My newest toy...
/ My newest toy... #1
KentT
Elite Member
Sevierville, TN
1993 Power Trac 1430 w/Kubota diesel engine
Ater surfing and window-shopping for weeks, in addition to kicking a few tires I bit the bullet and just put a deposit down on a new-in-the-crate 2008 model Rhino 450 Special Edition. One of these puppies...
After pricing both new and used UTVs of several brands, I found a deal on this one that I just couldn't refuse. $6999 on a new 2008 model (still in the crate) that had an MSRP of $9199. The out-the-door price from a NYC dealer was $7280.50, but I'll still have to pay the 5% Massachusetts sales tax when I register it. [:D][:D] This compares to an out-the-door quote of $9000 on a new 2009 base model Rhino 450 from my local dealer. I can drive a hundred miles or so for that difference!
That price leaves me enough in my budget to add some more goodies to it -- though certainly not all from dealers -- maybe ending up with something like this... This Build Your Own feature on the Yamaha site is neat! [8D][8D]
I won't be picking it up for a few days --likely next weekend -- they have to assemble it and prep it. The time will pass slow, I'm sure! [:D]
/ My newest toy... #2
You'll love it,I have a 2006 that I bought new(has 1,000 touble free miles now)Same machine as the 660/700 injected,but a lot better gas milage.I traded a 660 Grizzley that was a great machine but a bear on gas.I added an after market front rack,roof,windshield.
/ My newest toy...
I hope so -- I just thought it was a heck of package at that price. I just didn't see the need to go 45 MPH, and the 450 seem to fit my needs much better, based upon my research:
1. More pulling power at low speeds due to its lower (numerically higher) gear ratio -- i.e. a better (though slower) hill climber and rock crawler
2. Better gas mileage and perhaps even more reliability
3. $1500 or so less money...
Only negative I've found is lower resale value -- but with the upfront savings, I'm not overly concerned...
/ My newest toy... #4
Nice...very darn nice!!!
Looking forward to pics. :)
/ My newest toy... #5
I have been looking for a similar deal around here like that. I really like the Rhino's as an all-around work and play machine. Congrats on the find and post some pics when it arrives!
/ My newest toy... #6
i got the 08,700fi they are nice but i don't haul anything with it but for riding around you can't beat it. i hope you have fun. i hear the 2010 is comin out with a 2 seater can't wait to see them in full i seen some pictures but thats about it.
/ My newest toy...
I already have two different trailers I can tow with it -- at low speeds, since they're designed for garden tractors/SCUTs.
So, I hope I can live with the 400lb payload of the box, and it's 1200 lb towing capacity is pretty much par for this size vehicle... In fact, the little Mule was the next closest rival to this on my list, for my needs, and its payload and towing capacity is the same.
/ My newest toy... #8
well it will pull a trailer but i will tell you this it's gonna tear up your yard plus your gonna go through some tires one of the rhinos worst flaws is the rear end and it's inabilty to unlock. it's great on the trails but not so good in the yard or when pulling a load. as for as the 400lbs in the bed it will haul it but to me it's pushing it because of the cheap shocks they put on them now if you had some aftermarket shocks that could pop the rear end up and really keep it level then it would help out alot. some nice air shocks would be good that way you could just inflate for hauling and deflate for the trails. if you need anything for it let me know. i'm always makin something for mine and then changing my mind and makin something els so i then have the ole stuff layin around.
/ My newest toy... #9
I don't know where you are getting this but the Rhino has "On-Command® In/Out 4WD feature lets you switch between 2WD, limited-slip 4WD and fully locked differential 4WD with the simple push of a button." I have ridden plenty of them and in 2WD only one wheel spins (unlocked) in the rear until you go 4wd. It's a typical open differential with electronic locking. There is no need for an open diff in 4wd so I don't see any problem with this setup.
/ My newest toy... #10
the yamaha rhino has a locked rearend!! the locking and unlocking diferential in for the front. lmao that rear end is locked up 24/7/365 if you don't believe me go out in the yard and do some turns i ain't worried about the front diferential i already know it locks and unlocks i never mentioned anything about it. the ones you rode that only had one tire spinning in the rear must have all had a proken axle on the other side.
I don't know where you are getting this but the Rhino has "On-Commandï½® In/Out 4WD feature lets you switch between 2WD, limited-slip 4WD and fully locked differential 4WD with the simple push of a button." I have ridden plenty of them and in 2WD only one wheel spins (unlocked) in the rear until you go 4wd. It's a typical open differential with electronic locking. There is no need for an open diff in 4wd so I don't see any problem with this setup.
/ My newest toy... #11
The two rhino's I have owned both had locked rear ends. It had limited slip and fully locked options for the front end. Great units but they will tear your yard up. I traded for a ranger because it had a turf mode.
/ My newest toy...
Yes, all Rhinos have locked rear diffs, which can tear up your lawn in wet conditions, tight turns, or high-speed turns. Alternatively, they offer the capability to electronically lock the front diff in tough situations, which a lot of their competitors (including Kawasaki) do not offer. Most of my riding will likely be on gravel roads or logging roads.
It would be nice if you could electronically unlock the rear, but...
That may be something they offer on their redesigned 2010 models, which supposedly will offer a 4-seater version as well.
All I know is that these kinds of deals make me feel good about mine:
http://cgi.ebay.com/ebaymotors/NEW-...oryZ6725QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
/ My newest toy... #13
thats the one thing that i don't think yamaha will ever change is the rearend it seems evereone complains about it but they seem to never do anything about it. but to tell you the trueth i would rather have it locked all the time then have the eletronics go out on the trail and need the rearend locked and not have it. i can get by without the front end locked but that rearend is a must in the mud the only time it comes into a problem is in the yard it tears up stuff plus it's hard on the tires too. if they ever do change it i hope they make it a manual unlocker like the hpx is .
/ My newest toy...
BTW,
Here's some good pics of what a 450 Special Edition looks like, that were used in the ad above -- I had to work around the way the ad was distorting and displaying them.
Can you tell I'm a bit anxious to be able to bring it home?:eek::eek::D:D
/ My newest toy... #15
the best thing about the 450 is the gearing . it's geared lower than the 660 so it can turn tires just as big as the 660 and pull loads just as heavy as the 660 can so really you got a 660 in a 450 package. i never checked the gearing on the 700's but i do know the 450's will do anything a 660 will do and more.
/ My newest toy... #16
KentT
Your just going to love it, we have an 05 660 with just over 1000 hrs on her. Most of the time it's hauling hay / manure or feed to the horse barn. it's never clean, gets used everyday and has not once let me down. I have an American Eagle snow plow a 3500 Warn winch, windshield and a molded roof. Extra lights are a must! Look up this new company, J Strong Industries, they make some of the nicest windshields, door covers and back cab enclosures I've seen.
Good luck and send more pictures.
Malvern
/ My newest toy...
KentT
Malvern
Since you asked -- here is it with less than 1 mile on the odometer... I got in home about 7:00 last night and snapped these pics this morning. It'll never be this clean again...
/ My newest toy...
And a few more...
2014 GMC Acadia AWD SUV (A61574)
2014 GMC Acadia...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2013 Nissan Pathfinder 4x4 SUV (A61574)
2013 Nissan...
Case skid steer wheels and tires (A63689)
Case skid steer...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
