3-Point Hitch on loader arms PICS
   / 3-Point Hitch on loader arms PICS #13
yea but the ad also says
Sale Price: $1452.00
OUCH!
I prob wouldnt buy it at that price but saved the link at some point for reference for a build it yourself project
I wish I could get a better look at it. Just to see how the width adjusts
   / 3-Point Hitch on loader arms PICS #15
Doesn't the scraper work good in the front?
Only when you use it as a fixed angle dozer blade. I have top-n-tilt on my 3PH and can cut a tilted slope. On the FEL, there is only curl which is like an adjustable toplink. I have no way of tiltiing the blade. Also, if I pull the boxblade in reverse, I don't have nearly as much traction as pulling forward with it on the 3PH. Frankly, I don't find the boxblade nearly as useful on the front as the normal FEL bucket.
I failed to mention that I have a subsoiler that I put on the front. It works very well for cutting trenches around trees to cut roots. With the narrow front on the FEL, I can get a lot closer than I could with the subsoiler on the 3PH. I haven't tried a middle-buster on the front yet, but it would also be a nice tool to for digging trenches when I need the rear 3PH for something else. Otherwise, the 3PH is still the best for draft implements.
   / 3-Point Hitch on loader arms PICS #16
My adapter was only $250 from my New Holland dealer. I think I could do a lot of modifications for $1200.:rolleyes: For example, I could cut the lower link adapters off and replace them with a sliding rotating ball adapter welded to a square tube section fitted over the existing square tubing. I think I could do that for less than $200 more. I think you can order this from your NH dealer using the data plate info. It's probably up to $300 or more by now.
top-n-tilt , I don't have it...........yet,
But it would make using the box scraper on the 3PH more of a benefit.
What other things can you use a TNT for?
   / 3-Point Hitch on loader arms PICS #18
If you don't go from one category to another it should stay the same width.
So I go and measure the 2 3pt implements I have here at home and get 2 dif measurements. Go figure.
6' landscape rake 28", JD weight box 26.5"
Knight and Jinman, what is your lower span measurements on your adapters ?
   / 3-Point Hitch on loader arms PICS #19
It is just a tube inside a tube which slides to the position desired. Looks fairly easy to build.
You might be able to hang some forks from the top, or make that bottom tube removable, so forks could slide on.
The second and third pictures have a hyd motor for those powered attachments.
The third picture has hyd motor and adjustable width.
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
KOMATSU PC40MR-2 EXCAVATOR (A52707)
KOMATSU PC40MR-2...
Man Basket Forklift Attachment (A55851)
Man Basket...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
