Cub GT2542 vs JD X300
   / Cub GT2542 vs JD X300 #1
artp
Southern Illinois
Kioti CK30HST
We are needing to replace our aging JD LX172 38" cut with a new lawn tractor. We need to stick to small deck size (42") hydrostatic (for my wife) and mulching deck. We have narrowed it down to these two, but would like feed back from members on this board.
So my observations:
The GT2542 seems heavier built with a larger engine and smoother operation. Comfort level is good on both, but with an edge on the GT2542. Wife likes the feel of that unit better. Did a test cut on a used JD X300 at the dealer. Seemed OK on level ground (which is what I have at home) , but had some trouble on steeper grades. Ride was OK, better than my old tractor. JD dealer would not let us test the tractor at our home. But JD does have 60 day return policy-no questions asked and 0% 12 month financing.
Cub dealer will be let us test the tractor next week at our home. Will know more then. Price comparison was suprising-the JD was about $ 400 less than the best I could do with the Cub dealer.
I have bought from both dealers in the past. Got my current JD from the local guy here. I bought my Kioti tractor and implements from the Cub dealer and have been very pleased with the service and performance of the units I purchased from him.
Any comments, thoughts, from guys on this board?
   / Cub GT2542 vs JD X300 #2
Tough comparison because the Cub is a GT, and the JD is a LT. The X300 will probably give you a better cut, be a little more maneuverable, and is quieter. The 2542 weighs a lot more and will give you more options in the future, should you decide you want to do more than mow with it. It has a heavier duty transmission and frame, both designed for ground engaging. But seeing that you have a larger tractor as well, not sure this is even a concern.
JD's tend to be better quality, but if you have a good Cub dealer it won't be an issue. Most Cub issues tend to come from poor initial setup and support.
The price differential is tough to argue because you're buying stuff in the Cub that you may not need (GT abilities). My personal opinion is that I'd rather have more tractor than I need. But then I don't have a Kioti backing me up either :)
What it really sounds like it comes down to is comfort with the tractor and the dealer. Based on what you've said it sounds like the Cub guy is a bit more interested in making sure you're happy. And if your wife prefers it ergonomically, then it sounds like you're pretty much there. Again, it depends on whether the extra GT-ness or the "my wife prefers it"-factor is worth spending $400.
   / Cub GT2542 vs JD X300 #3
1*We are needing to replace our aging JD LX172 38" cut with a new lawn tractor.
2*We have narrowed it down to these two .
So my observations:
3*The GT2542 seems heavier built with a larger engine and smoother operation.
4*Price comparison was suprising-the JD was about $ 400 less than the best I could do with the Cub dealer.
5*Any comments, thoughts, from guys on this board?
1*So far you have looked at one lawn tractor and 1 garden tractor.
2*A garden tractor and a lawn tractor.
3*Garden tractors are better built with better engines than lawn tractors.
4*Not to me as lawn tractors should cost less than garden tractors.
A CC lawn tractor comparable to the JD probably would have been less than the JD.
The GT2500 and 3000 series are the top of the line Cub Cadets.
The JD x500 and x700 are top of the line JDs.
You have compared an apple with an orange. :)
5* That's mine.;)
   / Cub GT2542 vs JD X300 #4
The OP has formed his opinions on an
apples to oranges comparison .
Such comparisons are meaningless and are full of errors .
Not a good way to make a sound buying decision
   / Cub GT2542 vs JD X300 #6
If you are just mowing go with the JD. If you are mowing and doing other things go with the cub.
   / Cub GT2542 vs JD X300 #7
I just got our 2554 and was very well-pleased(actually surprised) with it's ability on differing terrain. Traction is excellent and it's ability on hills seemed good.
I feel the 2500 Series as the best buy in tractors. I sold my 20 year old Cub 1872 to get this and this new one is better on uneven terrain than the horse of a garden tractor it replaced.
I am very pleased with it.
Just pulled our 6X12 trailer with 2 scoops of mulch around the yard and it did well. Mind you I only pulled it on the level stuff.
I do not know a thing about the JD. Sorry.
   / Cub GT2542 vs JD X300 #8
If he is just mowing he should compare a CC lawn tractor with the JD lawn tractor before deciding which to buy.
1*I feel the 2500 Series as the best buy in tractors.
2*I do not know a thing about the JD. Sorry.
1*I tend to agree unless you buy one of them when you should have gotten a S-Compact instead like i did.Then it is an expensive painful experience.
2*The Jd is not in the same class as the CC he compared.:cool:
   / Cub GT2542 vs JD X300 #9
The OP has formed his opinions on an apples to oranges comparison.
Most people start out that way, which is why they post on places like this. Nothing wrong with that.
Such comparisons are meaningless and are full of errors.
