A Pretty Simple One, or "How Not To Lose My Lynch Pins"
   / A Pretty Simple One, or "How Not To Lose My Lynch Pins" #1
yeagisyeag
Northern Ohio
Kubota B7100HST, International IH454, John Deere F910
I just bought some new lynch pins, and wanted to make sure I didn't lose them when I'm out in the woods or field. It's probably been done before....
There were welded on loops on my 3 point arms, so I used old keyrings and some small chain to keep tabs on things.
I found myself stuffing the pins in my pockets, then fumbling for them later, so I'm happy with the outcome!
Jim
   / A Pretty Simple One, or "How Not To Lose My Lynch Pins" #2
You can also get some of the heavy duty black lynch pins that takes an effort to get them open. I have snapped my thumb with a regular lynch pin, but you would be in trouble if one of the heavy duty ones pops you.
   / A Pretty Simple One, or "How Not To Lose My Lynch Pins" #3
been there, done that... etc
you'll wonder why you didnt do it before..
I attach them to the implements as i have different pins and constructions amongst my implements
Haven't really used things besides hooking up in the driveway, but I saw this coming!
I was watching your killer tiller thread, I need that kind of deal!
Jim
   / A Pretty Simple One, or "How Not To Lose My Lynch Pins" #5
Jim
Yep..that works good.. ford did this back in 39'
soundguy
   / A Pretty Simple One, or "How Not To Lose My Lynch Pins" #6
I currently have a JD-2640 and on the adjustment housings for the drag links, they put in 2 ea loops to put your lynch pins in. I had an older international tractor and just welded some nuts to the adjustments arms. They worked fine as well. Looking at your pictures, I was just a little concerned with that much loose chain hanging down and catching on something.
Mike
Mike
Yeah, I wasn't sure how much to put on there. Better to start with too much, then cut some off, no?
My dirt scoop has the pins pointing inward, so the extra chain wound up being useful there.
Jim
   / A Pretty Simple One, or "How Not To Lose My Lynch Pins" #8
On my JD they gave me loops on the arms that you drop the pins into, then snap them over to hold. I still tend to set them on the tire where they stay until I drive off....
   / A Pretty Simple One, or "How Not To Lose My Lynch Pins" #9
i got some fron tsc that had the chain on them and a cotter pin like thing on the end and i just hooked them to my draft arms in the loop holder on my 4510 and i have not lost one yet. i have lost alot of them on our 1715 new holland.
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A53421)
2025 ZWB 59in...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A55315)
2023 Kubota...
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
2016 Toro Groundsmaster 7200 72in Zero Turn Mower (A55851)
2016 Toro...
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
