ford 4500 backhoe
/ ford 4500 backhoe #1
dirt clod
Gold Member
panama city and altha florida
Kubota L3300, m5700, case 580se
Have got 120 acres that needs refenced for cattle. need to clear old fence line. Fence is about 30yrs old. Mostly brush needs removed. Found a 4500. guy wants 3500. Says it is in good shape. Have not seen it yet. I'm told it has manual tranny not shuttle. I would think this would be better than the torque converter model for pushing. I know these torque converters get weak with age and use.I dont know yet if this is the newer model with the 3 cylinder or the older with 4 cylinder. I think this is built useing the 4000 model ag tractor. Anybody know anything about these old backhoes?
/ ford 4500 backhoe #2
They are good machines getting old though. One thing to look at is how much wear is on the backhoe. For that price you should be fine if it is decent
/ ford 4500 backhoe #3
A 4500 is a 3 cylinder. If it is in decent shape, $3500 is a swinging deal. They have very strong hydraulics. If you can handle a 4 stick machine, you can do a LOT of work with a 4500.
/ ford 4500 backhoe
Never used a backhoe b4 so I got nothing to unlearn to use the 4 stick. Whats differant about it compared to other backhoe controls?
/ ford 4500 backhoe #8
I like the 4500's better than the 550's that replaced them. Same backhoe and a little lighter. The 555's were a step up with a significantly better backhoe (no chain). My biggest concern would be the condition of the engine if it has high hours (more than 7000) and has not been rebuilt. You can get a pretty good feel for everything else from a test drive. Too bad you were not up north where you could check how easy it starts in the cold (good test of compression). $3500 is a good deal if it is in good shape, so-so if it is in need of a rebuild.
Kuhn FC400RG (A60462)
2018 International LT Automatic Day Cab (A62613)
2018 International...
Informational Lot - Shipping (A63689)
Informational Lot...
ROADTEC RX700 MILLING MACHINE (A62129)
ROADTEC RX700...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
2022 EZ-GO ELITE...
