Welder's Auto-Dark Helmets
/ Welder's Auto-Dark Helmets #1
Scotty370
Buffalo, New York
318 John Deere, 4200 John Deere, 1947 John Deere "M"
Well, it stopped raining/snowing, long enough for me to get up the nerve to strike my first arc on the new Lincoln! Thanks to all who have contributed to helping me get started. Welded yesterday on some 1/8" & 3/8" rectangular mild steel, tube stock. Actually found it much easier to strike and hold an arc, than I thought! My first venture had me using: Lincoln 225 AC/DC box, 7018 rod, 3/32" dia. welding mode DC-neg, at 85-90 amps. Had some beads, that I might even admit to! Big question on welding helmets though. I used my son's SpeedGlas helmet that probably 8-years old. I only say that because the technology may have move forward. My difficulty is seeing the weld 'puddle' at all! Just seems too dark! In fact, spotting the seam, or gap, is tough! It's got a darkening selector from 9-13, but seems to make no difference. Maybe, it's not working! I want to buy a new Auto-Dark helmet, and am wondering what to look for. Cost isn't and issue as oppose to eye safety. HF sells Chicago helmets, buy they're all Chinese. I think they put more effort into the 'graphics', that the guts! I don't need to impress anyone with how I look! Just want good quality protection that I can see through! Also, how do you tell, how 'light' is too 'light', in the shade department? Any suggestions? Sources? Etc. ~Scotty [PS: Thanks Willl, for all your help!;) ]
/ Welder's Auto-Dark Helmets #2
Maybe the batts dead in the SpeedGlas ?
Hate to say it, but been using a cheap HF auto helmet for 3-4 yrs, no complaints.
Too light ?, oh, you'll know.
It'll be the 'other' version of not being able to see your puddle.
Followed by a 'white spot' stuck in your vision afterwards.
And in the AM, a handful of sand in both eye's. Fun stuff.
Joking aside, dial it back to where you just loose the glare and then a tiny smidgen more.
/ Welder's Auto-Dark Helmets #3
Speedglass,Lincon,Miller all have good helmets. Stay away from cheapos. In my experience the higher the amps the darker the shade I run.Any of the settings 9-13 are safe. Try to focus your vision on the puddle and not the arc. As I have gotten older I have to wear glasses when welding close . If you can't see good you can't weld good.They make magnifiers for the hoods if this is the case.
Bill
/ Welder's Auto-Dark Helmets #4
I have a Miller XLix - not top of the line, but not cheap, either - and a Harbor Freight model. I find that I reach for the HF before the Miller.
As far a UV protection is concerned, I don't think the darkness level makes much difference. I just lighten the lens until I've got enough light to read the puddle without excessive glare. I'm a hobbiest/home/repair weldor. So I don't weld 8 hrs/day which might make a difference, but I've experienced no ill effects from that approach.
/ Welder's Auto-Dark Helmets #5
Interesting, as I have the same problem with my three year old Optiva welding helmet. Even on the lightest setting, I can't see a blessed thing........ even welding outdoors in bright sunlight. Before I strike an arc, its no problem....... but when it darkens, it is waaaay too dark. I hate to spend another couple hundred on a second shield........ but too often my welds go off track due to the fact that I can't see what the heck I'm doing.
/ Welder's Auto-Dark Helmets #6
I've never owned anything else other than a standard helmet to compare to but I really like my Miller Big Window Elite helmet. I second the opinion on replacing the batteries in the Speedglas before buying another,unless this your reasoning for getting a new one.:D
Clarity, isn't the problem. I wear cheapy 'drugstore readers' (1.75) for close work. They fit under the hood just fine. Will, I ruled out the battery, because it 'darkens' at first flash. But it's too dark! Maybe the battery is marginal and not running the gradiant. Cheap first fix, new batteries! Can't see the 'puddle', HP! Gotta be the batteries, or the darking gradient circuit!
/ Welder's Auto-Dark Helmets #8
Looking at the 'new' SpeedGlas helmets user manual, says it has a low batt symbol. Maybe yours does also ?
/ Welder's Auto-Dark Helmets #9
I'm also a beginning welder with a little Sears wire feed 120 volt machine.
