Grading Blade positioning
/ Blade positioning #1
djshadowz8801
hello everyone....my dad has a powertrac with a 48 inch mowerblade...he had to replace the blades on it and he didnt take note of the positioning on it..is there a certain way the blades should be positioned? i'd appreciate the help
/ Blade positioning #2
Welcome to TBN, and the Power-Trac forum.
Cutting edge is always on the bottom.
/ Blade positioning #4
If you are referring to postions relative to each other, it doesn't matter whatsoever. Just make sure they are right side up, as JJ said.
/ Blade positioning
thank you very much for all your help more than likely i'll be back when he wants me to find something out about his power trac
/ Blade positioning #6
I might also suggest a little dab of bathroom calk on the bolts, and new hardened washers as well...
None of that is needed on a 48" finish mower. Mine has over 300 hours on it. Nothing has come loose that didn't actually break. :p
/ Blade positioning #8
Same for me. But on a related topic....how many times can you sharpen the blades?? I'm guessing as long as you can maintain balance you are good to go? If I were to replace the blades would mulching type blades work? I rarely get windrows after cutting unless I waited too long to cut the grass....but I would love to be able to mulch the grass a bit finer to cut down on what my puppies track into the house.
/ Blade positioning #9
Don't mulching blades require a baffle to keep the grass trapped under the deck while it is being sliced and diced? I installed a mulching kit on my lawn tractor. It included a baffle.
/ Blade positioning #10
Mulching blades can be used as a direct replacement for regular blades. Mulching blades combined with a mulching kit where available (baffles, etc) will generally give better mulching results than use of mulching blades alone.
However, the PT mower design (at least the one I have) is "rear discharge" which means a heavy rubber sheet on the rear of the mower and there is no mulching kit available from PT.
/ Blade positioning #11
The PT mower blades are a stock replacement item for another brand, at least on the 48" finish mower. I forget the brand name at the moment. The blades are available from several lawn equipment supply houses. A little digging should reveal the mulching blades for that same equipment, if they exist.
Take off one of the blades and look carefully. You should find a number on there. Google that number along with mower blade. You should find it. Measure to confirm it is the correct blade.
I may have posted my source a few years ago. I bought a bunch of blades at the time and haven't had to reorder yet, mainly because I switched to the brush mower for the Xmas trees.
John Deere 4044M (A60462)
John Deere 4044M...
Trailmobile Van Trailer (A63689)
Trailmobile Van...
2001 Ford F-150 Crew Cab Pickup Truck (A61573)
2001 Ford F-150...
COLEMAN POWERMATE 60 GALLON AIR COMPRESSOR (A64281)
COLEMAN POWERMATE...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
6 Band Wooden Barrel (A61574)
6 Band Wooden...