No, they're not. They provide a great starting point, especially if you're not familiar with the models in question. Besides, he might have started comparing these two models because they are priced similarly, or because they are what the dealers had on hand. Both of these reasons are perfectly fine to START with.
Not a good way to make a sound buying decision :)
... which is why he came here and posted. Notice how he never mentioned that he made a decision.
   / Cub GT2542 vs JD X300 #10
Don't mind the negative talk. It is not typical of Cub owners and most in this forum.
Whether or not we're comparing apples to apples is not the topic. The topic is what the original poster asked. If you know the differences, be nice and tell them what they are.
Basically what they are trying to tell you is the JD is a lawn tractor(meant for cutting grass and very light yard work). The Cub is a Garden tractor and that means it can handle heavier duty work.....snow plowing, snow blowing, garden tilling, etc. But if you are just cutting grass you may consider the Cub anyway because it will hold up longer and may be worth more in resale. I just sold a 20 year old Cub garden tractor for $1,000 and could have gotten $1500 to $2000 if I had stripped it down and painted it up. Since I don't have the time for such i sold it as it was.
Very pleased with the GT2554.
   / Cub GT2542 vs JD X300 #11
I see the line wife likes it ergonomically
that sells it for me if she likes to mow likes the fit go for it
me I just bought the ccyanmar inmy avatar for the way it fits me I test drove green, red, orange, another red, and decided on the black and yellow before I shopped for pricing that was just a plus
I am a fairly big guy have a fairly new knee need a cab as it gets darned cold up here
I go with the it fits whoever is driving it then go from there
the GT factor for and extra $400. is a plus in my book
   / Cub GT2542 vs JD X300 #12
I also think it's great of the dealer to let you try the Cub out on your property. I am not sure why the JD dealer will not allow this. It just seems silly to me to buy the JD and then if you don't like it you can return it policy.
Michael
Thanks for all the replies. You guys were right to point out that I was comparing apples to oranges. After we test the Cub on our lawn we will have a much better idea of how well it does that job. I too would rather error on the side of buying a little more tractor than I can possibly get by with for something more substantial that will last me for the long run. But you are correct lawn mowing is what I need this tractor for, not ground work, so we will see how well it cuts and put all the considerations in the mix. Thanks again for your input. I really appreciate everyone taking the time to respond.
We decided on the Cub. It may be a bit more machine than we need for just mowing the lawn, but the overall construction, feel, fit and (my wife just fell in love with it). Plus our dealer gave us a very good price and I have had good luck with service on all my Kioti equipment. Thanks for all the feedback and advice.
   / Cub GT2542 vs JD X300 #15
Welcome to the family!!
   / Cub GT2542 vs JD X300 #16
congrats onb the new piece of equipment
   / Cub GT2542 vs JD X300 #17
Congrats, and welcome to the family. Don't forget to throw up some pictures when you can :)
   / Cub GT2542 vs JD X300 #18
I test drove the JD300 and the Cub Cadet GT2542. After many hours of mulling the purchase over, I decided on the Cub. The price was 8 dollars more, (big deal), but I felt the Cub had more to offer. I have a little over and acre of meadow type terrain with small hills and my Husqvarna bit the dust trying to handle the work. That's all I needed to see was the fact that a belt drive failed to do the job. So-I went with the shaft drive of the Cub. In driving the JD, the reverse action, of the pushing on the pedal, seemed to cause the tractor to jerk harshly. The Cub is louder but feels more powerful, even though the HP's are about the same. I plan on taking down some Ash trees this fall and don't want anyones big 4whl drive pickup going over my lawn. So the Cub will be trailering the wood out to their trucks. One of my other first winter plans with the Cub is a snow blade, and if there's too much snow I have a large walk behind snow blower-but I thought the plow would be good up to 6 or 7 inces.....
   / Cub GT2542 vs JD X300 #19
Hi Diesel_nut, I have an 1882 and love the heck out of it. How would you compare the 2554 to the 1872(82)? I know that the 72 and 82 are super garden tractors but are they really similar to the 54? Thanks.:)
   / Cub GT2542 vs JD X300 #20
I'm pretty pleased with my 2518 that I've had since May. This is the same as the 2544 except mine has the old style hood. I was looking at those two also before I found mine used. The Deere looked better from a fit and finish standpoint. The Cub Cadet has a stronger drivetrain. I really like a horizontal shaft engine in a mower.
I was bugged by all the negative reviews I see on Cubs. Sounds like someone just isn't trying really hard in the QC department. Then again, most people will only post a review when they are frustrated with something. Maybe there are just more Cubs out there. I did notice that a lot of Cub LT owners were posting reviews under model numbers of Cub GT's.
Anyway, mine has to go, just picked up a Kubota g1900 and I've got no use for them both.
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2017 Ford Transit 250 Cargo Van (A59230)
2017 Ford Transit...
