FreeCell Game #1941
/ FreeCell Game #1941 #1
BillyP
Eagletown, OK
JD 4610 ehydro MFWD
Have any of you beat this one? I've tried off and on all day with no luck. I don't want to know how to beat it, just is it beatable. If it is, I'll keep trying :eek:
/ FreeCell Game #1941 #3
I always went under the assumption that any freecell game was winnable.
Now....
My thoughts are changing...
/ FreeCell Game #1941 #4
Yes it can be beaten. The solution is relatively short.
After 4 tries I looked it up and then tested it. :eek:
/ FreeCell Game #1941 #5
Which version are you using, XP or Vista? The only thing to recommend Vista is that Freecell has unlimited undo.
That's why I have a 99% win record :D:D for 3400 games
Vernon
/ FreeCell Game #1941 #6
Yep, it is very winnable. You just need to change your strategy a bit.
There are two Freecell games you absolutely cannot beat:
# -1
and
# -2
So whenever someone says they can win every Freecell game....
That being said, there is a Freecell cheat that allows you to put any card anywhere and win....
/ FreeCell Game #1941 #8
I remmeber that one!!!! I swear I remember winning that game. And gosh it seemed like it took me weeks adn weeks (well off and on). I went on the internet and searched and did not read the solution only that it could be won. And by gosh I was so proud when I figured it out on my own. But man o man was tha a hard one. I can't even count how many times I had to restart it and try again another tactic. But on my own I figured it out :)
OK, I finally won it! Not on my own though. I looked it up, cause I have to get some sleep tonight ;)
That's the first one I haven't been able to solve, not sure I would have ever done it without the help of the internet.
/ FreeCell Game #1941 #10
FreeCell is the ONLY game that I play on my Windows XP and my statistics show 2113 wins and 1 loss. My loss was # 11982 which no one has ever found a solution to. (not counting #-1 and # -2 which are set-up games and can't be won)
#1941 was definitely one of the harder games. There are a few other real hard games but they are all numbered over 100,000.
/ FreeCell Game #1941 #11
I found a way to "win" any freecall game if you want your stats to be clean.
"If you press Ctrl+Alt+F10 for any FreeCell game, you get the User-Friend User Interface dialog box. Click the Abort button to win the game; return to FreeCell and move any single card and — ta da! — you've won!"
Unsolvable games are listed in Wikipedia. There are solutions listed for games one and two on the web but I have not tried them.
/ FreeCell Game #1941 #12
"If you press Ctrl+Alt+F10 for any FreeCell game, you get the User-Friend User Interface dialog box. Click the Abort button to win the game; return to FreeCell and move any single card and ta da! you've won!"
I just tried this on the Vista version and got zip, nada!
Neither did Ctrl-Shift-F10.
Vernon
/ FreeCell Game #1941 #13
I don't believe that this would be called "winning".
Games #1 and #2 are easy to win. It's games #-1 and #-2 that are impossible.
/ FreeCell Game #1941 #14
How about that frog jumping game I got in an e-mail last night. There's 6 frogs and you're supposed to swap their positions in the pond. I can't do it. It says it's a computer test for 2nd graders in China. Frog Leap Test
/ FreeCell Game #1941 #15
Took me about 20-30 tries. Yikes! That was a tough one. :)
/ FreeCell Game #1941 #16
Got it first try. :D
In all fairness, as kid I was sick a lot and had about a bazillion board games with plenty of time to figure them out. One was a very similar jumping peg and hole game. ;)
/ FreeCell Game #1941 #17
Me too got it on the first try in pehaps 20 to 30 seconds. I guess some people just have the knack for this kind of usless talent :) To bad you can't earn money jumping frogs around, ha-ha
John Deere 750C Dozer (A64047)
John Deere 750C...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 FREIGHTLINER CORONADO 122 SD DAY CAB (A63569)
2014 FREIGHTLINER...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
