A Question for Contractors
/ A Question for Contractors
deleted -- duplicate
/ A Question for Contractors #22
Dave - I went by one of my projects today, a high school, and looked at the tile on the second floor exterior walkways. It also is a porcelain tile and to my surprise we have runs of almost 200' without a single expansion joint and standard grout in the joints. We have been using this same detail for several years now without any problems with tile coming loose.
Our winter temps are close to or slightly below freezing and summer will hit 120+. The kicker is that we pour 2" of light weight concrete over a steel deck. Tile is then thin set.
I really believe that your problem is with the wood framing, not that it is inadequate, but perhaps not the best application. The modulus of expansion for concrete & tile is more than double that of wood. Something has got to give.
I would cut an expansion joint every 20' or so all the way down to the wood deck and fill with an elastomeric sealer. This hopefully will allow the concrete/tile to move independent of the wood and reduce your problem.
Do you have a roof over the walkways?
I didn't realize the CTE of wood was less than that of concrete and tile.
Anyway I am attaching pictures of the deck, more in the next post.
/ A Question for Contractors #24
Some decks are covered others only partially and all are soffited below, but otherwise open to the weather.
I checked again and the beams are not Glulams, they are Versalam, which is a better material for this application. They are sheathed in Hardiboard. I measured, and on the east and north sides they are 18" x 5 1/4" and on the West side, over the garage doors, they are 24" x 5 1/4".
The posts under the beams are 14' tall, 15' 6" on the west side where the garage is. They are 6" x 6" pressure treat. The stone-sheathed post bottoms are 26" and 44" tall. Under the stone is 12" x 12" hollow cinderblock, concrete filled. The piers are 4' x 2' with lots of rebar and 4 pieces of #4 bar coming up the interior of the block. Galvanized post bases and caps.
The west side is where the tiles are coming loose the most, on the north side, they are almost perfect, and very little deterioration on the east side.
The contractor was out this morning and what he wants to do is take up the tile in a 20' x 10' section on the west side, let it dry for about a month, and test the polyurethane grout in this section. He thinks he can tell just by examining it whether it will last through the winter.
My cost is only going to be $300 - $400 on the test section, maybe even less.
Right now my inclination is to let him go ahead and do that. The biggest reason is that he told me he has insurance which covers failures like this and if we can't get a good resolution, he feels he can just turn it over to his insurance. If I tell him how to do the job instead of of just making suggestions, the insurance is not going to cover it, so I have to tread lightly. OTOH, he is a very sensible guy and we are both in agreement on how to proceed.
If the test section doesn't look good, then I will suggest expansion joints in the concrete underneath the mortar.
The insurance adds a whole new dimension to the problem, especially since the contractor is willing to help me if it gets to that. We would both prefer not to have to use the insurance, but at least no one is going to go bankrupt if worse comes to worse.
Some of the things that make me feel good is that last year the efflourescence on the bottom of the headers was much, much worse than this year. Almost continuous along the bottom of the headers. The cause of these deposits is water coming through the tile, down the back of the headers, and evaporating from the bottom of the header.
Also, last year the grout was missing, as in totally gone, not just deteriorated, from about half the deck area, this year it is much better. And the efflourescence on the surface of the deck is much, much less than last year.
Looking at your pictures, I am getting pretty hopeful here.
The big difference is that you have steel under your decks and I have wood.
If one were more concerned with doing this absolutely bulletproof than saving what exists, would that kind of expansion joint be preferred over something like laying sheets of ~ 14 ga galvanized steel, overlapping, on top of the OSB and then pouring a 2" layer of concrete? This would give me concrete over steel, just like at your high school, with the steel somewhat free to slide on the OSB to relieve stress.
If you don't like that idea, I am going to print out your pictures and show them to Mike, the tile contractor.
/ A Question for Contractors #27
Dave,
Sounds like you got some good ideas and options. I like the test idea allot. See what it does and how it holds up. That makes allot of sense.
From what you've written, it sounds like you built the deck plenty strong. Probably stronger then allot of elevated parking pads that I've seen!!! Loads sure are not going to be an issue.
One thing that I don't understand is how are you controlling the side to side movement of the deck? The posts don't have any diagonal bracing on them. With all that height, I would think it would be fairly noticeable. Since you didn't mention any movement, and don't feel that's an issue, I'm mostly just curious how you stopped it from happening?
Eddie
/ A Question for Contractors #28
Probably a foolish question but is that exterior waterproof grout?
From those pictures it is evident there is water permeation, just can't tell if it is occurring before the tiles are lifting or only after the damage is done. Water penetration along with freezing temps would do the damage by itself independent of any other factors.
You mentioned the North side as being the least affected, to have freeze/thaw damage you have to have the thaw, it's as important as the freeze, often times as would be expected there is not enough thaw on the North side. So the constant colder temps are actually preventing that process.
Not familiar with your climate but I thought there was mention of below freezing temps. do you get snow and ice accumulation?
JB.
/ A Question for Contractors #29
You wouldn't actually need the steel. We use it because our schools are of "fireproof" construction, that is we use no wood. The metal we use is steel decking which is actually a fluted roof deck, and the concrete is somewhat locked into the flutes and moves with it. Again the coefficient of expansion of metal is more similar to concrete/tile than wood. You can accomplish the same thing by just putting a slip sheet down over the wood, such as 15# felt.
/ A Question for Contractors #30
Been following;
I like the idea of 'controlled cuts' in the concrete base (to co-incide with a grout line).
That would eliminate any expansion related causes.
Also you mentioned a treatment to waterproof the concrete, could it be a silicone based product? that in itself could explain the lack of adhesion also might that product simply be filling the concrete pores and preventing the tile morter from adhering?
