what to make ?
  • Thread starter washita
  • Start date
/ what to make ? #1
W
washita
Guest
helped neighbor clean out barn this weekend, acquired a homemade logsplitter for my efferts, unusual build on splitter but the I beam and 4x24 ram seems to be fine, was thinking strip it down to beam weld receiver hitch tube to one end and in the middle, replace hoses and run it off aux. pto on the 425, unfortunately it would have a cycle time of roughly 40 seconds, I do not heat with wood so it would not be used as a log splitter,possiblely pipe bending, bead breaking, trimming branches occasionally, what other mischeif could I get into with it? ideas - thoughts
/ what to make ? #2
Run it off the main PTO. Much higher flow rate will reduce the cycle time. I think its 12 GPM versus 4 for the Aux PTO. You probably thought of this and wanted to save money on the valve.
/ what to make ? #3
I think the PT425 has 8GPM at 2500PSI on the main PTO and 3 or 4 GPM at 2500PSI on the aux PTO.
Use this calculator at Surplus Center to figure the speed.
https://www.surpluscenter.com/techhelp/cycalc.htm
/ what to make ? #4
Forgot to finish my post! :rolleyes:
Retraction times will be slower and will have to be calculated with the rod diameter whereas the extension time will be constant based on bore size.
All 4" bore cylinders will push at 2.5" per second at 8GPM, 0.9" per second at 3GPM and 1.2" per second at 4 GPM.
So, even at the lowest GPM of 3 a 4" cylinder that is 24" long will only take 26.6 seconds to extend.
At 8GPM it will only take 9.6 seconds.
/ what to make ? #5
With a 4 in bore and a 2 in rod, and 3000 psi
Push force = 37,699 lbs
Pull force = 28,274 lbs
Extension time 2.5 ips [ in per sec ]
Retraction time 3.3 ips
/ what to make ?
now I wonder how big of sapling/limb I can pinch off ? when time/weather permits I will be investigating the control valve to see if it is a open center valve then plumb it into the main pto circuit with extra long hoses so I can use the beam in horizontal and vertical positions heh heh tell my overly curious neighbor that its a walnut cracker :cool::D
/ what to make ? #7
Has anyone figured out how to reconfigure my Lackender mini-hoe so it can be a log splitter too?
/ what to make ? #8
Exactly what are you trying to do. Can you make a log splitter out of the boom, NO. Can the mini-hoe pick up a 3ph log splitter, maybe.
/ what to make ?
I think the suggestion of running the cylinder off the aux hydraulics will cycle the cylinder quicker with a valve I can operate from the seat, weld a receiver tube to one end and in the middle opposing the cylinder so I can use the ram in a horizontal and vertical position, I will have to change the wedge,someone welded it to the ram, will make so I can bend pipe, change post install 4 way splitting wedge, so I can shear saplings if needed, basically trying to make a do all attachment , probably be lucky to use it enough to pay for the new hoses and fittings. also cutting off all excess steel bracketry not needed, the 425 currently lifts it without a fuss ie: 5 hp briggs-small wheeled axle assembly- valve-hoses-towing hitch-pump, oddly enough there was no resivoir I am guessing it did not see much use, maybe the operator did not appreciate having split wood popping out at him due to the wedge being on the ram ( years ago left a splitter attached to the truck, broke both rear tailights out when a chunk of elm popped out of the wedge, a lesson well learned)
/ what to make ? #10
Cylinder speed is determined by pump flow in GPM's. So therefore, the PTO circuit would give better cycle times.
/ what to make ? #11
Is it just a beam and cylinder or is it a complete logsplitter. You mentioned it is an unusual build, what is unusual about it. WE NEED PICS. If it has a motor/pump and resivore why not just leave it the way it is?? Even junk homemade splitters are bringing a premium around here. Sell it and buy what you want.
/ what to make ?
yes j j your right pto hydraulics would be faster looked up cylinder today it is 2" rod x 5" bore x 14" stroke made by prince my honest opinion is anvil is to far away from cylinder, here are some pictures.
/ what to make ? #13
With the cylinder fully extended, it should just barely touch the anvil. If the stroke is 14 in, then the space for the log should be 14 in, maybe 15 in..
There was another guy on the TBN that had a short cylinder that he wanted to split 24 in or longer logs. He was thinking of a scissor type action or lever type. For instance, your cylinder is 14 in stroke. so how would you split 24 in logs? In your situation, it would be better to attach the push plate on the rod, and the wedge on the end. Of course a longer beam would be used. Now assuming that you have the spacing at 24 in, you push the first log until it stops, and retract the wedge, and then you add a gage block that will allow you to push the 24 in log all the way through the wedge. It is only time, you have the power.
/ what to make ?
it lacks by probably 7-8" here is what I will try to accomplish
/ what to make ?
I think your suggestion would work well in this situation, I personnaly do no heat with wood so its not a big to me my brother in law might burn 1/2 cord per winter so that probably only splitting it will do, gage block with sharpened edge might work well for pinching off saplings, do you think receiver hitch tube could handle the pressure ?that would be easy to fabricate and adjust for different lengths
/ what to make ? #17
On the hitch tube, sideways would be OK if you beef it up
I have a 3ph log splitter, and I was thinking of modifying it to cut trees up to 5 in at the base. I am going to hang mine off of the 3 point setup.
/ what to make ?
did some more measureing there is enough room for a 24" piece but only 14" of ram stroke, think I will cut off everything and start over cylinder support welded on crooked, welds look marginal at best ( 20+ yrs welding fabricating experience) think I will look up shear strength of grade 8 bolts and incorperate a receiver tube where the anvil was so I can make easy stop adjustments plus change to a pipe bending die when needed, back to the original train of thought the wedge lacks touching the anvil by 10"
8x5 Cattle Panel Gate (A64047)
8x5 Cattle Panel...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
(INOP) 2002 MANITOU MLT-633TLS TELESCOPIC FORKLIFT (A62130)
(INOP) 2002...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
