Landscape Rake-King Kutter vs other brands...
   / Landscape Rake-King Kutter vs other brands... #1
msp321
Maine
Massey 1528
I am looking to buy a landscape rake and am wondering others opinions about the various choices and what size I should get to fit my Massey 1528 (28 hp). I am thinking either a 6' or possibly a 7' (if that will not be too big for the tractor). Should I go with a King Kutter, Leinbach, TSC Brand (which I haven't read too much good on with other implements) or something else. I'm not looking to spend a fortune, but want something that will hold up. I'm looking at using it for my driveway (1,400 feet) and am having about 7 acres stumped and leveled this spring to make more pasture for the horses and using it to clean that up. Thanks for you opinions.
Thats a good price for the 6'. The best I've seen so far up here in Maine was $462....which is with out wheels. Thanks for the feed back.
   / Landscape Rake-King Kutter vs other brands... #4
Here is some info on a Fred Cain rake I bought a while back. I absolutely love it. This thing is built stout. I hung the right end of the frame on a stump while turning too sharp, and it stopped me in my tracks without any damage to the rake. Other than my grapple this is my most used attachment.
Joe
   / Landscape Rake-King Kutter vs other brands... #5
I have a 7ft KK and it does ok for the price. There are 2 things I dont like about it. The pivot moves up and down about an inch and the angle iron the tines are mounted to flexes alot if you are moving heavy material. have you concidered used. You might get a top of the line used rake for the price of a new KK.
Bill
   / Landscape Rake-King Kutter vs other brands... #6
I have a KK 6ft I pull with my 20hp Kioti. Handles it just fine. I do some gravel drive maintenance, but mostly landscape/yard leveling. I do a lot of ball diamond maintenance too. Only thing I did was fabricate my own dolly wheels that are crank adjustable and I can swap back and forth to my 5' KK box blade. makes finish grading ,leveling easy and fool proof.
There are several threads on dolly wheels for rakes etc.
If you can't fab yourself buy them from the dealer, drawback is they are not easy to adjust up and down and they usually extend back only about 18". I built mine so the extension can be adjusted by pulling a pin and sliding from 2' to 4' behind the rake. Makes it even easier to get a uniform level grade. Just like a big road grader.
   / Landscape Rake-King Kutter vs other brands... #7
   / Landscape Rake-King Kutter vs other brands... #8
   / Landscape Rake-King Kutter vs other brands... #9
I've been very impressed with the quality of Woods rakes. One thing that seems rather trivial, but awfully nice once you start to use it is the quality of the tines. Look at some of the cheaper rakes and after much use, the tines are frequently bent more or less depending on what they have hit. Woods appears to use some fine Italian steel (each tine is stamped as such) and they appear to be much stronger (maybe more brittle - I don't know) and the quality of the forging is obvious. One look and you'll see this.
I appreciate the info. The Fred Cain is a tough looking piece of machinery. I couldn't find a wed site and I called the company direct. They quoted me $707.00 (plus shipping). I'll give Chandler a call as well. We don't seem to have as many options up here in Maine.
   / Landscape Rake-King Kutter vs other brands... #11
I just picked up a Leinbach 7' for $475. Built pretty stout but the tines IMO could be a bit tougher. Been using it to drag downed cedar brush to the burn pile and have caught the tines in the heavier branches and bent them. As far as sizing them what I was told was to measure the width of your tractor and get one that size or maybe abit larger. My tractor measures abit over 6ft. So I got the 7ft. Could have gotten the 8ft and still been able to angle it but 7 was fine.
   / Landscape Rake-King Kutter vs other brands... #12
I have a 6' rake behind my 32hp compact and it works well. I could easily handle a 7' but the 6' was wide enough to cover my tire tracks. The one feature I especially like about the rake is the double bolt pattern for each tine. It helps keep the tines spaced evenly and prevents shifting. The rake is made by Southern Manufaturing out of Tenn. For a little under $400 it seemed better constructed than the KK.
   / Landscape Rake-King Kutter vs other brands... #13
I got a KK and ordered the guage wheels directly from KK and still came in under $500. It works fine for me. JC
   / Landscape Rake-King Kutter vs other brands... #14
bought a new 6' Leinbach for $450 back in december, excellent far as i can tell. Used it for clearing vines, fallen branches and small bushes. Just got thru spreading 16 yards of white rock, did a great job
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
VOLVO SD75B SMOOTH...
2008 New Holland T2420 (A60462)
2008 New Holland...
2012 KOMATSU PC360LC-10 EXCAVATOR (A60429)
2012 KOMATSU...
