JD 2720 - Need opinions
/ JD 2720 - Need opinions #1
labsrus
My wife and I are going to buy a compact tractor and have decided on a John Deere. I have researched a lot about the 2720 and I am just wondering if it will be a short lived model? I also see that some people are concerned about th2 speed range. We will use it mostly for mowing around fence lines and fields but will also need a bucket for lighter jobs. The 3000 series are just too big for what we need.
Is the 2720 a good choice in a tractor - engine, etc? Any opinons are helpful.
Thanks for helping a newbie out!
/ JD 2720 - Need opinions #2
I think that the 2720 is a fine tractor, and will handle your chores well. It is more expensive than the 2320, and 2520, but that is a personal decision. For running a rotary cutter either the 2520, or 2720 is perhaps a bit better than the smaller 2320, but all will run a 4' cutter. Do a search on posts by member "runner". He has a 2520 with both a 5' rotary cutter, and a 6' rear finish mower. He bought his before the 2720 came out. I know that he had to add double wheelweights to the rear wheels for using those cutters on slopes, but I don't believe that his rear tires are loaded with rim guard. I do use the mid range on my Kubota often, but could be very happy with a JD, and the 2 range also. I don't like going a whole lot faster than the low range on the JD's will go on rough ground myself. Now if your land involves some distance, and smoother lanes for getting from one area to another, that might be different. All in all, you will find the 2000 series limited more by weight than by hp, or number of ranges. They can do an awful lot of work though! Mine is 26 hp, and I ran a 4" chipper most of the day today with no problems. Some pine branches were full capacity, and 15, or more feet long, and it gobbled them right up. You might manage a 6" chipper (if weight isn't a limitation) with the 2720.
/ JD 2720 - Need opinions #3
I was in the same situation, I wanted a small frame tractor with higher HP/torque and PTO HP, the 3320 would have been too large of a foot print for my current needs. So far the 2 range has not been a problem but I still need to use it more for a better call on that one. I like the 2520 but wanted some extra insurance in the power area for now and down the road, so far, the 2720 is a nice machine for a small frame tractor with enough power to add a little insurance for my needs. I rather be a little over kill then not have enough of a machine. Good luck with your decision.
/ JD 2720 - Need opinions #4
This is just an opinion based on many years working with tractors take it for what its worth.:D
You would be better off with a tractor you think is a little too big in most cases. I just checked the specs on the 2720 and 3720 tractors and found the wheelbase to be similar and turning radius to be within a foot of each other. If you notice how many people upgrade after a few years to a larger tractor you may save yourself this expense. Right now discounts and cheap financing is available and in a few years with inflation the prices will be much higher.
You can fit a 3000 series tractor just about anywhere you need to go in a residential setting and for smaller areas a riding mower should fill in. The 3000 series has a lot better choice of implements that will do a better job too.
Just something to think about before you jump in:confused:
I use an L130 riding mower with a 48" deck to cut grass, a 110tlb for loader and backhoe work and hopefully this week my new 4520 without fel will arrive.
I am hoping this will give me some flexibility while providing me with enough physical size to do the various jobs. My point I am trying to make is that the slightly larger equipment will not limit you near as often as having a smaller piece of equipment that is not up to the job.
Hope this makes some sense, if not I guess I just started a war with 2000 series owners here.:eek:
Steve
/ JD 2720 - Need opinions #5
I don't think you'll start a war, Steve. You just restated most of the "high points" that the higher Hp crowd of 2000 users have discussed here on TBN - on and off.
The 2720 has the same engine as the 3320. And for around $2,000, you could move up into a 3320. So, for nearly the price of a new bush hog mower; you can have a tractor with 3 transmission ranges, greater hydraulic power for a backhoe or front-end loader, more 3pt capability and tractor weight to manage larger rear implements.
That said; many of the folk's that buy 2000 series machines fully appreciate the scope of their projects and how they plan to manage their properties on into the future. A 2000 series fits just right and they're fine with their decision and don't look back.
Other's haven't made a good assessment of how well the tractor really fits with the current objectives for their property or they have expanded their acreage or changed the way they use the tractor. Either way; they're looking to upgrade.
If you know what you want - and want what you know... go for it! Great machine - great dealer network - likely the best part's support in the industry - and Deere tractor's hold and hold and hold their value.
