Class 6 Truck
/ Class 6 Truck #1
SouthernX
I'm looking at buying a used class 6 truck. I've been looking at F-650, Freightliner 60, International 4200, Sterling Acterra, etc.; I'd like to hear any feedback you may have about trucks in this class. Is the F-650 everybit as tough a workhorse as the others in this class? I've looked all over for towing weight capacities (gcvwr / max-tow-lbs.) for these trucks and have had absolutely no luck finding it on the net. Based on what information I've pieced together I'm estimating that these trucks should be able to pull somewhere between 35,000 to 45,000 pounds. Sound about right? If you've got hard numbers and specifications then post them please. Any feedback you can share would be appreciated.
/ Class 6 Truck #3
Tell me what you want to do with this truck. I have experience with class 8's through tri-axles and lowboys behind them. I might be able to help.
An F-650 towing 45,000lbs is virtually impossible. I wouldn't want to be the poor sucker pulling 22.5 tons behind one. Even 35,000 is a lot. Those are medium sized excavators on 20 ton lowboys.
Ive pulled 25,000 behind my IH4800 and you can definately feel it. Once you get over 12 tons, you want airbrakes for sure. Of course a CDL is mandatory. 275-300 HP is real nice, too.
Most F-650's I see pulling are a full size backhoe, which weighs ~17,000 lbs on a 10-12 ton trailer that weighs 7,000 lbs, that a total of 24,000lbs. They'll do it, but you're talking almost twice that weight. Ain't happening on an F-650.
One other thing you might want to know: F-650's are made by IH in a joint venture called "Blue Diamond". IH basically makes the F-650/750 for Ford on a Mexican IH assembly line, then sticks a Ford cab on it. Another difference is the powerplants. Fords come with Cummins 6.7L or maybe CAT and IH uses their in-house MAXX FORCE (DT) series diesels.
/ Class 6 Truck #4
I would personally go with a class 7 single axle or tandem if you need the pin weight to get bigger motors, engine brakes, more torque.
The 8.3 Cummins and 3126 can probably do what you want but slowly and the exhaust brakes are just ok.
/ Class 6 Truck #6
A little more info on what you are pulling would be helpful. This 35-45K that you want to pull. Are you talking trailer and load, overall combination weight or what?
From what info you already stated, I agree that at least a class 7 would be needed.
For what it's worth, I drove a Pete 335 single axle with a C7 rated for 275hp backed by an 9 speed pulling a tandem axle flat that rolled back to unload trusses. Man, I could not get away from that POS fast enough. The fifth wheel was fixed so you could only get 7500 lbs on the front tractor axle so you had to watch not overloading the single drive axle. Even with a legal gross, the rig was a total dog on the hills. Handling was something else. The trailer would be pushing that tractor all over the place. About the best way I could describe it would be "barrel rolling".
/ Class 6 Truck #7
My daughter drives a F-650 for work,it has the Cat and a six speed standard trans. It is a bit of a dog,and has had hydraulic slave cylinder and clutch issues. The seat is a stock pump up seat,not a true airride,it's time for a new seat. The GVW is just under the requirement for a CDL endorsement. The F-650 is available with airbrakes. Sterlings are a pile of ^%&* My wife drives a Sterling triaxle dump. The interior,inside door panels and headlight bezels are falling apart. I drive a Freightliner FLD112,it is more rugged then Sterling,I had thought of getting a Sterling once. plowking
/ Class 6 Truck
I'm wanting to tow up to 25,000 lbs (inclusive of trailer weight).
I didn't make myself sufficiently clear. I should of said a GCVWR of 35,000 to 45,000 lbs. I only want to tow up to 25,000 lbs.; With a class 6 truck I'm guessing that's probably about 35,000 lbs of gross combined weight.
/ Class 6 Truck
Hope this has what you're looking for for the fords anyhow.
https://www.fleet.ford.com/showroom/rv_trailer_towing/default.asp
Model Max. GVWR Max. GCWR*
F-650 Regular/Super/Crew Cab 26,000 Lbs. 40,000 Lbs.
F-750 Regular/Super/Crew Cab 30,000 Lbs. 45,000 Lbs.
F-750 Regular/Super/Crew Cab 33,000 Lbs. 60,000 Lbs.
Thanks KLM. The GCWR for the F-650 is right in the middle of my educated guess of 35K - 45K GCWR. Of course that doesn't mean that an F-650 will tow it really well but at least the truck is rated for what I want to do.
/ Class 6 Truck
Thanks for the info. So, do you feel the FL-60 and IH 4200 are probably better built and will last longer with fewer problems? I've heard that Freightliners' are expensive to get worked on (but that's just what I've read).
/ Class 6 Truck
My understanding is that if a truck is equipped with air brakes you have to have a CDL even if the GVWR is under 26,001. Is this correct?
