2006 Kubota 7610
/ 2006 Kubota 7610 #1
pilot-werx
Gold Member
Southern Maine
looking at a 2006 Kubota 7610 with a FEL and groundbreaker backhoe. has 2000 hrs and they will take 13K. Good? Bad?
/ 2006 Kubota 7610 #2
That's a lot of hours for a 2006. I think $11K would be a good price.Make sure that Woods backhoe is a sub-frame mount.
/ 2006 Kubota 7610 #4
That's an awful lot of hours. It would have to be the deal of the century for me to bite. So cheap that if you had to drop 2-3000 on repairs you would still be ahead on price.
/ 2006 Kubota 7610 #6
I was just researching this model myself. There is one locally (Winnipeg, Manitoba) private sale, no hoe, has fel, hydro, 200 hrs, asking around 10.5k USD.
/ 2006 Kubota 7610
sorry that was a typo, it is 200 hours not 2000.... yes that is the tractor in Maine.
/ 2006 Kubota 7610 #10
Well that makes a difference 1800 less hours now 13000 doesn't sound like a bad deal. Good Luck.
/ 2006 Kubota 7610 #13
I wouldn't run one bigger than 4 foot. As far as comparing to the BX, they are similar in HP, but the 7610 has more ground clearance... longer wheelbase, etc.
/ 2006 Kubota 7610 #14
What is the biggest bush hog that the 7610 will take? Also, how does this compare to the BX23?
A 4 or 5'-er would be all I'd want to hook onto the 7610 at 21 / 24 HP.
$0.02
/ 2006 Kubota 7610 #15
i have run a 5' on mine with no problems through very tall grass (over the hood) & small saplings. it was a light duty model though.
/ 2006 Kubota 7610 #16
I second the 4 footer, that's what I run on mine and it's a good fit. HP is the same but I think the B7610 makes the same HP at lower RPM than the BX24.
Horse Weathervane (A61574)
Horse Weathervane...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
Adams High Clearance 5 Ton Spreader (A63688)
Adams High...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
Caterpillar 12H/140H/160H Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
