Backhoe Ford 555b backhoe shifter
   / Ford 555b backhoe shifter #1
paulownia
Greetings all,
I am looking at a ford 555b to purchase. Probably a late 80's model.
Cranks and runs good. However the forward lever does not go into forward easily. It goes but the transmission does not engage. Ya can go from reverse to forward and it goes every time. Just from neutral to forward it does not want to engage.
Is this simply a linkage problem or a transmission problem.
If so how to tell??
Thanks
David d.
   / Ford 555b backhoe shifter #2
Greetings all,
If so how to tell??
Thanks
David d.
There are a half dozen roll pins and several joints in the valve linkage. Some or all are probably loose enough to cause those symptoms.
2015 Ford F-350 Cab and Chassis Truck (A56858)
2015 Ford F-350...
WhisperWatt DCA-85SSM 85kVA Towable Diesel Generator (A55973)
WhisperWatt...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2025 Swict 84in Bucket Skid Steer Attachment (A56857)
2025 Swict 84in...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
telescope boom (A56857)
telescope boom...
