Posthole Digger Post Hole Digger - Help
/ Post Hole Digger - Help #1
602466
Silk Hope North Carolina
New Holland TC40D
I just purchased a used heavy duty post hole digger for my tractor. I lifted it out of my truck with the front end loader and chain. My question is how to install it to the tractor. Is it a two man job or can one man do it? Now it is laying on a skid. Should I stage it in any way to make installing and taking off any easier. I was thinking a 4X4 in the ground and tying the auger to it. Any help (pictures) would be appreciated.
Thanks,
Wally
/ Post Hole Digger - Help #2
Hi Wally, When I got mine I had the luxury of having a beam going through the basement garage of my barn (partly by design of course) so I just got a beam trolley to roll it out of the way and it aids greatly in connecting it to the tractor..;) Enjoy and be safe...
Nice work!
I will not have that luxury as mine will be stored out side.
Thanks for the idea!
Wally
/ Post Hole Digger - Help #6
I know it looks kind of junky but here's my solution. Just found a long pallet and lowered the PHD minus the auger on to it. Put some scrap pieces of 2x4 to keep it in place at the level it meets the tractor when lowered. I can now connect and disconnect in no time with out wrestling the digger. Once hooked up I raise it and slide the auger on (easy once the boom is on the tractor).
I just did this a temp fix and it's worked so well I haven't changed it. If I ever get some free time I'll pretty/stenghten it up a bit, but for now this'll have to do. An added bonus is I can move it around with the forks if needed>
/ Post Hole Digger - Help #8
If you have a sturdy tree on your place throw a chain over a low branch, 7 or 8 feet off the ground will do, back your tractor with PHD attached and raised under the branch, attach the chain around the PHD boom, lower it and then disconnect the PHD. It is disconnected and stored. You don't have to build anything, it is easy to reattach and it is cheap. Been doing that with mine for years.
/ Post Hole Digger - Help #10
I don't have a beam trolley (that's one cool tool!) but use a similar method.
I hang mine from a chain that is hanging over the rafters. Doing it that way allows me to swing it around by myself its and easy one man job to hook up.
/ Post Hole Digger - Help #11
Why not just auger a hole in the ground and disconnect it there leaving it stick out of the ground? If rusting the auger bit is a concern then line the hole with plastic buckets. When you have the PHD digger out of the ground cover that hole with something so no animals or people step into it
/ Post Hole Digger - Help #12
Here is the 4x4 route. This has worked for years for me. No muss, no fuss, and it is where I want it to be. The other ways that are posted work also, but you asked about using 4x4s, and that is what I have done.
/ Post Hole Digger - Help #13
So, once you hook it up to 3-point, how do you get it off of the 4X4 holder? My tractor won't move sideways and won't lift high enough...
Mike
/ Post Hole Digger - Help #14
Mike
You lift the phd, then the 4x4 can be pulled out from the side. The 4x4 only sets in the saddles, it is not fastened. ;)
/ Post Hole Digger - Help #15
I bought a Rhino PHD 6 months or so back. Took a buddy and myself to get it attached the first time.
When it was time to remove it I tried my Harbor Feight engine hoist. That makes install and removal surprsingly easy.
Warhammer
Thanks,
Wally
Thanks for all the replies. I now have lots of good ideas.
First thing is to get a friend of mine to put it on the tractor. We then can measure the height of it when pulled up all the way. Back that off then we can build the holder. Any magic number you guys have used for that?
Thanks,
Wally
/ Post Hole Digger - Help #17
I just take mine apart and put it in the shed when I'm done with it. Takes about 15 minutes to put together and mount on the tractor.
Attach the yoke to the lift arms, attach the boom to the tractor, connect the yoke to the boom and lower to the gear box/auger and put the pin in. Maybe thats more work than you wnat to do for a phd but I like to store mine stuff inside and I have room that way.