Best of luck.
AKfish
/ JD 2720 - Need opinions #6
AKfish, well thought out response, you know if a person is new to all of this the larger tractor looks much bigger. If though you are looking at one step up in size the difference in manueverability is not much difference.
FWIW, one of the most manueverable tractors I have ever had was a 3020 70 hp diesel with trycicle front end. I did not have to use it on slopes though. I could put a heavy duty 3 pt bush hog on it and it was a manuevering fool in the woods.
Steve
/ JD 2720 - Need opinions #7
Steve
Yep... stand real hard on one of the brake pedals and jam the throttle another 1/4 way... that front end will REALLY swing around!! (I used to be 16; too!)
Although, my wife will argue that not many year's have passed for me - MENTALLY! :eek:
AKfish
Wow - I can't believe all the responses! I am really glad to get everyones opinion and not have a wars going on. We do have a larger JD for the "big" jobs, so that is why we where thinking the 2720 would be nice for the small jobs. I will post what we decide on - maybe by next weekend.
My wife also said a big thank you for the replies. It just helps a little with our decision.
/ JD 2720 - Need opinions #9
labsrus,
Hard to say if the 2720 will be a short-lived model or not.
As mentioned, I have a 2520 with loader, 60 inch rotary cutter and 72 inch rear finish mower to handle 6 acres of fairly rough and very hilly ground. I chose the 2520 for the smaller size and maneuverability over larger machines.
Also, the bigger machines look, and from some reports, are, a little more "tippy" on the hills. I will say that I have found the 2520 to be rock solid on 20 degree slopes.
The biggest problem I have with this machine is, like most tractors, it's hard to put the power to the ground because there isn't enough weight. As mentioned, I have three wheel weights per tire on it and did not choose to load the tires due to issues mentioned in other threads on the topic.
That being said, if one did not have a problem with loading tires, I think the extra weight would be a BIG help for this machine and most who have loaded tires on one seem to agree with this.
As for the two-range tranny, for my use, the high range is just too fast (rough ground, hills) and is only usable for transport. There also isn't enough power to operate in high range on hills, particularly if your're working the machine.
The higher HP on the 2720 might help this or not, I haven't tried one. However, as mentioned, for me, the high range is just too fast, even if I had the power for it.
I have not had any problems, power-wise, running either the 60 inch RC or the 72 inch RFM. However, more power never hurts and if I was buying one now, I'd go for the 2720 just to have the extra HP.
For what it's worth, and for my purposes, I just wish they had geared the high range lower, like about halfway into the upper end of the low range. To me, that would be perfect for giving faster movement for using the loader and mowing, and I don't need to go 20 mph with a tractor anyway.
Best of luck in your decision, I think you will be happy with your choice. I am entering my third summer of service with the 2520 with no problems.
runner- We also have some hilly areas but not real steep. It would be mostly used for mowing around fences and around the fields but once in awhile a small meadow or two. We do want the belly mount mower and not a rear mount. It sounds like this model would be good for us and with reading about the 3000s being a little tippy, my wife may not like that feeling on one! Thanks for your input.
Some of these pictures we have on Flickr may show a little more of the property we would be mowing - if anyone is interested in looking - vmax4coco's photosets on Flickr
/ JD 2720 - Need opinions #11
labs,
Absolutely beautiful place you have there.
I have an antique bike myself, although it wasn't intended to be. I just bought my 1974 Raleigh Grand Prix new and it grew old with me. Guess that makes me an antique too!
Also have the 62D belly mower for my 2520 and it works as advertised. Delivers a very nice cut and is easy to mount/dismount. See attached pic of the machine tackling one of my 20 degree slopes.
/ JD 2720 - Need opinions #12
First of all that is a very nice place you have and I enjoyed looking at the pictures.
Second if you are responsible for getting it in that shape then you aren't a newbie, try veteran instead.
Third, if you have a larger tractor currently then the 2720 should be fine for the fill in tasks.
I can see using a 2000 series if backed up with for example a 5000 series. I just don't think a 2000 series is large enough to be all encompassing to be clear.
Steve
/ JD 2720 - Need opinions #13
Go for the 2720 and don't look back. I have a 2520 now (among others) and really like it but I want the 2720 just for the horsepower difference. If you can afford the price, then go for it. Life is short.
