
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2006 Freightliner M2 112 T/A Wet Kit Day Cab Truck Tractor (A66736)
2006 Freightliner...
Unused 2023 Hustler LX890 235 Gallon Sprayer Tractor Attachment (A66734)
Unused 2023...
2014 JCB 190T SKID STEER (A65056)
2014 JCB 190T SKID...
Unused 2021 IDeal RC6MD 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 IDeal...
