Getting in to small squares
/ Getting in to small squares #1
NDRA
Northwest Missouri
NH TD5050 IH 966 IH 706 IH 574 Ford 5000
Hi. I am looking at getting into square baling. I dont know much about the balers and need some advice. I found a 214T that is kindof close to my area. John deere 214t square baler
I am looking to start out a little smaller and build up. This year I am wanting to put up about 20 acres of straw and maybe 300 bales of alfalfa (depending on the year and if we have enough for our cows) I may also buy some big rounds and put them through the baler and resell them. Any advise would be great. I have attached a couple more photos of this baler.
Thanks
Nathan
/ Getting in to small squares #2
The first year is always the hardest. I had more problems the first year to list, but I learned so much about it. After that, it's just the little things that happen. And remember, don't beat yourself up if something breaks down. Just calm down and get it fixed. If it rains on the hay, it rains on the hay. theres nothing you can do about it.
/ Getting in to small squares #3
I would look more for a 336 JD. Tons of them out and around for sale. Not to say this one is a bad unit, can not tell from 2 pictures. Look to see how thick (or thin) all off the metal is on the baler. Look at all sides of the bale chamber, that is where it would wear through 1st. Look at the axles, make sure they are straight and not bent or cracked. Look at the bottom of the knotter and the tips of the needles to see of it looks like anything has been hit or rubbing. Look at the area the plunger travels in to see if any grooves.
If this baler has been sitting, how long has it been sitting? Over time bushings and bearings set up and will go out fast one you start using it again. Look the hitch over make sure it's not cracked. If you to buy it look at the bolts that hold the hitch on and I would replace it is it shows any wear.Over time the action of the plunger going back and forth puts stress on these parts.
/ Getting in to small squares #4
Hard to tell from the pictures, but it looks pretty weathered and doesn't appear to have been used in a while. I'd pass on it. I just got rid of a IH-37 that was in much better shape for about the same amount. I got tired of the pain and suffering.
USING an old baler is like boiling a frog.....over time you don't notice the increased pain. BUYING an old baler, is like jumping into the boiling water....the pain starts right from the beginning. When I finally had enough, I looked at a lot of used balers. There is no doubt that many would have served my needs, but the difference in price between the ones in very good condition and a new one was too small. So I bought a new green one.
There is nothing wrong with old hay equipment, I use a NH 456 sickle mower, a NH 256 rake, and pick them up with a NH 1000 stacker wagon. They all require maintenance but they rarely breakdown in the field. If the baler was going to give me trouble or break down, it was always in the field. Getting parts was always an issue. The older the baler, the more expensive the parts in both time and money. At least with a JD or NH you can get the parts. That won't be the case with a lot of the other brands. Over a short time you can easily spend 4-5 times the price of an old baler trying to keep it running.
When I bought my old baler it was in great condition, it lasted a long time and served me well. If it hadn't been a problem I wouldn't have replaced it. The guy that bought it has another one for parts so he knew what he was getting into. I'd suggest that you rethink your budget and plan on spending the money to get a decent baler. They're usually pretty worn out when the price is below $2000. Good Luck!
I know I can't expect a whole lot with the price. My first baler probably wont be around to long, I just need it to get started. I am also looking at a NH 237. New Holland 273 Square Baler
Does anyone know how much needles are and how easy they are to replace?
I shouldnt have a problem with wet hay, because we will just put it up in rounds if all else fails.
/ Getting in to small squares #6
Needles are expensive. probably round 200 a piece. If both are broken the baler jumped time and broke them. Sometimes you can weld um and thats not a very permanent fix. If you do get the baler it will need retimed. That 214t looks in decent shape. Ive got a massey 12 that i got for free when I got into squares and it hasnt givin me any trouble on older balers its hit and miss theyre not all bad
/ Getting in to small squares #7
Thanks
Nathan
Here's what my MF-124 two-twine baler looks like
Bought it last April for $2000 right out of the field from the seller who used it the day before to bale 35 acres.
That 214T you're eyeballing looks a little beat to me and probably needs quite a bit of servicing before it's ready to bale.
/ Getting in to small squares #9
I dont know NDRA baler looks, well rough. Rust in chamber, stored out side older model, them kinda things is scary. I'd go look at the NH 273. Hopfully its a little better.
I agree. The 214T does look rough. The NH was sold but I have been on craigslist a little today and have got a few replies. One is a NH 275. It also looks a little rough though. The guy bought it not to long ago and said he went through the knotters and put new knives on it, but it has been outside.