I grabbed myself a Northern Tool auto darkening helmet on sale for $48. Seems to work pretty well for me, and it's solar powered as well. I just leave it in the garage window to soak up the light when it isn't in use.
So far the adjustments on it all work well.
/ Welder's Auto-Dark Helmets #10
/ Welder's Auto-Dark Helmets #11
These helmets have been discussed quite a bit. Some swear they are no good, and will only use brand names. So be it, a lot of things are that way in life, you do what you gotta do. The auto-darkening helmets do what they are supposed to do, and you can't ask any more out of them. The high priced ones do the same thing. They probably use the foreign electronics anyway. I will not tell you to go with one or the other, that is your choice. Get one of each if you want , and make your own judgment. I always look to the side of the helmet on the first flash to see if the auto-dark electronics are working. There is a definitely problem with a too dark lens. If it's under warranty, take it back.
Wayno! With all the stuff I'm trying to remember, now you want me to throw 'chin movement' into the mix? I'd be welding, say "Holy $h*t", and blind myself! :D. I like the Auto Dark, just gotta get it working right! ~Scotty
Willl -I just checked their (SpeedGlas) web site and looked for an owners manual. They don't have it for the 9000V, but some that are simular. It does have a low batt led that's not lit, but I'm going to change them anyway.
J_J-Can't see why anyone wouldn't like them, or are you talking about the solar-powered ones? I've gained a whole lot more respect for the fellows that can 'head-flip' the shield, and weld!! ~S
/ Welder's Auto-Dark Helmets #13
I was wondering what powered them. Is it recommended to leave them to charge often? mine sits face down in the dark corner. thought maybe the light from welding charged it up but if I go months without it does it shorten the life?
/ Welder's Auto-Dark Helmets #14
Like I said, I'm no pro. The thing works fine for a casual user like myself. I can see the workpiece good and it darkens at the first hint of a flash. It does what I need it to do.
I would have grabbed a helmet at the local Lowe's, but there was no middle ground there. They had 2 helmets. A non automatic $28 cheapie or a $130 self darkening model. I wanted an auto darkener priced somewhere in the middle. It didn't make sense for me to spend big $$ on a top of the line model for the little piddling things that I do.
/ Welder's Auto-Dark Helmets #15
HF $49 cheapie 9-13 auto here and have to say it has worked well for the 3 years I've used it. tried out a few of the big $$$ ones and didn't see a difference other than they had more comfortable headbands. If I were welding all day everyday maybe I'd consider a better one, but I don't, so I'm happy with what I've got..
/ Welder's Auto-Dark Helmets #17
My 'cheepo' wotked very well. A flick of my BIC would activate it instantly.
Presume it had rechargeable battery, solar powered but being always stored in dark the battery is now dead.
Anybody know about these? would it be 3 volt cell? could I pry the unit open and replace the cell?
Am I wrong or do I assume that constant usage would keep this unit charged from the radiated UV created by welding.
Sure tempted to unseal the unit and attempt to replace the battery if in fact one exists.
/ Welder's Auto-Dark Helmets #18
If it was a cheapo to begin with and doesn't work now, what have you got to lose? Give it a shot and maybe you'll discover something that'll help someone else out here later on. :D
Piloon- Rest assured, there is a battery in there somewhere! I just replaced 2 (3v.) in the SpeedGlas. Take note that solar-charged batteries are different that others! How do I know? Just replaced some in some little solar landscape lights. Instead of regular aa's they take the pricey rechargable Ni-Cads. Like I tell my wife when I'm fixin' stuff that's sealed- "Well honey, It's fix it, or wreck it time!"
/ Welder's Auto-Dark Helmets #20
Scotty, it does seem like extra movement when you first use it. But you just drop your chin to partially raise the lens. So you can position the welding gun. Can you chew gum and weld too? It ain't even that complicated. I am a newbie to welding, and I have only used it on one project. And after a short time it became second nature.
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2007 International 7500 sba Flatbed 6x6 Truck (A62679)
2007 International...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
72"Skid Steer 4 in1Bucket (A62613)
72"Skid Steer 4...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
