Stubborn grease fitting
/ Stubborn grease fitting #1
Natureboy
Upstate NY
JD X728
Hey everyone, I've been a member since last November, but have been "lurking" since I got my CK20 HST in 2005. This is an incredible site and has taught me alot.
I have a single grease fitting underneath that sits directly to the front of the 2 fittings that are on the steering shafts. It wont take grease. I tried taking the front wheels off the ground to relieve the pressure, still wont take grease. Also, there is a few drips of thick fluid coming from the general area. Can I replace the grease fitting with one from TSC, or is it a dealer item? And should I be concerned about the few drips of fluid? My warranty expires this August.
/ Stubborn grease fitting #2
Just replace the zerk. I believe it's a 10 MM metric straight available at any auto store. Sounds like the front axle has been over filled maybe you better rercheck levels.
Rimshot
/ Stubborn grease fitting #4
As you need to remove it to replace it anyway, I'd start by servicing the zerk to make sure it is not plugged. Soak in diesel and work the spring loaded ball to see if that helps. You might also get a zerk "rejuvinator" from AgriSupply or a number of other vendors. These devices let you force light oil through the zerk without removing it. They work well for zerks that are just clogged with dirt or old grease but wouldn't do anything for a truly malfunctioning zerk.
I thought about the zerk rejuvenator, just figured it would be easier to replace. I assume they just unscrew, but was unsure about the size.
Rimshot, I think your right about the fluid level. About a month ago I noticed the fluid was just barely showing in the sightglass, so I added a bit . Shortly thereafter I noticed the slight leak. Did'nt put the two together until you mentioned it.
Thanks for the responses.
/ Stubborn grease fitting #6
The last time I was in HF, I picked up an assortment of all the SAE zerk sizes, and then another assortment of all the metric ones. Cost was ~$15 total for both.
I have one on my hoe that has failed, and no matter what size it is I can replace it now, and I can also fix any that fail on any machine in the future.
Why anyone would want to putz around with zerk rejuvenators, cleaners, etc. is a total mystery to me. On the upside, you might save 50 cents worth of a zerk, on the downside, you might be able to force dirt and grit through the zerk and into your bearing.
To me, it is worth the small change to not take a chance on doing that.
/ Stubborn grease fitting #7
Be very careful here. Some of the Kioti zercs are not metric or SAE. They are some goofball british one. For instance, the inside zercs for the steering rams that you mentioned above needed to be replaced on mine since I damaged one on trail debris. Easy I think, unthread and replace. Nope. I ended up finding them at a Kubota dealer after finding dead ends at the local auto places.
Kioti zercs are not standard.
/ Stubborn grease fitting #8
What I usually do is remove the zerk, attach it to a grease gun, and pump grease through it to see if it zerk is clogged.
When I was a kid, I would heat them a bit with a torch, and if it was actually the zerk, it would usually fix it. Nowadays, I have stopped heating them, because often the tiny little ball in them is plastic instead of metal. I could be mistaken on this, but at any rate, something happens to them that makes the ball not seal after heating.
Sometimes I find that the little path from the zerk to the actual grease holding area is clogged due to distortion (metal wallowed into the path). I have seen this even on fittings that have never been without grease.
I think this is what has happened to my mid mount mower idler arm. I'll have to take it apart to see, but it is a bear to grease.
/ Stubborn grease fitting #9
For the same reason that someone would putz around on a tractor to begin with. :)
You are correct that replacement is an option but as Highbeam points out the zerk industry has not seen fit to standardize particularly well. A big collection from HF might help and even HF can probably get zerks right but it is often faster to just use the rejuvinator. I don't worry about pushing through a little grit as the grease will flush that out immediately.
/ Stubborn grease fitting #10
I have trouble with that same fitting too. I have a pneumatic grease gun that hooks up to the compressor and that gun rarely will put grease in the fitting. I usually end up with a manual pump gun, and even then it takes grease very slowly, it must be a tight space.
/ Stubborn grease fitting #11
That's my understanding on the CK30. I just rotate the axle it's full range and work in the little bit of grease that the zerk takes.
Don
/ Stubborn grease fitting #12
i was just fooling with this crap tonight on that ferris ztr i bought....
some wouldn't take grease.....some i pulled out and replaced, they still wouldn't take grease...some i pulled and took a small picked and cleaned out the hardened grease and reinstalled.....they didn't take grease either.....
two i took the unit apart, cleaned, put never-seize (probably shouldn't), re-greased and put back together and they worked flawlessly....
the other are MUCH more difficult to take apart, clean and put back together....i'd really like to try one of those rejuvenators.....but even then it would be hard to get to them, let alone swing a hammer.....
i wish it were a simple as not putzing around and just replacing the fittings....i have the HF sae and metric fitting kits.......they are handy with all the junk around here that has fittings...
edit: i just found some that have a short flex hose.....i don't see how you would hit it with a hammer.....maybe you don't have to hit it as hard as i was thinking..........if i knew it would work, i'd order one today....
/ Stubborn grease fitting #13
My Kioti DK45DR HST Cab zerks will not take grease. Thanks, I will try your ideas tomorrow. I think the grease worms attacked them because of my lazy butt.
/ Stubborn grease fitting #14
Totally agree with comment by IslandTractor on page 1 about the Rejuvenator tool. I've used the Rejuvenator (note spelling) multiple times with no problem. Takes a little finesse and it's a little messy, and the operation might have to be repeated several times to unclog the fitting, but you get the hang of it.
/ Stubborn grease fitting #15
Never, Never use a Rejuvenator on angle fittings. The fitting will brake off the 1st time. If you replace the angle fitting with a straight one then you need to get the Rejuvenator in a straight line onto the straight fitting. That will never happen. The reason it was an angle fitting in the first place was because you couldn't get the grease gun onto the fitting. There was not enough room.
/ Stubborn grease fitting #16
Good point but you could wedge something behind the angle fitting before using the rejuvenator that would absorb the shock load. Your point is well taken but I suspect a work around is possible.
METAL GRAVITY WAGON (A64278)
METAL GRAVITY...
1991 FREIGHTLINER FLA-89 T/A SLEEPER TRUCK TRACTOR (CABOVER) (A67148)
1991 FREIGHTLINER...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2010 FORD F750 BUCKET TRUCK (A65054)
2010 FORD F750...
2007 Peterbilt 379 T/A Kill Truck (A64194)
2007 Peterbilt 379...