/ JD 2720 - Need opinions #14
Now I feel like I'm going over kill! I only have 6 acres to play with and I'm going with the 2720. I thought the 2520 would be to small. I plan on doing a lot of backhoe work though. I alos got the 72" belly mount and the loader. I liked the extra hp in the 2720. I'll be sure to let you know how I like it when It gets delivered .....any day now.....!
Also, I got to talk to you about the suspension in your V-max, I got a 600 with no (at least thats what it feels like) suspension in it.
/ JD 2720 - Need opinions #15
Great pictures! Thanks. Very nice place.. and quite a selection of critters, too!
Best of luck with your new tractor.
AKfish
/ JD 2720 - Need opinions #16
I had a 2520 with 200cx and 46 bh (13" bucket). Used it to dig sons crawl space 36'x72' x 4' deep. Took a while but it did it.:D Then I dug a bunch of trenches, some at the max 6 1/2'. But, the hydraulics acted up.:mad: Bucket would only go up 3/4 of the way and it had no down pressure. Took it to JD and they replace PS assy under hood (down time 10 days). Well, now transmission made a bad noisy and had to keep turning the wheel to keep going straight. Gave tractor back to JD to fix. Was still down after 4 weeks and more parts coming, so I traded for 3320 with 300cx and 447 bh with 16" bucket.
Boy, do I love the 3320. :) 3 speed verse 2, doesn't need to be in N to start. 2520 would kill and was hard to get into N so it would start. Had filled tires on both but the 3 point on 2520 was old type and would rub on tires with my 6' blade. No problems on 3320 and its so much stronger and it can swing to left/right more.
Just look at the axles on 2520 and 3320. Big different, so much more meat on the 3320. It rides better (nice seat) and has tilt wheel. I ran both with wheels reversed. The 2520 would rub the front tires on the bh before I swapped tires. The teeth on 46 bh are very weak and bent right away digging rocks.
I had the 51" bucket on 2520 and 61" on 3320 (on the lot). I wished I had the heavy duty bucket, I'm bending top a lot doing big rock work.
The 3320 bh will do a lot more work faster with the bigger buckets and higher hyd flow. If I would do it again, I would go straight to 3x20 with large R4s (for more ground clearance) as I've been in some deep mud. The 300cx will lift a lot of weight in bucket but I move lots of big rocks around end up rolling 'em or pulling 'em.
ps: just did 72 hrs of bh'ng. Done at 1000 rpm and got almost 5 hr per gallon.:) Another nice thing is the bigger fuel tank.
/ JD 2720 - Need opinions #17
Don't know anything about the 3000 series. I have a 2320 and a 5325. The 2320 is perfect for what I bought it for--tight spots and mowing. Don't know if I had rather have a 2720 or not since I never have operated one. When I bought the 2320 I considered the 2520 but decided since I had a bigger tractor for bigger applications I did not want to spend any more money for a little more HP. Anyhow, its a great little piece of equipment for darting around tight spots and doing those jobs that would be a PIA to do with the big fella.
I intend to get a 4' rotary cutter to mow in and around my many oak trees. I understand the 5' would work just fine, but I want the narrower width. I have a 62D MMM which is a nice mowing unit, but think I had rather mow my rocks with the cutter than with the MMM.\
So no war intended here either, just my personal "druthers".
/ JD 2720 - Need opinions #18
I believe that the engine used in the 2720 is the same one that is in my JD1445 front-mower. If it is then you are in for a very sweet sounding, powerful engine. It doesn't clatter like a diesel usually does. Perfect for the size of the 2720. You will simply have plenty of power on hand. Especially running a 72" mower, you will have no problems at all.
Well, we bought a 2720 and hopefully it will be delivered here this Saturday. :)
Can anyone tell me how long from front to rear with the bucket on? I may need to make some room in the garage!
Thanks again for all the opinions. I will post some pictures of it, once we have it here.
1986 JOHN DEERE 843 (8) ROW CORN HEAD (A62130)
1986 JOHN DEERE...
2012 John Deere Z425 Zero Turn (A63116)
2012 John Deere...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
(2) 330 GALLON POLY TOTES W/ CAGES (A62131)
(2) 330 GALLON...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
