A Mini Power-Trac?
/ A Mini Power-Trac? #2
Hardly. That thing looks unstable on flat ground.
I've seen Toro Dingos. I don't really care for them.
The DitchWitch and the Gehl I like. (PT got me into articulating machines)
Also, I've been thinking about getting a small Power-Trac a while after we get our large one (a PT-180 or 422) for my own property. I have a very small yard (less that 1/4 acre) but I HATE push mowing it and a lot of the other small mowers just don't...something. I know its too much machine but my yard also needs to be Tilled, re-leveled and re-seeded. I also have a large driveway and we get hammered with snow a lot in the winter. It's just a nice thought/dream, though
/ A Mini Power-Trac? #6
/ A Mini Power-Trac? #7
The Gehl advantage are really nice tractors from what ive heard. Made by Avant in europe. Theres a couple threads on compact loaders on here about them.
http://www.tractorbynet.com/forums/construction-equipment/138763-compact-articulated-loaders.html
http://www.tractorbynet.com/forums/all-other-brands/69948-made-finland-avant-tractor-skid.html
AVANT Tecno Oy
Note that Gehl has stopped importing the Avant -- because of emissions, I think...
Still would like to have one. A Kubota diesel in a machine the side of PT425 would be nice...
/ A Mini Power-Trac? #9
I have the Gehl Al20dx. Bought it used with only 39 hrs on it. I have about 420 hrs
now. It is really a good machine. There was one on Ebay recently with about the same number of hours asking $7900.00 . Attachments are hard to come by. I use the Power-trac mowers. Made a mini-hoe last year (looks like a welder's nightmare).
I bought a Dingo power broom on Ebay this year, and use that to sweep the stones our of the grass on my very long
driveway.
/ A Mini Power-Trac? #10
Thanks for the update. Too bad they looked like they filled a niche. I wonder if it was emissions or sales that stopped the import of the Avants? I read reciently that Gehl is on shaky ground financially.
/ A Mini Power-Trac? #11
I am not sure it was an emission issue. I think price had more to do with their decision. I have heard that the tractors sell for about 18k new. That is a lot for
such a small unit. Another problem was the cost of attachments. Very expensive
from Gehl. Some of the attachments that you can find listed are not even available
from Gehl in the U.S. . Gehl doesn't stock the mower, for example, because they
didn't think anybody would spend 18k for a lawn mower. Well, I didn't spend 18k,
but I use mine primarily for mowing. As I said, I use the 60'' mower from Power-Trac
and with some modifications it works really well.
I have had pretty good luck finding attachments that work with my tractor. I bought
a wood chipper made by Ingersol that works great for small branches (3'' or smaller).
Ingersol has since discontinued the manfacture of this chipper. The Dingo broom I
bought on Ebay, required a little modification, but it is basically a plug and go unit.
/ A Mini Power-Trac? #12
Friend of mine just purchased a new Zahn gas engine....over $22k.
/ A Mini Power-Trac? #13
Another fairly rare European import is the Multi-One from CSF in Italy...
They're sold under a few different names, I think. Parts availability would be a bit sketchy, I'm guessing...
CSF
/ A Mini Power-Trac? #14
CSF
Theres a multione dealer in montreal. Very nice looking machines, but you should check out the prices! I dont think they were big sellers, the machines are listed as "new" but are 2006 models. Maybe the dealer is dumping the line?
MULTIONE Wheel Loader, Used MULTIONE Wheel Loader, MULTIONE Wheel Loader For Sale At MachineryTrader.com
/ A Mini Power-Trac? #15
Theres a multione dealer in montreal. Very nice looking machines, but you should check out the prices!]
Someone's got to pay for all that swoopy styling. :rolleyes:
I guess the Power Trac mine tram heritage kept them relatively low to the ground and unneeding of styling. That, and it's hard to "style" steel plate. :D
Who styles construction equipment anyway?
/ A Mini Power-Trac? #16
There are some larger tractors that look like they could go 200 mph with the styling they have. To me it looks like stuff that will break off but what do I know. But it poses the question, why do those little track hoes have rounded cabs? What sort of wind resistence is there at 2 mph?
/ A Mini Power-Trac? #17
If they are molded fiberglass or the like, it would make them significantly stronger than if they were box like. The same would be true for metal, but it would be less of an advantage due to the increased construction costs.
/ A Mini Power-Trac? #18
The panels are all made of steel. Not sure of the gauge, but very strong and painted with a quality enamel similar to that you would see on larger construction equipment.
Another neat feature; they come off very easily and allow access to the engine
compartment, and hydraulics.
You can't help but notice the similarity to the Multi-one. The have a different engine,
but the smaller tractors like mine, are almost identical.
/ A Mini Power-Trac? #19
The tail end of track hoes are rounded so that they don't catch on things when the machine rotates -- that's their primary motion, rotating back and forth. There's a a whole class of them that is designed ot have zero rear overhang, so they can work up as close to a wall or fence or something as their tracks will allow...
I think the cabs are rounded to match the style of the rounded rear...
Many of the trackhoes and skidsteers have VERY heavy steel (or cast iron) on the rear to act as a counterweight to the bucket...
Dealer quoted me a Zahn R300 4WD with the Tool Carrier (with Bucket, Auger, Pallet Forks), Trencher, Large Dumping Hopper (with front loading scoop), Tiller, and Stump Cutter. Okay, drum roll please.
$43,000! :eek:
Jeez! We'd rather buy a PT-425 or Bobcat 463 for all our small jobs!
But we really do like that Zahn. But not for no $43,000! :eek:
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
1997 International 4700 Bucket/Chip Truck, VIN # 1HTSCAAP2VH489823 (A61165)
1997 International...
APPROX (14) 20'-35' HEAVY DUTY INSULATED PANELS (A62131)
APPROX (14)...
John Deere 855D (A61166)
John Deere 855D...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
