Holes for Cat 1 pins
   / Holes for Cat 1 pins #1
Eric_Phillips
Rochester, NY
FarmTrac 270DTC
I am trying to modify a post driver to attach to my 3 PH. I need to drill some 7/8" holes in 1" thick plate for the lift pins. Where do you guys find 7/8" twist bits to drill these holes or do you use some other method?
   / Holes for Cat 1 pins #2
Ahh somebody has to say it -- Harbour Freight!! They have a set of large diameter drills with reduced shanks that go on sale fairly regularly. They also have step drills but I cannot remember if one is actually 7/8 final diameter (i dont think so) so you could not use them to drill 1" material.
regards
   / Holes for Cat 1 pins #4
I would use a good quality hole saw.preferably on a drill press on slow speed.Pre drill the pilot,use plenty of oil to keep the bit cool.And clamp it down.Tim
   / Holes for Cat 1 pins #5
I too recommend hole-saws. I read somewhere that anything over 3/4 that is not a blind hole of course, it is better to use a hole saw. THey will be less expensive than a drill bit too.
Mike
   / Holes for Cat 1 pins #6
A hole saw will work, but I have found that if you want a nice tight hole the twist bit is the way to go!
I would think that for a link pin you would want to keep slop to a minumum?
   / Holes for Cat 1 pins #7
A hole saw would be second choice for me too. It will make the hole but they tend not to be as true as with a twist bit.
   / Holes for Cat 1 pins #8
Good Mornin Tim,
I agree providing the OP doesnt have a drill press. If he does not Lennox hole saws are my favorite ! ;)
Good Mornin GT2,
As I said above, the twist bit with a sturdy drill press will give the best results. But if using a large hand drill, I favor the holesaw. You may still get a sloppy hole using a twist bit of that size if drilling by hand. Of course, if you have all the toys you could hand drill 1/32 under and ream it for a great fit ! :)
   / Holes for Cat 1 pins #9
Eric if you can get the plate off use a drill press or mill at a slow speed and a Silver&Demming drill.
If you already have a large hole a hole saw will be a problem unless you have a plug to fit the hole in the plate and that will keep the hole saw centered.
If you can not get the plated off and onto the drill/mill use the S&D drill with a good hand drill. Watch your self as that drill can/will hang up and twist out of your hands.
I have never tried the step drill in any thing heaver that sheet metal but I don't really think it would work for what you are talking about. The step drill is more for sheet metal, like electrical boxes.
Thanks for the help. I am needing to enlarge a 5/16" hole to 7/8" so the hole saw would pose some problems. Also there is no way to get the plates off and onto my drill press so I will need to go slow with a hand held. I will keep an eye on HF to see if they go on sale soon.
2023 Load Trailer (A55787)
2023 Load Trailer...
Set of Heavy Duty Steel Trailer Ramps, 60" Long (A59076)
Set of Heavy Duty...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
HAMM HTC15 TRENCH COMPACTOR (A52709)
HAMM HTC15 TRENCH...
2021 Ford F-450 4x4 Crew Cab Liftmoore 3612 1.5 Ton Crane Service Truck (A55973)
2021 Ford F-450...
2018 KENWORTH T800 HOTOILER (A58214)
2018 KENWORTH T800...
