Pulling a 10 ft. disc
/ Pulling a 10 ft. disc #1
Huntermax-4
My question is, I have a J.D. 1530 tractor that is 45 hp. Will this pull a 10 ft. double gang disc through sandy loam soil? The terrain is flat. Thanks.
/ Pulling a 10 ft. disc #2
Will not be a problem. I pulled a 10 footer with a lot of weight on top with my 45 hp tractor and had smooth sailing.:) (Sorry about the orange color on the tractor!!)
/ Pulling a 10 ft. disc #3
It will pull it. There are some variables.... The more you angle it and burry it, the harder it will pull. Also, if its so sandy that you cannot get traction, it will have a hard time with much angle at all.
Are the rears loaded?
/ Pulling a 10 ft. disc #4
i have a 4510 jd and i was wondering the same thing. my rear are not loaded yet.and mine mfd
It is a light to medium sandy loam. The rears are not loaded yet, but that is on the list. I used to pull it with a J.D. model 70 which is about the same hp, but the 70 had a lot longer power stroke. The 70 handled it no problem.
Is all that weight on the disc necessary?
/ Pulling a 10 ft. disc #7
Will be the odd one here who says you will not be able to pull it. At least not at any speed you need to. Both my brother and I both have 9 to 10 foot disk and we pull them with 68 and a 75 hp tractors and a full load on them. We have sandy loam soil also. But on first disking our blades will penetrate much more than the picture shown by Oleozz with NO added weight. Both of our disk are 20 inch blades with two different brands of tractors and disks. On second or third pass we are disking full depth which is about 8 inchs. Again all we want to pull at a speed that a disk needs to run at. We are running with loaded rear wheels, two wheel drives. One orange and one red tractor. Harder ground is easier to pull disk over than softer dirt.
But you can always lift the disk, reduce the angle or remove blades if I am correct. Of course the frist two reduce how well the job is done but may be fine for your needs.
/ Pulling a 10 ft. disc #8
If your 70 handled it no problem, then your other tractor should be able to do it. Might not do it as well if you think the 70 is more powerful.... Try it first and see. I would not load your tires until you know you need to.
/ Pulling a 10 ft. disc #9
With a 1530 you would need to pull the disk in 4th gear to have a good ground speed. I don't think 40 hp drawbar is enough to do it right.
You would need filled tires to have a shot at it at any rate, and once you had enough set and passes to sink to the hubs or spools it would be too much for the tractor to handle. Bear in mind that a 70 weighs about a ton more than the 1530, the 70 can pull the disk but not fast enough with proper set.
I would think a 6' tiller would be a much better choice for the 1530. A disk and tiller cost about the same but the lighter weight with less strain on the engine and drivetrain is a real plus. While the tiller has a low travel speed the number of trips across the field are minimal compared to a disk.
Disks are great if you have larger blades, enough set and the power to pull them fast enough.
Steve
I already have the disc, and I am suppose to buying the 1530 on Sat. If I took the 1 blade off of each of the four gangs do you think that would make enough of a difference?
/ Pulling a 10 ft. disc #11
Removing 4 blades has to help but the total weight will still be close to the same. This would be a good load for a 3020.
What is the size of the blades and the weight of the disc?
Steve
Steve
Not sure on the total weight of the disc, but the blades are 16". The disk is an old J.D. KB wheel disc. Also, wouldn't controlling the depth of the disking via the cylinder help?
/ Pulling a 10 ft. disc #13
What is the proper speed?
I am going to be discing up some pastures for a seedbed next year. I have a 12' 32-20 hay king that I will be pulling with a John Deere 5525 (75 PTO).
Any tips would be appreciated.
Thanks,
D.
/ Pulling a 10 ft. disc #14
Pics of when I first bought the disc. Tractor without weights and FEL.
D.
/ Pulling a 10 ft. disc #15
If you have 16" blades then it is a light duty disk, or disk harrow. You have a chance at pulling it. This would be a finishing disk something I have used after running an offset disk with 20 to 24" blades first.
If you can make several passes across the field you can eventually do some good. You should get results similar to running a tiller 4" deep. If this is for pastures it would help alot.
Ground speed needs to be fast enough to throw the dirt a little which is needed to help level the ground and turn the sod over with the roots exposed.
Initially on hard ground you shouldn't have a problem pulling the disk, but after making a few passes and trying to cut deeper it will be harder to pull. Controlling the depth of the disk with your hydraulics will simply keep you from getting enough depth kind of a catch 22.
IMHO, I would consider using a good tiller with a working depth of 7 to 8" about 6 or 7' wide or a disk of the same width with 20" to 22" blades. My 4520 weighs about the same as a 1530 and with tractors this small and light I think a tiller is a better choice. A tiller enables you to dig down deep enough and pulverize at the same time with a much slower ground speed.
A well cared for 1530 is a nice tractor though and should work well with 6 to 7' implements.
Steve
/ Pulling a 10 ft. disc #16
Thanks,
D.
As to speed you need to be able to roll the dirt over and get it to level. Too slow a speed and you don't tear up the roots or loosen the dirt that well. On my disk you also end up with a very unlevel job. You can run too fast but is not likely. Now if bouncing out of seat and can not make turns you are TOO fast. More than likely the first sign of running too fast is the disk is not sinking into the ground as much and thus cutting as deep as it should.
But a rule of thumb, on 4 speed two ranges trans it seems second gear in high range fits most of the time.
/ Pulling a 10 ft. disc #17
I have a JD 5203(56hp 47pto hp) and have been using a 6' Tuffline disc that belongs to a friend of mine. I use it to cut fire breaks, so I pull it in very sandy soil that's been previously plowed(one pass and the disk is at the axles). the harrow has 18' blades I think. Anyways, I have to pull it in 4wd ALL the time, not some of the time, ALL of the time. I'm buying my own disc in the next couple of weeks and won't go any bigger then 6' with 20" blades. I'll also be adding two sets of rear wheel weights and about 400lbs up front. this should help with the traction issue I've been having as it will put my tractor around 6,000lbs total. my goal is to have it weighing around 7,000lbs when i add my front end loader and fill the rear tires along with the wheel weights(will take off the front weights when I add the fel). if I was plowing in hard ground or ground that had never been worked, I have no doubts I could go 8' or possibly 10' but that would do me no good as I have t run my disc in ground that gets worked every 3 weeks. even with 56hp and MFWD the tractor knows that disk is behind it. I would suggest 6' or a tiller as others have said.
/ Pulling a 10 ft. disc #18
Here is a small 18 footer that I normally pull behind my Kioti 45:)
I think, as most responders have mentioned, soil conditions are critical for matching disc size to hp.
Well, the verdict is in and a j.d. 1530 45 hp tractor will pull a 10 ft. disc in 5th gear with relative ease. Not too bad. Thanks for the input.
/ Pulling a 10 ft. disc #20
I'll bet you do... (always with the wheels down!!) :) On your way to the big tractor - so you can hook it up!
I used to pull a 12' disc behind a JD 730 diesel (2 lunger). It was a small (finish) disc as jenkinsph would say.. 14" blades. Not a problem.
AKfish
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
2009 Ford F550 Flatbed w/ Lift Gate (A62613)
2009 Ford F550...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
Hydraulic Breaker Excavator Attachment (A64194)
Hydraulic Breaker...