I also found a JD 24T. The guy had bought it about 3 years ago and then it didnt sound like he used it or not very much if he did. Him and his partner just ended up using something else. He said that he had someone with him when he bought it that knew square balers and said that the knotters looked good and that it looked decent. He has kept it in the shed since. He figured if someone could use it he would get rid of it. I may get some pictures of it in a few days.
Thanks for the replies and keep the advise coming. Like I said, I am just looking to start out a little lower and build up once I get started. I've put up a lot of big rounds for the dairy cows but we havent done any of our own squares (we dont use many) but I would like to start doing some to sell.
/ Getting in to small squares #11
Ummm, hay still inside chamber... how long outside?:eek: Hopefully that 24T Looks better than the last two!!!! Shed stored, thats half the battle won there. I think new holland is hay implement king, but have heard of the older balers, some parts is no more for them. Cant verify that though. long time ago, 87' ish, I baled 1400 bales in a row with not one glitch with a 283 NH baler till the knot I tied the twine spools together busted:eek: Baled with a new 580 NH, large chamber, thats a hungry beast:D
/ Getting in to small squares #12
I would stay away from the 14t. The pickups are notoriusly bad. Some will just push the hay in front of the baler and very little will go into the the chamber.
Is it the 14T or the 24T that are known for having bad pick ups. I'm still working on finding a decent one that has been shedded because I dont like the idea of any baler sitting outside all the time. Especially with the knotters on square balers.
Just a side question.... Does anyone know anything about last years models of Brush Hog utility vehicles. We are looking at a tractor and we may through that in the deal because they are needing to get rid of it. I dont know the model because I didnt look very close but it was forest green.
Thanks
/ Getting in to small squares #14
I can only speak from experience on the 14t. Needs perfect conditions to bale properly. JD knew it too. They sold a hay compressor as an option, to attach to the pickup. I doubt if you could find one these days.
Hi guys. Thanks for all of your help thus far. Here is the newest option (not sure what I think yet but what are your opinions of it) Heres the email. It is a NH269
bought the baler Feb 1996, and have been baling about 400 bales every year except last year. Didn't have the time last year so I big baled everything with the used New Holland big baler I bought last March. After using the baler, I always clean it out and grease it so it's ready the next time I use it. I don't have a shed to store it in so it shows being outside. Since I've owned it I've replaced several of the pickup teeth, and the rods that drag the hay towards the chamber. I've got a spare belt and pickup teeth along with the owners book. If your like we can unroll some hay and run it though it. Main reason I'm selling it is due to the big baler I have now bales 1000lb bales and with an unroller, I can unroll what I need for those times I used square bales. I'd take $850.00 for it.
Thanks guys
/ Getting in to small squares #16
I think I'd go $850 on it, I stood on a wagon behind a 269 for several years growing up, rarely ever missed a tie and took a lot of punishment.
/ Getting in to small squares #17
I am not sure what area you are in, but I updated to a NH 315 last year and saved my NH 68 as a backup baler. I completely went thru it in 2003. I have attached some pics. The pics was after I finished restoring it. It even has new wheel bearings and implement tires. All new pickup tines as well.
PM me if interested. Here is a link for a couple pics.
http://mnfarmall.com/john-nh68.htm
I know I do love my Deere tractors but I prefer a New Holland baler. Parts are resonable and still can get most off the dealers shelf. Most parts were carried on in the later models. They are also not to bad to work on.
/ Getting in to small squares #18
Well, you know my feelings about old balers, but for $850 that 269 looks pretty good. It's weathered but the from the picture the chute doesn't look bad. I'd unroll a bale and see it work. You may have found a diamond in the rough! A '96 baler isn't that old and it doesn't sound like it's been worked very hard. Good Luck!
/ Getting in to small squares #19
Needles for your MASSEY might be $200 a piece, but $200 will buy a PAIR for a NH 273.
How are the NH 269's to work on. For how this one looks in pictures (we'll see how everything looks up close and personal this weekend hopefully) I dont think I could pass it up for the price.
Also when looking at it what all do I need to pay close attention to . I know the bale chamber because thats where a lot of wear occurs, but what else do I need to look at specifically mechanical wise.
Thanks
2022 Bobcat T66 R - Series Skid Steer (A61166)
2022 Bobcat T66 R...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
Oxy-acetylene Torch and Regulator Rig (A63118)
Oxy-acetylene...
FORKS (A63276)
FORKS (A63276)
2004 International 4300 Box Truck, VIN # 1HTMMAAL74H678307 (A61165)
2004 International...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