/ Class 6 Truck #12
My freightliner costs me 80.00 an hour at the garage,I have a Cummins with a ten speed,basically the same components found on Pete's,KW's. As for International we have a fairly new ten wheeler at the highway department,it has had a problem with the fan blades disintergrating and taking out radiators,coolant bottles and fan shrouds. If you could spec. the truck yourself,it would be better then buying an existing truck that was speced wrong. The company my daugter works for has a second F-650,it has the powerstroke and a four speed automatic. When it hauls their JD 110TLB,it gets under five miles a gallon. I've driven it,the exhaust system is two open straight pipes[stacks],don't drive that truck for long. The 650's both have air brakes,I wouldn't want hydraulic brakes for that kind of weight. plowking
/ Class 6 Truck #13
I'll throw my 2 cents in, since I've owned Ford, International, and Freightliner med. dutys....... and extensively operated the GMs (which you didn't ask about). Never drove a Sterling. Out of the bunch...... by FAR the best med. duty I owned was a Freightliner FL60. It had a 3126 Cat / Fuller 6sp. It had approximately 500,000 mi. on it when I sold it, and was incredibly reliable...... in fact I had just barely replaced the original water pump when i sold it.
I'd call the GMs, Fords, and Internationals fairly equal behind the FL. They were all decent trucks. I'd have to say my Internationals nickel and dimed me the most. Never terribly expensive repairs, but things like sensors, water pumps, etc. International did have the best parts availabilty of any of them though.
/ Class 6 Truck #14
air brakes, air brakes, air brakes.
What are you pulling that is so heavy?
You're going to need a CDL A no matter what. (gross combined weight over 26d with a trailer over 10k)
You're probably going to need a USDOT # and all that jazz unless it's not for commercial purposes. Specifically what are you using it for?
Big trucks mean big bucks.
Things just cost a lot and they cost more to work on. The one guy said $80/hour by him. By me (Denver metro), it's from $90/hour to $120/hour. (for comparison's sake, the local chevy dealer is $75/hour)
Common parts are actually pretty cheap, but other stuff breaks too and it can get SPENDY. Heck, just an oil change is $200 on a class 8, not sure on a class 6.
Used trucks tend to get beat to heck and gone before people sell them. Expect to put money into it to get it safe and reliable again. Just make it part of your budget. A couple thousand dollars at least.
Gearing and transmissions matter a lot for your work. It's not like a car or pickup where you just deal with it. Figure out what you want to do and where you want to drive, then that will lead you to the HP range of the motor you want along with gearing and the appropriate transmission.
most big truck shops work on all big trucks. Parts are common across many of them and they just go to the right dealer to get the specific parts. Sterling is being shut down by Diamler, so parts availability is 5+ years may become a problem.
/ Class 6 Truck #15
You're right on with the shop rate,I'll bet it'll be 90.00 a hour here before long. My garage has treated me right for over twenty years. I heard the Toyota Dealer is 95.00 an hour here. plowking
/ Class 6 Truck #17
This discussion could take a turn, but my opinion of mediums/heavies is that Freightliner & Sterling, Ford & GM were the most affordable, but bottom of the barrel for quality/reliability. IH was a step above, MACK & Western Star would be a step better and PACCAR bros trucks (Pete, K/W) were the best.
Thing you have to remember with Ford, GM, Freightliner and the now defunct Sterling is that these trucks share the same brands of engines, transmissions, rears, DPF systems, steering gear, etc.
The only somewhat major difference is the cab. Take the cab off most "vocational" grade trucks and they're differences are barely noticeable.
My last choice for a new medium or heavy would be Ford. The reason is because they make virtually none of the truck themselves except maybe the sheetmetal for the cab and the Ford emblem on the hood. The rest is made by Cummins, Allison, Spicer, IH, etc. They're made in an IH plant in mexico. GM would be next up the feeding chain. They do make their own allison transmissions, cabs and rears and some of the engine offerings(at least until a few months ago when GM sold heavy ally transmission division) and they're made in US instead of Mexico.
You'd be better off with a Pete, KW or mack vocational truck over a Ford, GM.
/ Class 6 Truck #18
Exactly. you can tow 25,000 lbs without airbrakes. Juice brakes that size are not real desireable, but they keep you from having to get an airbrake endorsement.
Yep, there's no way he can tow this load without a CDL. Brake system doesn't matter, but airbrakes are always better.
Here I would disagree somewhat. My oil changes are ~$120 and my truck takes 24 quarts of engine oil. I can do them myself for less. They're easier to do than a car because it's so easy to work on them. Brakes last a lot longer and service intervals are much further apart. Truck mec prices in my area are the same as car mech prices. I do most myself since it's pretty simple (fluid/filter changes, brake adjust on air brakes, etc.)
All depends on previous owner. I've seen trucks & equipment so well cared for, it would blow your mind.
Agree.
/ Class 6 Truck #19
I have yet to see a factory speced truck under 26,001 with airbrakes. Maybe once in my life I saw one. I would think this would be a truck specially purpose built for a unique application.
If there was one, you might not need a CDL if the trailer weight was under 10,001, but you would need an airbrake endorsement.
What most people don't understand is that there are multiple "levels" of CDLs. To drive an 80,000lb triaxle with no trailer, all you need is a class B CDL, which is very easy to get.
Once a bigger trailer comes into play that changes into a class A CDL. Much more difficult CDL test to pass.
/ Class 6 Truck #20
I have seen and driven several under 26k trucks with airbrakes
A CDL or "Air brake endorsement" is not required
PS Air brakes isn't an endorsement it is a restriction if you don't have it
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
John Deere ZTrak Pro Series Z994R Operators Manual (A63117)
John Deere ZTrak...
2020 Peterbilt PB337 S/A Dump Truck (A61573)
2020 Peterbilt...
Caterpillar D6D Tractor Service and Parts Manuals (A63117)
Caterpillar D6D...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
2022 EZ-GO ELITE...
