RTV900 diesel cap
/ RTV900 diesel cap #1
Nwood
Member
anyone found a gas cap that works on the early rtv900's?
finally got around to ordering one and it still doesn't fit right.
Thanks,
D
/ RTV900 diesel cap #2
The fuel cap on the early 900's was a problem and some dealers even replaced the tank and cap to stop the cap from leaking, have heard that is the only way to fix it as just replacing the cap doesn't work. On another site, some have said that adding another O-ring to the cap did the trip, that would be two O-rings stacked in the grove in the cap, then the cap will tighten far enough to seal. Evidently the cap won't screw on far enough to seat with just one O-ring, cheap fix if it works for you.
/ RTV900 diesel cap #3
I agree with milkmans post.My 2006 kubota RTV 900 had the same problem,it was resolved with a new fuel cap.I have also read the tank may need to be replaced.I would try to get in touch with your local dealer or Kubota customer service as they know this was a problem.coobie
/ RTV900 diesel cap #4
We also had the leaky fuel cap >>>>
Dealer give me a new one ( cap ), didn't work. ....
He ended up replacing the tank and cap....
Now, I was told by several dealers, that the threads on the tank where different than many of the caps. That's why they were replacing the tank along with the cap that came with the new tank. So that the threads would match up proper ......
Even after the new tank got replaced, it would still try to leak, but very little if it was not tightened up really tight., so I did what others has done, and installed a second gasket on the cap and it works good. Still a bi*&^ to get off sometimes, but doesn't leak now ~~~~~~~
This is what I found >>>>> On Both caps, the words - - - KELCH MEQUON MI - - - on on the underbottom of the cap. BUT, the difference is after the WI, is a number. Now, the cap that DON'T leak, has the number 2. The original cap that came with the machine from the factory has the number 1. >>>>>>. THE NUMBER ONE LEAKED TERRIBLE WITH THE OLD TANK !!!
Don't know if it means anything or is going to help, BUT , if one goes to the dealer for a replacement cap. Look at the bottom and see what number it has.
Before the dealer replaced my fuel tank, he sent me a cap that said " DIESEL " on the top. I tried it on the old tank, and it did not work, it leaked worst than the origianl cap. I gave the " Diesel " cap back when the replacement tank got intalled.
Both caps that I have DO NOT HAVE DIESEL on the top !!!!!
WHAT NUMBER DOES YOUR FUEL CAP STATE ???????
~~~~~~~ two guns
2017 Ford Transit 250 Cargo Van (A61573)
2017 Ford Transit...
3015 (A56857)
3015 (A56857)
John Deere 12in Channel Tooth Bucket Excavator Attachment (A64194)
John Deere 12in...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
