Advice needed with 50 Hr service on CK-20S
   / Advice needed with 50 Hr service on CK-20S
NAPA -$ 60.04-6 gallons-including tax
TSC -$ 64.18-7 gallons-including tax (wasted money)
   / Advice needed with 50 Hr service on CK-20S #12
I use the NAPA/Valvoline UTF in the blue bucket. 5 or 6 gallons per bucket. Trouble is that the CK30 needs 7 gallons!!!! so I have been storing a partially empty bucket for the last 400 hours of operation.
The CK30 has the main drain and then one additional drain plug below each final drive which is also pretty much the brake housing. The big plug in the middle is the major one though with the magnet.
   / Advice needed with 50 Hr service on CK-20S #13
You're fortunate; my 3054 TLB has no less than 5. One on each of the brake housings, one on the differential, one on the transmission and one on the front drive housing. The latter three each have a magnet attached, which is a good thing ;)
   / Advice needed with 50 Hr service on CK-20S #14
Some of the KIOTI Recommended Hydraulic fluids:
Shell Donax
Mobilfluid 524
Texaco TDH
There are more. Call a dealer, they have an up to date list. We use and sell Shell Donax with good results and low foaming characteristics.
   / Advice needed with 50 Hr service on CK-20S #15
whats that shell cost?
nappa is about same as tractor supply,well,there you go,thats what to use,be carefull though,they got like 3-4 kinds,get what I said[whatever that was],many words, but its 20 weight I believe,hydro oil is 10 weight,[again I believe].
   / Advice needed with 50 Hr service on CK-20S #16
Precise, concise & right to the point. :eek:
I may need a translator though. :confused:
Don :eek:
There are times it's just better to hold that thought.
   / Advice needed with 50 Hr service on CK-20S #17
Well,I try and be that[whatever that was],its a post back in this thread,where I said what it was,can't remember now,could look,but already wrote it once,heavy duty premium tractor universal,stuff,also for your wet brakes fluid.!!! Believe it was green and white bucket,course they probably all are.
NAPPAS are everywhere,at least every where I've been.
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
2010 Ford Fusion Sedan (A56859)
2010 Ford Fusion...
LOT: (18) Scraper Bars for Sakai Pad Roller (A59076)
LOT: (18) Scraper...
(4) 305/45R22 TIRES & WHEELS (A58374)
(4) 305/45R22...
flooring (A55758)
flooring (A55758)
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