For outdoor waterproofing I seem to recall that one was to add a seeler to the grout and that would prevent water infusion.
I tiled my outdoor entry slab last summer and biggest problem was that the slab sucked the tile thinset dry before I could lay a tile so I simply wetted the slab before trowelling the thinset. The winter here went to -30 and now that all is melted/thawed a few times I can report success.
I have to confess, I didn't design the deck myself. The general contractor who built it just made it that strong, possibly because he had worked with me for a few months before he built the deck.
The deck certainly seems stable, but I know that doesn't really mean very much.
I think its stability comes from the fact that there is an OSB diaphram under the concrete and tile. It acts just like a shear wall, lying on its side instead of standing upright. This stiffens the deck in the horizontal plane, preventing the outboard edge from moving in a direction parallel to the inboard edge. Cross bracing the posts would certainly be another way to get stiffness in this plane, but I think the OSB is sufficient.
There is a very substantial retaining wall/foundation along the south side of the house, which can be seen in the picture which includes the garage doors. Even though the wall is very tall, it was engineered and then I asked the subcontractor who built it to double the amount of re-bar in it. He balked at that, because it would involve a huge number of pieces, so we compromised. Everywhere the engineer called for #4 bar we used #5, and where he wanted #5, we used #6.
The floor inside the house is at he same level as the deck and again acts as a diaphram stiffening the structure of the house at exactly the attachment plane of the deck.
One of the pictures shows the attachment detail of the header to the retaining wall. There is a heavy steel seat for the beam, secured to the retaining wall by eight 3/4" bolts. I think the weakest part is that the beam itself is only secured to the bracket with two 3/4" bolts through the bracket.
The place where the grout is deteriorating the worst is very near where the beam is attached to the retaining wall, which is the spot I would expect the least movement in the deck.
If anyone can educate me as to why I am wrong, I would love to hear it, because it would solve the problem.
/ A Question for Contractors #32
Dave,
I am a general contractor and I do all the work myself. I too stand by my work as your contractor is doing. It is nice to hear about a good contractor for a change. You are being very fair to him.
One thought is epoxy grout. I did some research for a client, but we decided not to use it. It is water proof, but expensive. It may cost less than the grout you mentioned. I think expansion may be an issue too. When installing Hardiboard you leave an 1/8 inch gap between boards for expansion.
I have used a material on concrete floors for fracture control that is a peel and stick type of material that cushions the tile. Clients have dropped wine glasses on the tile floors with this material installed without the glass breaking.
Also I use a product called Flexibond which is a flexible ceramic tile adhesive with good results.
Cary:cool:
/ A Question for Contractors #33
We had a deck built in a manner pretty similar to yours on a house a few years back. Similar size too, with tile over plywood.
Before tiling, the entire area (of plywood) was primed and painted with a flexible waterproofing membrane, reinforced with fibreglass matt, which wrapped up the wall about 1 foot, and over the outer edge.
The tiles were then laid onto this waterproofing membrane with a 2-part flexible acrylic tile adhesive especially for use in areas subject to movement. The product we used was called Kemflex from memory, and carried a 25 year guarantee.
The grout was treated/mixed with another product that gave it flexability, i'm not sure what it was called, but you used a regular floor grout and instead of water you mixed it with this which both waterproofed the grout and provided the flex.
10 years on it still looks great, although some of the grout does have fine cracks (none is loose though) and no tiles have come loose.
/ A Question for Contractors #34
Boy Dave this just isn't your year for houses. The new house is very nice by the way.
As to the original question I think you are being fair by paying for the materials. It is also good to hear that the tile guy and contractor are working to fix the problem with you. I do kind of wonder if the thin set/grout manufacture who recommended the material that is failing should not be called into the mix.
Here for outdoor wet applications the thin set of choice would be epoxy based. It is the same material used to tile swimming pools and has a proven track record. I have used it and it is not as easy to work with but it sure does hold once it is down.
Someone mentioned the compatibility of the waterproofing agent, Redguard, and the thin set used. That would be something to check out in my opinion. I see Reguard used often and tile is set directly on it but I believe you can't use all types of thin set over it. Worth checking.
Dave check out Sheet Membranes & Shower Installation Products for Tile & Stone They offer tile materials for outdoor applications and have some PFD detail files worth looking at. The tile guys I work with think highly of the Noble products.
MarkV
/ A Question for Contractors #35
Dave,
Thanks for the explanation. It sounds like you way over built it and have everything covered. I'm out of ideas and now fall into the clueless category. The tile coming loose near the cement wall really destroyed all my theories as I agree with you that is where there would be the very least movement.
Since it sure sounds like nothing is moving on you, then it goes back to the thinset being the issue. There are a variety of brands and types designed for different applications. I can't believe you had two bad batches of it, or that he used the same type the second time that failed the first time, so it all comes back to the test area and trying another type of thinset.
Keep us posted, it's an interesting situating where everything sounds like it was done right, and then some.
Eddie
/ A Question for Contractors #36
Could water be getting trapped or pooled at that spot and then freezing?
Since we are really running out of ideas..... Could you put a gauge on the deck to measure if it is moving? Since I have no idea how much this would cost is it time to call in a PE with experience in this sort of thing? If the deck is not moving then it seems like a water issue?
Very pretty deck and the view is not bad either. :D
Later,
Dan
Arrow Quip 10' Corral Panel X 4 (A64047)
Arrow Quip 10'...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2011 FREIGHTLINER M2 112 CNG DAY CAB (A59910)
2011 FREIGHTLINER...
Excavator trenching bucket- one bucket per lot (A63118)
Excavator...
Three (3) John Deere 6000-Series Hood Guards (A63116)
Three (3) John...
